garymaertens Samba Member
Posted: Mon May 17, 2021 1:15 pm Post subject: He won't unlock door after door trigger/button has been pulled |
Hey everyone just wondering if anyone has ever had this problem, my bay window bus door locks work fine except for the driver side will not unlock with the key if the button has been pushed I can lock and unlock it fine but if the button is pushed while the door is locked I have to go through the car and manually unlock from the inside. I'm wondering if there's some kind of spring missing or something broken inside my door handle.
But like I mentioned if I locked the door come back later and unlock it without ever pulling the handle button it will unlock with the key just fine, just not if the trigger button has been pushed between being locked with the key and unlocked with the key.
It's sort of a good sign that tells me someone has tried to open my door between the last time I locked it but I still have to go through the car to unlock it manually at that point. |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1765 Location: Newmarket, ON
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon May 17, 2021 2:25 pm Post subject: Re: He won't unlock door after door trigger/button has been pulled |
Thanks busdaddy |
framed Samba Member
Posted: Tue May 18, 2021 9:39 pm Post subject: Re: He won't unlock door after door trigger/button has been pulled |
I have same problem.
I think the new doorseals are to blame.
when I push the door inwards when unlock, the lock starts to works fine. |
Posted: Tue May 18, 2021 9:50 pm Post subject: Re: He won't unlock door after door trigger/button has been pulled |
Hhmmmm I'll have to try that too..
Thx |
Posted: Tue May 18, 2021 9:57 pm Post subject: Re: He won't unlock door after door trigger/button has been pulled |
Sorry, forum add title should say KEY not He. |
