54bugn Samba Member
Joined: April 28, 2005 Posts: 493 Location: Parksville BC, Canada
Posted: Thu Jul 19, 2012 1:30 am Post subject: |
Thanks Joey thats awesome, looks good, I am sure you are happy with the results. Makes my job easier now that I have a visual when I go to do mine. Home this Saturday see you shortly after that, and I will check out the new install in person.
Cheers,
Mike _________________ "Schwing wrote:
You either have to be too cheap to hire a pro or determined to do it yourself, but it helps to be both!"
54 European Sedan deluxe
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=414940 |
gonebaby Samba Member
Joined: July 08, 2009 Posts: 110 Location: freeland pa.
Posted: Tue Jul 24, 2012 8:35 pm Post subject: |
Joey i bought this 57 and of course there are No vent windows. Can i buy any year door to use the vents? Thanks Rob |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Wed Jul 25, 2012 3:38 am Post subject: |
Anything from '56 to '64 will work. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Wed Jul 25, 2012 1:44 pm Post subject: |
thank you.. |
marzano Samba Member
Joined: July 26, 2006 Posts: 55 Location: Sao Paulo, SP, Brazil
gforcepdx Samba Member
Joined: March 23, 2008 Posts: 153 Location: portland,oregon
Posted: Mon Jun 06, 2016 11:28 pm Post subject: Re: How To - One piece windows back to vent windows |
I wanted to thank you for the work you did here. I looked for three days to find this. I'm buying a 57 ragtop with one piece windows I need to reverse. well done sir... john _________________ yes... I'm the one who destroyed this fine, vintage, automoble... |
Posted: Mon Jun 06, 2016 11:29 pm Post subject: Re: How To - One piece windows back to vent windows |
Peter_KG Samba Member
Joined: January 08, 2013 Posts: 148 Location: Belgium
Posted: Wed Jun 21, 2017 1:54 pm Post subject: Re: How To - One piece windows back to vent windows |
Great topic!!! Thanks!
Planning to convert the one piece windows of my '54 oval bug too...
Finally found all the period correct pieces!
Next step is to bend me an U-profile out of some sheet metal (1 mm thick?) for the support... I understand the profile should be 140 mm long, 18 mm wide... but how high did you make your support?
Thanks!!
Peter _________________ VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54 |
Joey Samba Member
Posted: Sat Jun 24, 2017 3:55 pm Post subject: Re: How To - One piece windows back to vent windows |
From the bottom of the 'U' to the very top of the door skin is 11mm. It the measurement in blue in this diagram:
Posted: Sun Jul 02, 2017 1:56 pm Post subject: Re: How To - One piece windows back to vent windows |
Joey wrote: |
Thank! You know how high, the actual channel (bracket) you welded in, was?
I'm planning to use sheet metal glue to avoid damage on my paint...
Thx
vwbrewer Samba Member
Joined: March 23, 2009 Posts: 201 Location: San Antonio
Posted: Sun Jan 28, 2018 12:53 pm Post subject: Re: How To - One piece windows back to vent windows |
Depends on how much material was hacked and/or trimmed. _________________ 1957 Oval Rag |
iamthewalrus30 Samba Member
Posted: Tue May 12, 2020 7:53 am Post subject: Re: How To - One piece windows back to vent windows |
I'm going to add this here just in case anyone recently is trying to add back their vent windows. My brother and I will be tackling this job for ourselves and is starting to gather the bits and pieces needed for the job.
He actually found this guy is Japan that is reproducing the inner metal that needs to be welding into the channel.
He bought the pair and is waiting to see if they will work for his 62' doors.
but if they do, this will save considerable time!
here is the link
https://www.ebay.co.uk/itm/VW-Bug-Beetle-Door-Wind...0903.m5276 |
shiddot Samba Member
Posted: Sun Sep 20, 2020 9:31 am Post subject: Re: How To - One piece windows back to vent windows |
iamthewalrus30 wrote: |
Really interested to hear if these parts were any good, and if you managed to add your window vents back in successfully?
My ‘61 has one piece windows (fitted by a PO in the 90s). My near side window regulator now needs replacing so I’m contemplating reverting to the original two-piece windows, but finding donor doors is not easy/cheap.
Taking off the door card for the first time since I bought the car in 2005 has revealed some interesting butchery scars that I can only assume were required in order to fit the later regulator into the early door?
(The piece of wood is wedging the glass up in place due to the regulator being stuck fully-open) |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sun Sep 20, 2020 9:54 am Post subject: Re: How To - One piece windows back to vent windows |
… and i want to go in the other direction - i want to go with one piece windows, but on ribbed units - not your 56 - 63 doors - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1048 Location: Germany
Posted: Mon Sep 21, 2020 12:06 am Post subject: Re: How To - One piece windows back to vent windows |
Thank you very much!
After the last "to do list" I assume, it is not possible to change the outer chrome trim/scraper thing without touching the vent window? At my car, I'm only interested in changing this, because of a destroyed rubber scraper itself... |
wbbbbbbb Samba Member
Joined: August 25, 2008 Posts: 83 Location: Washingtion State
Posted: Sat Apr 24, 2021 6:38 am Post subject: Re: How To - One piece windows back to vent windows |
One piece windows back to vent wing windows, restoration!
I bought these from eBay seller: ysbugs
Found trough Samba forums but can’t remember who originally posted it, wish I could credit member?
eBay Listing: VW Bug Beetle Door Window Vent Wing Inner Assembly Frame 2pcs.
Looks like just what I need to restore vent-windows on my 64 chop! Paided $38.47, S&H+Tax on 04/17, Delivered 04/23. 6 days!
See pictures! PN: 50541 RH side pulled for pic’s. Used $2.00 swap-meet green wing, LoL!
https://www.ebay.com/itm/132121350567
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Thu May 27, 2021 4:42 pm Post subject: Re: How To - One piece windows back to vent windows |
wbbbbbbb wrote: |
Thank you for posting this up!!!!! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Mon Jun 13, 2022 3:17 pm Post subject: Re: How To - One piece windows back to vent windows |
here is the link
@iamthewalrus30 – I would love to know how you got on with this? The eBay link is dead now so if you have any more info on sourcing the inner metal pieces from Japan that would be really useful. |
Posted: Tue Jun 14, 2022 10:31 pm Post subject: Re: How To - One piece windows back to vent windows |
All I have and can tell you the seller, currently has nothing for sale. Not sure if or how they can be contacted through eBay?
ysbugs (3,577)
91.9% Positive feedback
Member since 2015
Location United States
As for installing these I don’t have the time to install right now. I’m moving and need to remodel house before I can get back to my cars. |
