How much propane
Forum Index -> Eurovan Share: Facebook Twitter
MrPulldown
MrPulldown is offline
PostPosted: Mon May 17, 2021 10:32 am    Post subject: How much propane Reply with quote
Every thing I have read says that my 2002 EVC has a 5.9 gallon tank. If completely empty and assuming 80% fill capacity, that should mean I can get 4.7 gallon in.
I had run my tank dry, I mean completely dead. Couldn't even get a flame on the stove. Went to fill yesterday, and it stops at 2.5 gallons. Guy tried to cram some more in, mostly just venting out propane, with the meter stopping on 2.7.
Is this right. I have always filled up when the gauge shows low and get under 2 gallons. Always figured the gauge was just off and there was a bunch more fuel. Doesn't look that way now. Could the 2001-2003 have a smaller tank?
Could this be an indication of a problem with my propane system?
2002 EVC
VolksVelo
VolksVelo is offline
PostPosted: Mon May 17, 2021 1:23 pm    Post subject: Re: How much propane Reply with quote
Just filled mine up few days ago and it's exactly 2.5 gal
with a near empty tank (1/8 full)
EVC 2002
MrPulldown
PostPosted: Mon May 17, 2021 1:56 pm    Post subject: Re: How much propane Reply with quote
EVC 2002
Good to hear that someone else has the same results. Thank you.
Wanting to hear from more owners.
2002 EVC
orbeamike
orbeamike is offline
PostPosted: Mon May 17, 2021 2:32 pm    Post subject: Re: How much propane Reply with quote
I ran my propane tank empty just over 2 months ago to the point my Norcold can't hold a pilot light. I had it filled at local U Haul and I remembered the fill is right around 4 gallons, may be a tad under. 2.5 gallons definitely sounds low.
steve2sloth
steve2sloth is offline
PostPosted: Mon May 17, 2021 2:56 pm    Post subject: Re: How much propane Reply with quote
The last time that I filled my 2002 EVC's propane, I could only get 3 gallons into it but I don't think that I was totally empty. For what it's worth, GoWesty's replacement propane tanks are 5.9gal for 1995-2001 EVC and 4.6gal for the 2002-2003 EVC.
MrPulldown
What year?
I think I recall you having a 2001.
2002 EVC
orbeamike
PostPosted: Tue May 18, 2021 2:39 pm    Post subject: Re: How much propane Reply with quote
MrPulldown wrote:
What year?
Yes, I have a 2001 EVC
Broseph Stalin
Broseph Stalin is offline
PostPosted: Fri May 21, 2021 2:04 pm    Post subject: Re: How much propane Reply with quote
My '03 took 3.5g's many times. It's a 20lb tank so impossible to get more than 4.5g into it even dead empty. Be happy you have a propane system that works. Winnebago did a good job IMO. Crawl under and replace cracked hoses, protect them with wireloom, spray Aerospace 303 on anything rubber.
'68 Bus in West Germany, 1977-1979
'67 Riviera poptop conversion in the US, 1984-1990
'95 EVC Winnie, 2018, Sold
'03 EVC Winnie, 2018, Sold
MrPulldown
PostPosted: Fri May 21, 2021 3:21 pm    Post subject: Re: How much propane Reply with quote
Any tips on hose to replace the hoses. My main HP line coming off the tank was leaking when on a trip, right at the crimp connection. I bought some 2 part epoxy and slathered it with it. Sealed up really well, but I bought a new hose to replace. Got under there and couldn't figure out how to access the upper connection. Figure, like you said, that I should also replace the 2ndary low pressure hose. I can't even find it.
2002 EVC
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
