Another 1.8T hits the road !!
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
VWhead
VWhead is offline
PostPosted: Sat Feb 28, 2015 4:54 pm    Post subject: Reply with quote
84' Red Doka 1.8T test drive
81' Single Cab Syncro 1.8T GMW
88' 2wd Westy 1.8T GMW
www.gmwerks.com
Tristar Eric
Tristar Eric is offline
PostPosted: Sun Mar 01, 2015 7:32 pm    Post subject: Reply with quote
The red Doka needs flares!
Looking good Paul!
Vanagon/Transporter flares here: www.terrawagen.com
Facebook:https://www.facebook.com/terra.wagen/
[email protected]
VWhead
VWhead is offline
PostPosted: Mon Mar 02, 2015 8:04 pm    Post subject: Reply with quote
Looking good Paul!
Thanks Eric, I agree they look pretty sweet on my 1.8T Westy
www.gmwerks.com
madspaniard
madspaniard is offline
PostPosted: Mon Mar 02, 2015 8:08 pm    Post subject: Reply with quote
Sweet video, when are you going to start doing conversions for vans with auto tranny?
"The only difference between me and a madman is that I'm not madĒ - Salvador Dali
VWhead
VWhead is offline
PostPosted: Mon Mar 02, 2015 8:30 pm    Post subject: Reply with quote
Thanks
Good question
I'm clearing the operating table for the next conversion, it's an automatic Westy. We have a real nice throttle drive-by-wire/kick down system designed for it. Looking forward to helping out the auto's Smile
www.gmwerks.com
ThankYouJerry
ThankYouJerry is offline
PostPosted: Mon Mar 02, 2015 9:00 pm    Post subject: Reply with quote
VWhead wrote:
Thanks
Good question
Stephan's been doing them. He just reworked/improved the throttle system very nicely! What's your plan for auto R&P?
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
VWhead
VWhead is offline
PostPosted: Mon Mar 02, 2015 9:18 pm    Post subject: Reply with quote
Yep, I know
R/P all depends on tire size. So why not put a bigger tire on stock R/P?
www.gmwerks.com
ThankYouJerry
PostPosted: Mon Mar 02, 2015 9:27 pm    Post subject: Reply with quote
Yep, I know
Give it a try. I had a bigger tire (215/65/15 = 26.5") mated to a 3.73. Didn't like it. Curious to hear how another R&P/Tire combo might work out.
Mountain1.8t
Mountain1.8t is offline
PostPosted: Wed Jul 20, 2016 4:21 pm    Post subject: Re: Another 1.8T hits the road !! Reply with quote
What are you 2wd guys running for suspension springs these days? I just installed a 1.8t in my '85 2wd westy with Gowesty 1.5" lift springs, and it appears to be sagging in the back. I believe the 1.8t engine is a bit heavier than the wbx, so I'm wondering what my options are at this point....
I'm not that excited to do spring spacers as I've read that it is not good for progressive spring performance.
I want to keep the van lifted between 1.5 to 2" max.
I want the van level.
Altoona
Altoona is offline
PostPosted: Wed Jul 20, 2016 4:34 pm    Post subject: Re: Another 1.8T hits the road !! Reply with quote
Spacers don't affect the spring performance at all. If you are happy with how it rides, throw some spacers in there.
Christopher Schimke
PostPosted: Wed Jul 20, 2016 4:48 pm    Post subject: Re: Another 1.8T hits the road !! Reply with quote
I totally agree (no issues with spring spacers)!
Christopher
VWhead
VWhead is offline
PostPosted: Wed Jul 20, 2016 6:03 pm    Post subject: Re: Another 1.8T hits the road !! Reply with quote
Spacers, it does the trick.
www.gmwerks.com
dkoesyncro
dkoesyncro is online now
PostPosted: Tue May 25, 2021 6:09 pm    Post subject: Re: Another 1.8T hits the road !! Reply with quote
Does anyone know what motor mount Paul used on the passenger side? The engine was an 06A block and used from a transverse Mk4 VW.
xoo00oox
xoo00oox is offline
PostPosted: Wed May 26, 2021 3:23 am    Post subject: Re: Another 1.8T hits the road !! Reply with quote
Do you have a picture of the mount your wondering about?
dkoesyncro
PostPosted: Wed May 26, 2021 5:17 am    Post subject: Re: Another 1.8T hits the road !! Reply with quote
I don't, but Paul reached out and said it was custom. It's tight because its squeezed in between the AC and the oil filter housing.
Par for the course here, I'm going to bend up some EMT to mock up the carrier bars before moving to some real stuff and using a tube bender.
xoo00oox
xoo00oox is offline
PostPosted: Wed May 26, 2021 5:27 am    Post subject: Re: Another 1.8T hits the road !! Reply with quote
Are you trying to mount up the Passat motor mount brackets and using the transverse accessories?
dkoesyncro
PostPosted: Wed May 26, 2021 9:25 am    Post subject: Re: Another 1.8T hits the road !! Reply with quote
Yes, I plan on a hybridized install, using majority of the transverse engine coupled with some audi bits like turbo/manifold and engine brackets. Currently playing with the lego bits and seeing what I like and don't.
xoo00oox
xoo00oox is offline
PostPosted: Wed May 26, 2021 9:51 am    Post subject: Re: Another 1.8T hits the road !! Reply with quote
It does all fit together, it is a little tight and requires some cutting and grinding but you can use the Passat mount and bracket and the MK4 accessories. I have done it a few times.
dkoesyncro
PostPosted: Wed May 26, 2021 5:27 pm    Post subject: Re: Another 1.8T hits the road !! Reply with quote
You use the Passat accessories bracket? It looked like I could use the Mk4 accessories bracket with the Audi engine bracket, this would require a v type notch cut from the mk4 bracket but looks like the AC might not line up well?
xoo00oox
xoo00oox is offline
PostPosted: Wed May 26, 2021 5:31 pm    Post subject: Re: Another 1.8T hits the road !! Reply with quote
Either one. What Iím saying is it is possible to use the transverse accessories bracket with the inline mounts. Takes a little cutting but it will work and gives you a very compact setup.
Page 9 of 9
