EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sun May 16, 2021 9:43 am Post subject: Re: Nice quality drums . . NOT |
It’s fine if the op wants to post the manufacture of the drum, and where they got it from. The issue is, unless we are buying NOS VW drums, we’re all at the mercy of the past of a used drum/quality of an aftermarket one.
How long was the drum on the car? Is the wheel that it was used on perfectly straight/round, and balanced to zero? How old are the tires? Are the tires perfectly round in circumference? It doesn’t take much for something a tiny bit off to cause a tiny issue that compounds into a larger one. Not sure if you have a yearly state safety inspection, but when’s the last time you looked over the entire mechanicals of the car? Like mukluk mentioned, there was already corrosion in the cracks of the broken sections, so it had been cracked at least a couple of weeks to a month.
I dispose of dozens of sets of fully threaded tires at work that are on fair weather classic cars that are no longer round, or are starting to crack from age. What issues in our hobby have nothing to do with quality of parts, but the 180 degree change of having a 60’s Beetle that gets driven 1k miles yearly instead of 15k miles like it may have been in the early 70’s?
And as for AAA... The last tow on a customer’s car I needed around this time last year took an hour to get to me, and a half hour to get home. Something else to think about is the call frequency in your area. Needing a jump start, or gas in a vehicle after your area just got a foot of snow is going to have you waiting awhile from all of the idiots needing towed that can’t drive in snow. Needing a tow during Friday rush hour on Memorial Day weekend isn’t going to get to you anytime soon. Those hating it so much, cancel it. Just be sure you have a friend with a truck/car trailer on standby. You could always make sure your break down is in a dry, well lit, safe/secure place to leave your car while you can get the part to then repair it on the spot to get you home. |
QRP Samba Member
Joined: April 27, 2008 Posts: 1712 Location: NORTH HOLLYWOOD,CA
Posted: Sun May 16, 2021 1:02 pm Post subject: Re: Nice quality drums . . NOT |
[email protected] wrote: |
I'll go along with the first two line you wrote.
After that you're assuming quite a bit aren't you? |
Posted: Sun May 16, 2021 1:15 pm Post subject: Re: Nice quality drums . . NOT |
QRP wrote: |
If it’s genuinely a defect in an aftermarket part, post the manufacturer as a “look what happened to me, it could happen to you” heads up.
While I’ve seen an odd defect in a part, the majority of failures I’ve come across in the last 18 years are usually caused by something else. So no, not really assuming from my experience.
Assuming would be simply installing another drum without checking anything else. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3443 Location: San Diego
Posted: Sun May 16, 2021 1:54 pm Post subject: Re: Nice quality drums . . NOT |
There are pics of broken brazilian rear drums in the gallery. Same as this one |
AlteWagen Troll
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Sun May 16, 2021 11:17 pm Post subject: Re: Nice quality drums . . NOT |
Since you were already using a spacer....you might try
Some of these "German made5 lug adapter drums" (modified 1960 bus drum)
Which are currently for sale. |
QRP Samba Member
Posted: Mon May 17, 2021 11:01 am Post subject: Re: Nice quality drums . . NOT |
No markings on this drum anywhere, any one wanna guess.
I was fortunate enough that no other damage was done.
Everything else looks ok.
I'll take it apart and clean it all up to make sure.
And just for the record I don't drive around with old unbalanced tires on bent rims, and I do drive this bug a lot. |
mark tucker Samba Member
Posted: Mon May 17, 2021 12:15 pm Post subject: Re: Nice quality drums . . NOT |
Glenn wrote: |
Use an impact gun. |
and try to kill the trans while your at it......breaker bar and long pipe. looks like typickel CiPee down your leg .com drums....yes it's a good think you were going slow. be sure the rim isant effed up too. |
QRP Samba Member
Posted: Mon May 17, 2021 1:20 pm Post subject: Re: Nice quality drums . . NOT |
mark tucker wrote: |
Glenn wrote: |
Yeah that's what I did, pipe wrench and a breaker bar, no problem.
Got a nice souvenir for the failure shelf. . . LOL
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Mon May 17, 2021 1:43 pm Post subject: Re: Nice quality drums . . NOT |
Wow, congrats on getting it off. I hope you can find a good source for quality drums.
I see you have some leakage back there that needs to be addressed...and it must be my eyes, I can't really tell, but it sorta looks like the adjuster screws are wrong-way-round? |
satterley_sr Samba Member
Joined: March 31, 2005 Posts: 650 Location: Belleville,MI
Posted: Mon May 17, 2021 2:09 pm Post subject: Re: Nice quality drums . . NOT |
Also seen this on a lot of F Vees with the Italian drums. We now use smooth OG drums or there is a company in Indy ICP making new drums. _________________ DDC racing |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Mon May 17, 2021 2:21 pm Post subject: Re: Nice quality drums . . NOT |
satterley_sr wrote: |
Also seen this on a lot of F Vees with the Italian drums. We now use smooth OG drums or there is a company in Indy ICP making new drums. |
This,
https://icpcitation.com/partsfv.htm _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Mon May 17, 2021 2:48 pm Post subject: Re: Nice quality drums . . NOT |
67rustavenger wrote: |
This,
https://icpcitation.com/partsfv.htm |
Anyone know how much those cost? _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Mon May 17, 2021 3:07 pm Post subject: Re: Nice quality drums . . NOT |
Broken aftermarket drums have been an issue in off roading for a long time, especially the class 9 guys whom a lot of still run wide 5. Many will only run original german drums off road. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
QRP Samba Member
Posted: Mon May 17, 2021 5:27 pm Post subject: Re: Nice quality drums . . NOT |
evanfrucht wrote: |
This,
Anyone know how much those cost? |
Good question, I couldn't find it on the sight either. |
Posted: Mon May 17, 2021 5:44 pm Post subject: Re: Nice quality drums . . NOT |
QRP wrote: |
evanfrucht wrote: |
This,
Call and ask what they cost!
Bob Lybarger Racing
4414 W. HiPoint Road
McHenry,IL 60050
Tel: (815) 363-8560 _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Mon May 17, 2021 6:02 pm Post subject: Re: Nice quality drums . . NOT |
Link is no longer any good as Lybarger died a few years ago. But, I do have a contact through another forum and found that the ICP drums are $150 each plus shipping.
email is [email protected] _________________ DDC racing |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue May 18, 2021 8:06 pm Post subject: Re: Nice quality drums . . NOT |
Fuck that’s a no-brainer. I wonder if they make Type 3 size.
Also I didn’t know the prodigy domain still existed! _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Tue May 18, 2021 8:17 pm Post subject: Re: Nice quality drums . . NOT |
Folts makes a billet insert for the drum so the class 9 guys stay legal. Call and ask him. 9099235970.
K in can post some pictures tomorrow if your interested. _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
