Mahag 1951 Standard Micro
rxBusboy
rxBusboy is offline
PostPosted: Wed May 05, 2021 10:54 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
CaLiBus
CaLiBus is offline
PostPosted: Wed May 05, 2021 8:41 pm    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Great kick ass work Donny! That epoxied frame is definitely in the right direction. Iíve got some BD metal scraps to donate to the cause. Keep it up!
Bendango
Bendango is offline
PostPosted: Thu May 06, 2021 1:23 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
This is going to be great to watch.
I want a real garage.
WANTED - [WTB] 55-62 Bus Thin Lip Package Tray SWR
Getting Used - SWR 60 westy copy built by vw ( apparently Rolling Eyes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=320866
Braukuche wrote:
Where did you find the elephant dick?
rxBusboy
rxBusboy is offline
PostPosted: Thu May 06, 2021 7:43 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
When I first got this bus I remember talking to Barndoor Jonny about how bad but fixable it is and he told me ďdonít throw anything awayĒ. So Iíve saved almost every scrap so far and Iíve salvaged many little peaceís.
This peace was a couple inches of the tray above the engine connected to the rear window section I got from Dave. I was struggling on the lower fire wall section. Just a wire wheel was blowing holes through the bottom of it. I love the look of it once I got the surface rust and thin layer of paint cleaned off of it he fire wall so repairing it was my only option.
This peace worked out well having the same grooves in it. It wasnít quite big enough but close enough.
rxBusboy
rxBusboy is offline
PostPosted: Thu May 06, 2021 8:07 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Rich's 50
Rich's 50 is offline
PostPosted: Thu May 06, 2021 4:24 pm    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Looking forward to it Donnie Cool
FOLK'S THOUGHT YOU KNEW..........
rxBusboy
rxBusboy is offline
PostPosted: Fri May 07, 2021 7:26 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Thanks Rich for watching and supporting.
Iíve accepted the reality that this bus wonít be on the road for 10 years if I try and do everything myself so Iím going to start having some friends help and Iím sure itíll end up at Daveís again once I get it back together and rolling.
rxBusboy
rxBusboy is offline
PostPosted: Fri May 07, 2021 8:53 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Iíve been in contact with Mark Spicer and thankfully he knows the details of these early busís. I am looking forward to getting some parts from him because I am not capable of making any parts besides basic patch peaceís or recycling other parts and making them work.
I want to repair the rear divider door and passenger window frame with parts that Mark makes.
j.pickens
j.pickens is offline
PostPosted: Fri May 07, 2021 7:56 pm    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Nice socks!
And great work on your project.
BeaterBarndoor wrote:
Red Fau Veh wrote:
rxBusboy
rxBusboy is offline
PostPosted: Fri May 07, 2021 9:53 pm    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
j.pickens wrote:
Nice socks!
thanks alot, my neighbors probably think so too. I'm in my garage alot late at night welding in sweats. Some look at what I'm working on and think I'm a tweeker.
rxBusboy
rxBusboy is offline
PostPosted: Sat May 08, 2021 10:53 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Here are progress pics. This section is getting close but the wheel well isnít lining up how it should yet. The tray above the trans and front 1/2 of fender well was redone with parts from Gerson.
VW_Barndoor_Force
VW_Barndoor_Force is offline
PostPosted: Tue May 11, 2021 7:27 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Great Work !
May the VW_Barndoor_Force be with you, always
1970PAKombi
1970PAKombi is offline
PostPosted: Tue May 11, 2021 11:59 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Nice save, you're doing amazing work. I am sure it's a joy to work on too!
rxBusboy
rxBusboy is offline
PostPosted: Wed May 26, 2021 10:51 pm    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Here is the progress report for the last couple sections we have been working on. My friend Jesse has been helping on the bus and he's a metal work veteran. I got the trans panel from Gerson and was planning on only using sections out of it but ended up using most of it and Jesse made the access hole by hand since thats 50-51 only. The rear fender wells and fire wall is where we are starting so I wanted it to be super strong and alot of this lower metal was just to thin.
I tried to keep a much original paint and metal on the divider wall as well. It's been a fine line where to replace metal and save metal that is compromised. The old German steel is so much stronger than the new cold roll stuff that sometimes original is still just as strong even with some surface rust.
rxBusboy
rxBusboy is offline
PostPosted: Wed May 26, 2021 10:53 pm    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
rxBusboy
rxBusboy is offline
PostPosted: Wed May 26, 2021 11:07 pm    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
I quit working on the frame months ago but now my goal its to get some loose ends tightened up on in and put the body back on the frame in the next few weeks.
Scotty
Scotty is offline
PostPosted: Thu May 27, 2021 5:04 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
You're doing a great job of trying to repair as much of the original metal as you can. Don't get disheartened (as I'm sure you may), it will definitely be worth it in the end.
I absolutely love this bus, so keep up the good work!
LAGrunthaner
LAGrunthaner is offline
PostPosted: Fri May 28, 2021 3:46 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Keep up the great work rxBusboy. Very interesting comment about the original steel.
Keep your eye on the prize. Applause Applause Applause
American Red Cross Safe And Well link:
https://safeandwell.communityos.org/cms/index.php?...OSmeUzh8l4
Maui Roadsters VW Logo
www.mauiroadsters.com
Lind wrote:
rxBusboy
rxBusboy is offline
PostPosted: Fri May 28, 2021 10:12 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
Thank Scotty, I have a few bus's and have many big projects but thiss is for sure the one I am enjoying the most. I already see the light at the end of the tunnel and its still a long tunnel
rxBusboy
rxBusboy is offline
PostPosted: Fri May 28, 2021 10:17 am    Post subject: Re: Mahag 1951 Standard Micro Reply with quote
I appreciate the motivation boost. Yes, the old metal is completely different and much harder to bend and make peaces out of by hand. Alot of the after market metal is actually thicker but still much softer. Trying to make a rib with original metal takes alot longer than with a new peace of metal.
Page 7 of 8
