sanhozeezee Samba Member
Joined: June 17, 2019 Posts: 171 Location: SF Bay Area
Posted: Mon May 03, 2021 1:26 pm Post subject: Anyone have luck with the 123 ignition? |
i just added some dual kadrons on my split bus with a 1641 dp. im getting the infamous flat spot off idle. to be more specific, when i give gas the motor will die out. *if* i feather the pedal i can get it pass the flat spot without dying or once im driving it will sputter and just continue running.
anyhow, i'm hearing it could be a number of things from accelerator pump/diaphram to my 009 not having as much advance timing. so i'm thinking of ponying up and getting a 123 electronic/bluetooth distributor and wondering if anyone here has one?
if so, can you share your experience with it? is it worth having the bluetooth feature to advance/retard timing on the fly? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon May 03, 2021 1:29 pm Post subject: Re: anyone have luck with the 123 ignition? |
Why not find the cause if it's the carb?
If you have the original carb you want to match it to the original distributor, so what carb do you have? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon May 03, 2021 2:26 pm Post subject: Re: anyone have luck with the 123 ignition? |
i had a single solex carb matched with the 009.
the kadrons are "new to me" and were set up on a 1600 according to the PO. i'm going to revisit the carbs (resync, adjust, etc.) and also do the timing when i ran across some of the feedback from others saying the 123 distributors are nice cause it allows for much more advance than the 009. |
Posted: Mon May 03, 2021 2:37 pm Post subject: Re: anyone have luck with the 123 ignition? |
here's a video of it running after instal...
Glenn Mr. 010
Posted: Mon May 03, 2021 3:30 pm Post subject: Re: anyone have luck with the 123 ignition? |
sanhozeezee wrote: |
How much advance do you think your engine needs?
I wouldn't go more than 30* in a bus. _________________ Glenn
Member #1009
#BlueSquare |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Mon May 03, 2021 5:59 pm Post subject: Re: anyone have luck with the 123 ignition? |
I'd look into the CB Performance Black Box. It's done wonders for my dual IDFs. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Mon May 03, 2021 7:37 pm Post subject: Re: anyone have luck with the 123 ignition? |
I was just yesterday beginning on rehabbing my engine that has been shelved for the last 6 years. It's a single port 1600 with dual Kadrons, a 009 and a single quiet pack muffler. Ran like a top for the last 21 years. Not being familiar with a dual port engine with the Kadrons, but I've got a vacuum balance tube between both intake manifolds and the right hand carb air cleaner base has a tube that connects to the oil breather with a hose. I see you have routed your breather through the tin? Is that how it is done? A friend with a freshly built 356C engine went round and round for months with his engine exhibiting an off idle issue as per your video, he wound up having the carbs completely rebuilt (about $1700!) and the issue went away. He had tried other carbs, distributors, coils, wires, you name it.....in the end it was the carbs. |
Posted: Mon May 03, 2021 9:10 pm Post subject: Re: anyone have luck with the 123 ignition? |
so a friend dug in to one of the carbs and turns out the accelerator diaphragm was rock solid and looked like the fuel that sat in it for years kept it from moving and didn't squirt much if any. explains why once the motor gets past the the AP range it runs nice and healthy. gonna order a rebuild kit and see if that solves the problem.
btw, does anyone know what size idle and main jet a stock 1600 motor takes? |
karl h Samba Member
Joined: October 10, 2005 Posts: 578 Location: austria
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1257 Location: Bay Area, California
Posted: Tue May 04, 2021 2:13 am Post subject: Re: anyone have luck with the 123 ignition? |
No experience with the ignition you mentioned OP, but I had a similar problem with my Kads. Turns out one of them had a cracked emulsion tube, sent them back to Kaddie Shack and they fixed them. There's no more flat spot, No more hesitation off idle, with Pertronix Ignitor in a Bosch 019 equivalent, Pertronix Ignitor coil, and 30° of advance. Have had it set this way for 10 years, haven't adjusted the timing since.
https://shop.kaddieshack.com/Kadron-Solex-H40-44EI...KAD-EM.htm _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Sun May 16, 2021 9:27 am Post subject: Re: anyone have luck with the 123 ignition? |
quick update: we just installed the new ac pump diaphragm and the hesitation from idle seems to be fixed. but i’m still getting a flat spot just after idle. i picked up the 123distributor and wondering if anyone can share the right static timing? according to the instructions, it says for the 009 the static timing is set at 7 deg. should i set it for a little more advance?
it also says that the advance at 3000+ rpm should be between 28 and 32deg. |
Posted: Sun May 16, 2021 12:44 pm Post subject: Re: anyone have luck with the 123 ignition? |
just finished installing the 123 unit. pretty sweet imo. here's a video of it running and the curves i have set so far. eliminated the flat spot form idle completely! now i have some studder mid range which i think is related to my timing curve not right yet. below the video are the curve settings i'm looking to get help with...
CamBiscuit Samba Member
Joined: February 27, 2012 Posts: 82 Location: Adelaide Australia
Posted: Mon May 17, 2021 5:40 am Post subject: Re: anyone have luck with the 123 ignition? |
Curious to know how you are getting on with this?
It would be great to get it on the dyno to be able to see what works in the way of adjustments in real time........ _________________ 1965 ratty single cab
Instagram @cambiscuit |
Culito 11010101
Posted: Mon May 17, 2021 8:25 am Post subject: Re: anyone have luck with the 123 ignition? |
I'll see if I can post a screenshot of my Black Box dist. curve and MAP settings.
I just have it on the default dual carb setup, and It's been running beautifully. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Posted: Mon May 17, 2021 9:10 am Post subject: Re: anyone have luck with the 123 ignition? |
CamBiscuit wrote: |
It would be great to get it on the dyno to be able to see what works in the way of adjustments in real time........ |
i was able to get in contact with the manufacturer of the product and they gave me some better maps for a baseline. definitely runs better but not perfect.
I just have it on the default dual carb setup, and It's been running beautifully. |
thanks culito! i'd love to see what your settings are and can run it to see if my motor likes it better. |
ted698 Samba Member
Joined: June 17, 2016 Posts: 104 Location: Shropshire, UK
Posted: Mon May 17, 2021 9:23 am Post subject: Re: anyone have luck with the 123 ignition? |
I run a very similar setup - a 1904 SP heads, dual Kad's (from KaddieShack) with Vac.
I have a 123Tune+ Bluetooth Distributor and did a fair amount of work to get this far - I found the more advance you give it at idle the smoother it ticks over, and the sooner you ramp up the advance the less 'flat spot' type symptom you get.
I did a comparison graph between the stock 034 Vac Adv dizzy thats commonly fitted these days and a Mallory (now MSD) $400 red top with GREY/GREY springs that John at Aircoolednet recommends and what I found 'felt' seat of the pants right.
What the excel graph *really* shows is just how sedate the advance is on a stock 034 (this was mapped from the correct Bosch half speed distributor tables) - the settings I use really pepped up the engine - you can see I start my advance at 11 for nice tickover, (modern cars these days run really high idle adv - 14/16deg!), the only change from these figures is I fancied occasionally on a hot day I thought it pinged a touch (just once or twice), but I could have been imagining this, so I dropped the final advance back a degree to 31.
The important part is the more agressive ramp up of the advance rather than the overall final advance, it would be interesting to see what the best results would be from a proper dyno.
I can't take credit for all of this - as I spent alot of time looking at the ignition maps from the MegaJolt and Programmable ECM boys - but the ign point is gnerally the same across most maps - its just the way you fire it!
Cheers,
TED
(also to add I'm in the UK where we have 95 Octane petrol (gas!) as a minimum standard, with 97 as 'super' I just run standard pump 95)
Posted: Mon May 17, 2021 10:33 am Post subject: Re: anyone have luck with the 123 ignition? |
you rock ted698! i'm gonna try plugging in your numbers and see if it improves my set up. question, i read somewhere in the manual to ty and keep the points on the lower side. at 10, are you seeing any weirdness? |
ted698 Samba Member
Posted: Mon May 17, 2021 11:20 am Post subject: Re: anyone have luck with the 123 ignition? |
No not at all, the more data points you have mapped the finer the control in my opinion.
Your vac map looks a bit tame, try adding my numbers as you are rolling your vac off pretty early. It took me a while to get my head around the vac programming but if you remember that normal air pressure is 100kpa, so anything less than 100 is vacuum. |
Posted: Mon May 17, 2021 11:35 am Post subject: Re: anyone have luck with the 123 ignition? |
ok plugged your numbers in and i can't tell if it helped me lol. i notice the flat spot isn't off idle anymore for sure. but right around 1200-1500 if i punch thru it'll stutter but stay running. if i stay on the pedal and gradually climb thru it will drop rpm's and eventually die if i don't feather the pedal.
i checked my accelerator pump travel and im at 4mm per kaddyshacks video. i also replaced the diaphragm since it felt a little stiff. i guess next is to pull the idle and main jets to see if the PO put in the wrong size? |
Culito 11010101
Posted: Mon May 17, 2021 1:27 pm Post subject: Re: anyone have luck with the 123 ignition? |
Not sure these will help much since the Black Box does things a bit differently, but here's my spark table and vac map. These are just the defaults - I have tweaked mine a bit here and there but this was a good starting point for me:
Note that RPM is on the vertical column, and engine load is across the top, low load on the left to high load on the right.
Note that you vac settings might change based on you elevation (I'm at about sea level). _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
