What month is this engine code?
dirtbug
dirtbug is offline
PostPosted: Thu Sep 10, 2020 7:20 am    Post subject: What month is this engine code? Reply with quote
I have a 36hp that sings like a sewing machine. But I would like to narrow down the build month if possible. I know it's a pre-56. Thanks for any help you guys can lend.
1959 Type 1 - Owned since 1983
1959 Ragtop - Owned since 1986
1965 Type 1 - Owned since 2002
"8 dumb guys are smarter than 1 smart guy!"
sgmalt46
sgmalt46 is offline
PostPosted: Thu Sep 10, 2020 8:39 am    Post subject: Re: What month is this engine code? Reply with quote
early dec.55 . look in the technical section under vin/chassis numbers . it's a beetle engine type 1
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Thu Sep 10, 2020 9:31 am    Post subject: Re: What month is this engine code? Reply with quote
… years ago (around 1977), I made a photocopy of a number chart, that I refer to, all the time - might be the best reference chart around - is 1949 to 1959 and includes chassis, engine, rear axle, front axle, frame and body numbers - musta' got it from a VW book, somewhere... way before the birth of thesamba …/
… anyway, your engine number 1248714 is a 1956 model 36 horse, made in 12/1955 - z
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
dirtbug
dirtbug is offline
PostPosted: Fri Sep 11, 2020 6:58 am    Post subject: Re: What month is this engine code? Reply with quote
Wow, thanks. Just the info I needed. I got this motor from a good friends 1956 bug back in the 80's. I always thought it was the original engine from the car. I put it in my 1959 ragtop 20 years ago, it sat in my barn and never ran. Pulled it out a few months ago and it purrs like a kitten.
The stamping "1964" means it was probably rebuilt then, but not sure what the "A" represents or the upside down "2674". Could that mean it was rebuilt Feb 1974 as well?
Thanks again!
dirtbug
dirtbug is offline
PostPosted: Fri Sep 11, 2020 7:00 am    Post subject: Re: What month is this engine code? Reply with quote
Would love to have a copy of the number chart. Great info
ZENVWDRIVER
PostPosted: Fri Sep 11, 2020 9:07 am    Post subject: Re: What month is this engine code? Reply with quote
Thanks again!
… I always thought the "A" was a rebuilt marking, but there was a fairly recent thread advising the "A" was not a rebuilt stamp - have fun - z
1960 single cab
'87 Toyota MR2
Blue Baron
VW Aficionado
Blue Baron is offline
PostPosted: Sat Sep 12, 2020 3:40 pm    Post subject: Re: What month is this engine code? Reply with quote
In the photo you can see the year 1964 is stamped. I wonder what the purpose was.
Heinz Nordhoff
janerick3
janerick3 is offline
PostPosted: Sat Sep 12, 2020 4:31 pm    Post subject: Re: What month is this engine code? Reply with quote
Inspector's stamp from the factory.
Thanks,
Jan K.
bwaz
bwaz is offline
PostPosted: Thu May 13, 2021 9:47 am    Post subject: Re: What month is this engine code? Reply with quote
so, any idea how long from the time a block was stamped on the side of generator tower, until the time it was built? I assume the stamp was part of the mold, added after it was pulled from the mold or during the pouring of the mold? I assume they were quick to build the cases, but how quick a turnaround I wonder
Dan22
Dan22 is offline
PostPosted: Thu May 13, 2021 6:54 pm    Post subject: Re: What month is this engine code? Reply with quote
My understanding is the A indicates it has the metal cam gear, as opposed to fiber.
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
qwerty
qwerty is offline
PostPosted: Fri May 14, 2021 6:11 pm    Post subject: Re: What month is this engine code? Reply with quote
Here is some info from VW parts manuals - one page for T1 one page for T2
qwerty
qwerty is offline
PostPosted: Fri May 14, 2021 6:22 pm    Post subject: Re: What month is this engine code? Reply with quote
more T2 detail 52-57
Kjell Roar
Kjell Roar is offline
PostPosted: Mon May 17, 2021 6:18 am    Post subject: Re: What month is this engine code? Reply with quote
Thanks again!
I dont think VW rebuildt the old cases from before 1957 in 1964. In 57 the case was upgraded, better oil channels & stronger, eg around main bearing. My 8/55 (56 YM) got a factory refurbisged engine in 1964, the case is from 9/57. Still runs it today.
I have seen several factory refurbished 36hp engines through the years, but none with the old case.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
