hockeymatrix Samba Member
Joined: July 02, 2013 Posts: 18 Location: Wet Coast Canada
Posted: Tue May 18, 2021 11:11 am Post subject: Removing glue from behind white vinyl on pillars |
Hello all. I am restoring the inside of my '77 Riviera. I have pulled all of the white vinyl that was stuck onto the pillars around all of the windows. There is a residue of old glue that completely resists rubbing alcohol, paint thinner, and acetone. It appears organic, and it chips and is brown in color. Does anyone have any ideas how to remove this glue from Hell? Thx, Ron |
BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Tue May 18, 2021 11:20 am Post subject: Re: Removing glue from behind white vinyl on pillars |
I haven't found anything to work well either. So I'm also interested to see what people say. I assume you'd like to maintain the OG paint underneath the glue? I am sanding down and repainting on my bus. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue May 18, 2021 11:26 am Post subject: Re: Removing glue from behind white vinyl on pillars |
A Laquer thinner soaked rag held up against it for a while will help, cover it with tin foil and tape it on. Once it's softer a 3M Stripe off wheel (or similar off brand) should do it. A heat gun also helps soften it up.
Worst case scenario a paint stripper wheel will get it off, but the paint underneath will suffer. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1039 Location: Calgary, AB
Posted: Tue May 18, 2021 11:35 am Post subject: Re: Removing glue from behind white vinyl on pillars |
I went through the same when I converted my Transporter to a Westy interior, and removed the vinyl to install a wooden headliner and wall panels. Nothing I tried even came close to removing it. I ended up sanding it down and spraying the area around the windows with some code-matched spray paint cans. It turned out pretty nice I thought. I guess it depends how much you value that original paint underneath. |
Posted: Tue May 18, 2021 11:48 am Post subject: Re: Removing glue from behind white vinyl on pillars |
I contacted 3M about adhesives and the rep said that once it gets this dry nothing will work. Since I will likely repaint the pillars, perhaps I'll use a wheel or sand it down.
My local shop said toluene or ethanol might work...but quite dangerous to work with.
What do you prefer to use to sand if you're reading this? |
Posted: Tue May 18, 2021 11:49 am Post subject: Re: Removing glue from behind white vinyl on pillars |
CanStan wrote: |
How do you get paint code-matched please? |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Tue May 18, 2021 11:55 am Post subject: Re: Removing glue from behind white vinyl on pillars |
hockeymatrix wrote: |
CanStan wrote: |
I've been eyeing paintscratch.com for a while. Haven't tried it yet, but I plan to real soon. https://www.paintscratch.com/touch_up_paint/Volkswagen/Bus.html _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Any decent auto body supply shop should be able to make you spray cans if you give them the correct paint code. Usually for around $20. It's not the greatest way in the world to do it, but I don't have access to a proper paint gun and setup, so it was my best option. If you're doing a Westy where curtains cover the majority of that painted area around the windows anyway, most people would never notice the quality of your paint job. |
Posted: Tue May 18, 2021 11:56 am Post subject: Re: Removing glue from behind white vinyl on pillars |
Depends on if you are a cheapskate, or don't mind a couple extra bucks for the right stuff. A local autobody paint store can mix it, and most of the time they can put it in a spray can as well, but don't expect to get away paying hardware store prices.
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
raygreenwood Samba Member
Posted: Tue May 18, 2021 1:30 pm Post subject: Re: Removing glue from behind white vinyl on pillars |
If the adhesive is dry and dusty...use a fine wire wheel.
If its still rubbery....50/50 mix basic mineral spirts (xylene) and acetone. Wet the rag and soak it. wipe up with paper towels and do not spread it around.
Both of these take work either way. Ray |
Posted: Tue May 18, 2021 5:11 pm Post subject: Re: Removing glue from behind white vinyl on pillars |
Thank you all for your input....Ron |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Wed May 19, 2021 7:40 am Post subject: Re: Removing glue from behind white vinyl on pillars |
I'm going through this process on my Vanagon Westy. I've found that using slow reducer and some coarse steel wool is effective. The slow reducer stays wetter, longer instead of drying quickly like acetone. Once it's scrubbed, I wipe it off with a reducer soaked rag.
Good luck! _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Wed May 19, 2021 9:17 am Post subject: Re: Removing glue from behind white vinyl on pillars |
Bulli Klinik wrote: |
Good luck! |
What kind of "slow reducer" are you using my friend? |
avoll Samba Member
Joined: September 04, 2014 Posts: 119 Location: Ottumwa
Posted: Wed May 19, 2021 9:54 pm Post subject: Re: Removing glue from behind white vinyl on pillars |
I used a wire wheel to bare metal, but I painted whole inside.
MEK will take anything off, but will remove paint also.
Maybe try sanding it off also. |
Posted: Thu May 20, 2021 8:55 am Post subject: Re: Removing glue from behind white vinyl on pillars |
Good luck! |
I'm sure any brand would work. I think mine is a PPG product. It should be available at any local, automotive paint supply store. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Thu May 20, 2021 10:48 am Post subject: Re: Removing glue from behind white vinyl on pillars |
Good luck! |
Yes. A product like xylene is a "slow" reducer. However, spending on the glue type it can not be strong enough.
This is why I mix with acetone (or MEK). Both of those are too fast. By that I mean....they will dissolve the glue...but flash off so fast they just leave a spread out mess.
The object of mixing a stronger/faster solvent with something slower is that it brings the flash off point of the hotter solvent up so it flashes off slower. It allows you working time.
The thing to around...is that most of the more efficient fast solvents ...are going to attack the paint. But if this is an area that is fully covered in vinyl.....I would not worry about the paint so much. You can repaint it with something like master series.
But.....if you are REALLY worried about saving the paint beneath this vinyl...sometimes the way to get this done ....is with the fast/hot solvents. You can cut MEK with a small amount of paint thinner or xylene to slow it down a little...not much. Wet a a rag....wipe quickly. it will dissolve some....and you take that away with the rag. Let it flash off and dry. Move to a clean spot on the rag and repeat. Keep doing this.
The object is to let any softened paint...completely dry and reharden before wiping again. Its Damn slow.....so work in one spot and them move to another to give it time to dry.
Ray |
