Thompson2 Samba Member
Joined: June 06, 2018 Posts: 659 Location: Portland, OR
Posted: Wed Jun 09, 2021 9:33 am Post subject: Oil for speedometer? |
I rebuilt the speedo for my bus and it turned out great but the needle has a bit of a bounce to it. I used a clock oil for it but I'm guessing it's a little too thick / sticky.
I've some searches and I've seen a lot of generic "use a lightweight oil" but no real specifics on type or, even better, brand recommendations aside from "mineral oil", but I've seen arguments against that too...
Anyone got info to add some clarity?
Cheers!
Michael |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Wed Jun 09, 2021 10:13 am Post subject: Re: Oil for speedometer? |
In most cases of needle bounce I've seen, it's generally the speedo cable that needs lube. It gets dry, binds, then wraps up a bit before breaking free. Other than that, I'd opt for a light silicone oil inside the speedo. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Tizian Samba Member
Joined: February 18, 2015 Posts: 383 Location: Hamburg, Germany
Posted: Wed Jun 09, 2021 11:03 am Post subject: Re: Oil for speedometer? |
Hi Michael,
I second this.
In most cases the cable is bent. Get yourself a new one.
Please avoid to use any sort of oil in your speedo. That’ll make it worse. It will end up in wrong reading because of different friction.
Eddy currents induce a force to the small aluminium bell which is attached to the needle by rotating a magnet inside the bell. If this rotation is not stable, the needle will jump.
If you would have problems with the needle bearing, I assume it would read completely wrong if not reading anything. But most probably it would not jump... |
Posted: Wed Jun 09, 2021 11:32 am Post subject: Re: Oil for speedometer? |
telford dorr wrote: |
In most cases of needle bounce I've seen, it's generally the speedo cable that needs lube. It gets dry, binds, then wraps up a bit before breaking free. Other than that, I'd opt for a light silicone oil inside the speedo. |
I should have mentioned that the speedo cable was replaced as well. Do they need to be oiled before installation? |
Posted: Wed Jun 09, 2021 11:34 am Post subject: Re: Oil for speedometer? |
Tizian wrote: |
I can give that a shot as well. It'll need to be cleaned out anyway, so I can retest with no oil. Any concerns about wear over time? |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Wed Jun 09, 2021 5:24 pm Post subject: Re: Oil for speedometer? |
I was unable to locate it for a pic, but I cut of the cable mount from a junk speedo and installed a zerk on the cut face. Then I use a grease gun to pump wheel bearing grease into the cable. If I have a used cable I just keep forcing grease through the cable until it looks clean.
I used to let ATF drip through it. That also worked well. It is a bit less viscous. So, I never really trusted it. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
