Ted2 Samba Member
Posted: Mon May 24, 2021 11:43 am Post subject: Case material change |
Hi everyone,
When did VW change from Aluminum to Magnesium cases?
Thanks |
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon May 24, 2021 3:06 pm Post subject: Re: Case material change |
So, what is the answer - when? I cannot figure how to get to M9 in PR - Z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
RUNKLE Samba Member
Posted: Mon May 24, 2021 3:24 pm Post subject: Re: Case material change |
Here ya go.
_________________ Type 1
Type 3
1968 Squareback |
Posted: Mon May 24, 2021 3:51 pm Post subject: Re: Case material change |
… the NO-BS reply from JT Garwood > page 171 > 1951, at engine number1-0379470 and at ch. number 1-0313829, the engine crankcase was now made of a new aluminum magnesium alloy formula, known as electron - the crankcases were darker, beginning with 1951 models - they were not as shiny and bright as before - everything else, was left untouched for 1951...
… note on page 34 - 1945 engine - the magnesium aluminum alloy crankcase held the crankcase rigid in it's 4 insert-type main bearings - there were no separate cam bearings - the case was hardened, at this point - early engines, through 1950 were lighter in color then those used in 1951 and up - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Mon May 24, 2021 4:21 pm Post subject: Re: Case material change |
ZENVWDRIVER wrote: |
… the NO-BS reply from JT Garwood > page 171 > 1951, at engine number1-0379470 and at ch. number 1-0313829, the engine crankcase was now made of a new aluminum magnesium alloy formula, known as electron - the crankcases were darker, beginning with 1951 models - they were not as shiny and bright as before - everything else, was left untouched for 1951... |
Those numbers are the last VIN/Engine #s for 1951 so this sounds incorrect since it would be the beginning of the 1952 models.
The beginning of 1951 would basically be the numbers from Progressive Refinements above.
Another thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=150583 _________________ How to Post Photos
Ted2 Samba Member
Posted: Mon May 24, 2021 4:30 pm Post subject: Re: Case material change |
Thanks,
So, based on this information would the "new" cases have been Dow 7 coated? |
Posted: Tue May 25, 2021 10:23 am Post subject: Re: Case material change |
EverettB wrote: |
Another thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=150583 |
… one thing for sure is Garwood may be , incorrect at times, but is easy reading - That Progressive Refinements PDF really sucks - guess that's the best thesamba can offer - i'm one of those 'old schoolers' who relates to a (cost prohibitive) hard reading copy - can't say, thesamba didn't try though - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Tue May 25, 2021 10:28 am Post subject: Re: Case material change |
Ted2 wrote: |
Thanks,
Googled, Dow7 - Much like DOW 19, the DOW 7 is also a chromate chemical conversion coating. Chemical conversion coatings, when applied to magnesium, have chemical reaction which results in a thin film being formed on the magnesium surface. DOW 7 also contains the toxic chemical hexavalent chromium (aka:Cr 6+) - give your Dow7 a try, then report-in your findings - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Tue May 25, 2021 8:16 pm Post subject: Re: Case material change |
EverettB wrote: |
Another thread
… one thing for sure is Garwood may be , incorrect at times, but is easy reading - That Progressive Refinements PDF really sucks - guess that's the best thesamba can offer - i'm one of those 'old schoolers' who relates to a (cost prohibitive) hard reading copy - can't say, thesamba didn't try though - z |
It's a PDF so you can print it out if you prefer a hard copy.
In this case I would argue a PDF vs. a hard copy is superior since you can search it with the Find command.
Search on "crankcase" and you can jump right to that entry.
I post this info mainly for others to be aware of as it can be useful. _________________ How to Post Photos
splitjunkie Samba Member
Posted: Thu May 27, 2021 11:37 am Post subject: Re: Case material change |
EverettB wrote: |
EverettB wrote: |
Another thread
I post this info mainly for others to be aware of as it can be useful. |
Everett. Thanks for all the hard work that you go through keeping this great site and all of its resources available to all. It's a pitty that some don't appreciate it. _________________ Chris
sinclair Samba Member
Joined: July 01, 2004 Posts: 398 Location: New Forest UK
Posted: Fri May 28, 2021 1:55 am Post subject: Re: Case material change |
Ted2 I bet you wish you hadn't asked
It's good to have more than one point of reference. For me PR is great web based info for quick access anywhere and Garwood is a better read.
Not everyone has access to Garwood so credit to Zen for doing the digging when there's a query, as there's no search function in the book. |
Posted: Sun May 30, 2021 9:36 am Post subject: Re: Case material change |
EverettB wrote: |
Another thread
… rechecking things to hand write a correction entry, I was looking in 2 places, at once (old age, setting in) - Garwood suggests the new Electron formula introduced at engine number 1-0266000 and chassis number 1-0220472 these numbers were at the very beginning of 1951 - my apologies to JTG and everyone else... (the aging) z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
