moonsocket Samba Member
Posted: Wed May 19, 2021 1:03 pm Post subject: Digital Clock hours counting like seconds |
Our digital clock does not work properly.
The hour numbers just continuously count.
Is there a fix for that?
We have a GoWesty stick on digital clock to cover it but I kinda want to figure this out haha |
kourt Samba Member
Joined: August 13, 2013 Posts: 2381 Location: Austin, TX
Posted: Wed May 19, 2021 1:13 pm Post subject: Re: Digital Clock hours counting like seconds |
Your left hours setting button is depressed, advancing the hours. And by depressed I mean pressed down, not emotionally depressed. Or maybe it is truly depressed, and trying to get your attention.
You need to jam a paperclip in the left hole, wiggle it around, and try to unjam it. Or disassemble the cluster to accomplish the same thing.
You can also use supportive language and try to engage with the clock to get to the root of the depression and help it turn a corner to a new world view.
These are German cars, so read up on weltschmertz to study the matter from the Teutonic perspective.
kourt |
SCM Samba Member
Joined: January 26, 2011 Posts: 3465 Location: Bozeman MT
Posted: Wed May 19, 2021 1:22 pm Post subject: Re: Digital Clock hours counting like seconds |
I have the opposite problem. Both buttons are busted so the only way I can "adjust" the time is to disconnect/reconnect my battery at noon or midnight. I usually don't bother with that though because always having to do math to figure out what time it is keeps my brain sharp. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Blakesinclair Samba Member
Joined: January 22, 2021 Posts: 60 Location: Santa Ana, California
Posted: Wed May 19, 2021 1:31 pm Post subject: Re: Digital Clock hours counting like seconds |
It took me forever to figure out where the little buttons inside the holes are. Thought maybe it was broken, but the buttons sit very low on mine. Not sure if it's the same, but try poking the bottom edge of the holes.
I like the midnight battery disconnect method though. _________________ ———————
1985 Weekender Vanagon 1.9L - Manual |
jlrftype7 Samba Member
Posted: Wed May 19, 2021 1:41 pm Post subject: Re: Digital Clock hours counting like seconds |
| kourt wrote: |
kourt |
This 'could' become a sticky..... Too funny _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Thu May 20, 2021 6:12 am Post subject: Re: Digital Clock hours counting like seconds |
Agreed that this should be a sticky!! Totally my humour so thank you for this kourt!!!
| kourt wrote: |
kourt |
rogertj Samba Member
Joined: October 07, 2008 Posts: 522 Location: Tijuana, Baja California. Mexico
Posted: Thu May 20, 2021 6:17 am Post subject: Re: Digital Clock hours counting like seconds |
That was definately funny
But yeah he was right on the spot with the paper clip method! _________________ Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17272 Location: Brookeville, MD
SCM Samba Member
Posted: Thu May 20, 2021 8:27 am Post subject: Re: Digital Clock hours counting like seconds |
| Blakesinclair wrote: |
I like the midnight battery disconnect method though. |
I don't think the buttons are supposed to be "inside" the holes because mine used to be flush with the surface of the console face. Now the left button is completely invisible deep inside the hole (maybe not even there) and the right button is still visible but doesn't respond to pushing in any direction.
I'm not really worried about it. Anytime I'm in the van is "fun time", the hour doesn't matter.  _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Thu May 20, 2021 11:33 am Post subject: Re: Digital Clock hours counting like seconds |
| For one of my vans, I made some taller buttons that don't get lost down in the holes when you push on them to set the time. Been a decade plus at this point in time so I don't remember what I used anymore. |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1173 Location: SF Bay area, CA
Posted: Thu May 20, 2021 12:43 pm Post subject: Re: Digital Clock hours counting like seconds |
I keep a couple opened paper clips on the floor next to the hand brake boot. Always ready to adjust the clock. Oh and yup, I have a couple spare clocks in my westy parts bin. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Posted: Thu May 20, 2021 2:50 pm Post subject: Re: Digital Clock hours counting like seconds |
| It finally occurred to me what I had used to make the longer buttons. I got some tiny plastic screws from the hardware store and shaped them to be just like the original buttons but a bit longer. |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1954 Location: anchor pt. alaska
Posted: Thu May 20, 2021 8:45 pm Post subject: Re: Digital Clock hours counting like seconds |
| Dude! You've got the ultra rare warp speed feature! Sorry, first thing that popped to mind. |
jimf909 Samba Member
Posted: Thu May 20, 2021 10:09 pm Post subject: Re: Digital Clock hours counting like seconds |
| cmayna wrote: |
| I keep a couple opened paper clips on the floor next to the hand brake boot. Always ready to adjust the clock. Oh and yup, I have a couple spare clocks in my westy parts bin. |
I always thought the "ashtray" was the clock-adjusting-device-garage. _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12397 Location: Santa Cruz, CA
Posted: Thu May 20, 2021 11:39 pm Post subject: Re: Digital Clock hours counting like seconds |
| If you want to fix it and get the buttons back flush the the cluster you have to remove the cluster and the clock. You will find a small zip zag looking plastic part that are the actual buttons between the clock and cluster. You can GENTLY bend the buttons outward on the plastic piece and that should fix the issue and help keep tension on the piece to keep the little buttons seated correctly in position. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24288 Location: NYC/Upstate/ROW
Posted: Fri May 21, 2021 2:48 am Post subject: Re: Digital Clock hours counting like seconds |
| kourt wrote: |
kourt |
The clock obviously has Zeit Geist _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Fri May 21, 2021 4:58 am Post subject: Re: Digital Clock hours counting like seconds |
Don't worry, it's just your Scoobydoo time machine taking you back to the seventies. _________________ This free advice is worth exactly what you paid for it.
4Gears4Tires Samba Member
Posted: Fri May 21, 2021 6:45 am Post subject: Re: Digital Clock hours counting like seconds |
| Abscate wrote: |
| kourt wrote: |
kourt |
The clock obviously has Zeit Geist |
You mean it hates Subaru conversions?  _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Posted: Fri May 21, 2021 9:39 am Post subject: Re: Digital Clock hours counting like seconds |
. ..and the presence of black holes dilate time.... _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Sun May 23, 2021 8:46 am Post subject: Re: Digital Clock hours counting like seconds |
I love all your posts!
I fixed it with a sewing needle!
I mean it tells the correct time now. The button is still hidden inside but I managed to get it set.  |
