markeaton Samba Member
Joined: July 09, 2013 Posts: 686 Location: Seacoast NH
Posted: Wed Jun 02, 2021 5:09 am Post subject: Shepherds hook - do most use them? Make or buy? |
All-
Do most use a shepherds hook steel vacuum line to their carburetor? Are they needed?
If so, I saw the video on how to make, but do any vw vendors sell them?
Thanks
-Mark |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Wed Jun 02, 2021 6:12 am Post subject: Re: Shepherds hook - do most use them? Make or buy? |
It's nothing fancy. You can simply loop the hose higher than the vacuum port or make one out of metal tubing. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Jun 02, 2021 6:53 am Post subject: Re: Shepherds hook - do most use them? Make or buy? |
Gotcha.... thanks |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24735 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jun 02, 2021 7:26 pm Post subject: Re: Shepherds hook - do most use them? Make or buy? |
Needed if one wants the vacuum advance not to fill with gasoline. Rubber diaphragm does not do well in the long term by being soaked with fuel. _________________ In Stereo, Where Available! |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jun 05, 2021 8:28 pm Post subject: Re: Shepherds hook - do most use them? Make or buy? |
From the 1960's the diaphragm is actually made of a speaker cone like paper- even more vulnerable.
I would say most do not know about them, yes they are needed, I've had NOS in the past and good used off and on and yes there are vendors that have them. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sat Jun 05, 2021 8:36 pm Post subject: Re: Shepherds hook - do most use them? Make or buy? |
There was an evolution to the line and not always in the shape of a shepherds crook.
Braukuche Samba Member
Posted: Sat Jun 05, 2021 8:41 pm Post subject: Re: Shepherds hook - do most use them? Make or buy? |
71 up with the push pull cans didn’t use them. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sun Jun 06, 2021 8:44 pm Post subject: Re: Shepherds hook - do most use them? Make or buy? |
From my experience the advance line was still a "shepherds crook" but the retard side was not. _________________ Roads Scholar &
Posted: Mon Jun 07, 2021 7:16 am Post subject: Re: Shepherds hook - do most use them? Make or buy? |
tasb wrote: |
From my experience the advance line was still a "shepherds crook" but the retard side was not. |
You know more than I, so I double checked looking at old brochures and you are correct, they used them even on the ones with the advance port located at 7 o’clock.
Guess what I am going to be doing this morning… _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Jun 07, 2021 7:27 am Post subject: Re: Shepherds hook - do most use them? Make or buy? |
What size metal line is common? Can a normal brake line work? 3/8" |
Posted: Mon Jun 07, 2021 8:10 am Post subject: Re: Shepherds hook - do most use them? Make or buy? |
markeaton wrote: |
2mm which is about .080" (80/1,000 of an inch).
3/8" is .375" (375/1,000 of an inch) _________________ In Stereo, Where Available! |
Posted: Mon Jun 07, 2021 8:12 am Post subject: Re: Shepherds hook - do most use them? Make or buy? |
Thanks..... to be clear, you are saying 2mm is the correct size and not the 3/8" |
Posted: Mon Jun 07, 2021 9:20 am Post subject: Re: Shepherds hook - do most use them? Make or buy? |
markeaton wrote: |
Exactly. _________________ In Stereo, Where Available! |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6594 Location: Houston, Texas
Posted: Tue Jun 08, 2021 1:33 pm Post subject: Re: Shepherds hook - do most use them? Make or buy? |
VW ones have nipples like this on the ends:
You will see aftermarket ones where they just trim a piece of tube off. _________________ www.vwnos.com [email protected]
