Portable Power Devices aka Solar Generator
Page: Previous  1, 2, 3
thebigben
thebigben is offline
PostPosted: Sun Jun 06, 2021 8:42 pm    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Anyone with the 720Wh battery tried fitting it under the bench? Also has anyone tried this? https://www.costco.com/.product.100716886.html
Seems like a good deal for 1400wh capacity + inverter + charge controller + cooling fans + MPPT controller + easy to resell down the line.
Ben
'85 2WD Westy w/ Peloquin TBD + 2.2 Subi (Kurt Vannegut)
thebigben
PostPosted: Thu Jun 10, 2021 10:39 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
I placed an order for the $700 Costco deal. Considering it is less than the price of an equivalent capacity Lithium Ion battery, seems like itís hard to go wrong.
I currently have two very large FLA batteries that are struggling to hold a charge, and Iíd like to add solar, so this was a great callout.
Will update on fit when I receive them next week. Thanks!
Ben
Howesight
Howesight is offline
PostPosted: Thu Jun 10, 2021 2:21 pm    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
"Portable Power Station"?!! Didn't we used to call these batteries?
It just bothers me that the manufacturers of these batteries with accessories are referring to them as "power stations" or similarly-misleading names. There are a lot of unsophisticated people who don't realize, until they buy the "power station", that they have to go home, plug it in, and only then have "power" in their "station". The marketing materials then use W/h to make the units appear to have more power than they do. All deep-cycle battery companies use amp/hours to allow apples-to-apples comparisons. Not so with Yeti, River, etc. It's not right.
Here's a real portable power station:
By comparison, here's a battery with a handle with attached inverter and accessories so that you can tell your envious friends that your 18-pound flashlight will definitely outlast the power in their wimpy REI headlamps.
Old technology in a wanna-be slick package with a handle on top.
It reminds me of when television manufacturers used to put a handle on top of a 50-pound TV and call it "portable". Fine for Ward Cleaver to move, not so much for June Cleaver. The Beaver? Forget it.
I'm sure it's a fine product, but wish the marketers would call it what it is - - a battery with a handle and gew-gaws.
'86 Syncro Westy SVX
djkeev Premium Member
djkeev is online now
PostPosted: Fri Jun 11, 2021 1:35 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
[img]https://www.thesamba.com/vw/gallery/pix/2186634.jpg[/img
[img]https://www.thesamba.com/vw/gallery/pix/2184138.jpg[/
I get your point, there is a terminology "break down".
These are a storage unit for electric, yes ...... a battery.
I initially scoffed at them just like you are.
Then I realized that I needed what they provide.
1) a clean, neat, organized and functional storage battery.
2) multiple power outlet designs
3) a 12v dc to 110 ac outlet
4) a solar controller
5) ability to power device while charging
6) multiple ways to charge
A) 110 ac shore power (very fast charge)
B) 12v dc vehicle cigarette lighter while underway
C) portable (or permanent mounted) solar panel while stationaryor underway
D) from another alternate power source. (Generator, stirage bank, etc, )
I have come to really like this unit, it isn't a lot of power and won't meet long term needs without a recharging source hooked up.
The portability you scoff at is absolutely perfect for my situation.
I am off this Sunday on a journey in the Prius and will take along my portable unit and electric TruckFridge.
Yes, the name is misleading but the concept fills a need in many peoples lives.
Is it fir extended stationary off grid boon docking without solar or constant travel?
No, it isn't.
Is it a fast easy solution for a day or two of light use without power input? Absolutely.
Dave
Ghia
Vanagon
Beetle
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Jun 11, 2021 2:18 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Dave, that seeming anomaly is because there is a small error in the TP41 label you showed.
They reversed the order of the DC amp draw.
It can run on 12/24 volts, either one.
On 12 volts it uses 3.8 amps, on 24 volts it draws 1.9 amps.
Mark
djkeev wrote:
I have my Dometic CF11 ......
I find it curious that this small 1.1 cf unit sucks 2.2 amps 30 watts at 12v
And
My big Truck Fridge TP41a sucks but 1.9 amps 45 watts at 12v
I guess the Wattage factors in?.......
Dave
WestyWanter
WestyWanter is offline
PostPosted: Fri Jun 11, 2021 3:34 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
so if I'm correct this is 120Ah of storage on top of 1200w peak inverter? plus solar charger? In theory if you wanted you could wire the van to have outlets/usb etc all terminate to under the bench seat then just drop in the device with its extra battery and plug those in then boom the van has power? + have inputs from either solar on roof or charge from alternator while driving...
120aH of Lipo battery storage for 700$?
jayinduluth
jayinduluth is offline
PostPosted: Fri Jun 11, 2021 8:12 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
I think your math is wrong, aH is watt-hours / volts, so 1440 / 28.8 = 50aH. There are more specs available on the ecoflow site -
https://ecoflow.com/products/ecoflow-river-pro-portable-power-station
85 Westy with 91 2.1L
crazyvwvanman
PostPosted: Fri Jun 11, 2021 10:43 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
This illustrates why having the Watt-Hour ratings can be a valuable plus for comparing overall storage capacities.
In the case of this product an amp-hour rating isn't straightforward.
Since the device in question has different output voltages available the amp-hours would be different for each voltage.
It appears the internal storage voltage is different from all the others as well.
Mark
ProspectiveOwnergon
ProspectiveOwnergon is offline
PostPosted: Mon Jun 14, 2021 12:40 pm    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Teardown of the ecoflow.
https://youtu.be/sDb0BaJ3NRQ
PostPosted: Tue Jun 15, 2021 3:40 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Great find! ^^
Saves me tearing it apart to see what is inside.
I've been using my EcoFlow for about two weeks now.
No surprises, it does exactly what .i wanted it to do and thought it would do.
It is REALLY NICE having refrigerator onboard on a daily basis for drinks and food.
The only downside is that I haven't yet wired in an ignition controlled lighter outlet so I can charge the EcoFlow while driving.
I also have a 110 v AC Shore power plug designed for boats that I want to mount on the Vans side panel behind the drivers door somewhere.
This will be handy for charging the unit without removing it from the Van or running an extension through a window at night.
I currently bring the EcoFlow in to charge it every few days.
All of this wiring needs to happen before I head West in the Fall.
Color me pleased, yes, I know that I could have more capacity for about the same money if I had DIY'd something. But this little package is just so portable and handy to have.
I'm not limited to using the refrigerator in only the Van.
In the short testing period to date, This has ended up being the ideal power solution for me.
I never liked the complexity or space my house power took up in my 86 Weekender.
(I did end up getting the additional battery making my EcoFlow River a "Plus" model.)
Dave
Ghia
Vanagon
Beetle
Abscate Premium Member
Abscate is offline
PostPosted: Tue Jun 15, 2021 5:26 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
The big difference between a boat through hull and a car isÖ the boat hull is non-conductive. Itís much safer to keep it simple and route a cord to a dry space like the license plate hatch, then use a system of tags ďremove before flightĒ to manage the cord application. You have to do that with a through hull anyway.
.ssS!
DuncanS
DuncanS is offline
PostPosted: Tue Jun 15, 2021 5:31 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Glad to hear it fits your needs so well. It should make the "Go West, young man" much more enjoyable.
Could this work for you?
S4VAGE
S4VAGE is offline
PostPosted: Tue Jun 15, 2021 1:48 pm    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
mine shows up tomorrow!
thebigben
PostPosted: Tue Jun 15, 2021 2:00 pm    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Same here. A bit disappointed capacity wise, but excited to see how long it can drive my TF49.
Ben
PostPosted: Fri Jun 18, 2021 3:42 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
A pattern is developing, I am getting four days of daily use.
10 - 14hours a day.
I shut it off at night and every morning it cools off the box and keeps it cool all day.
This system is until I wire in a lighter socket and a shore power plug.
Dave
Ghia
Vanagon
Beetle
thebigben
PostPosted: Mon Jun 21, 2021 9:08 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
..and Iím returning the battery back to Costco. The battery is really too small.
Itís also Lithium Ion, which generally doesnít last as long as a Lithium Iron battery. From what I understand, the units shipped through their kickstarter were Lithium Iron.
For the same price ($700), I ended up buying a 100ah LiFePO4 battery + RedArc Ignition Switched Charger with MPPT. I like the ability to easily add more capacity down the line, for just the price of the battery.
If you go the EcoFlow route, keep in mind you still need a battery separator for alternator charging (which is limited to only 10a with EcoFlow).
Ben
vegpedlr
vegpedlr is offline
PostPosted: Mon Jun 21, 2021 11:56 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Just tried out my new Bluetooth AC30 at Adventure Van Expo. It powered my mini rice cooker in a home test, and did really well powering my 35qt Dometic. Itíll work well until I wire I up my solar stuff. Itís nice to be able to move the power source around.
1985 Tintop 4 sp GW 2.3
Vanlife Geek
Vanlife Geek is offline
PostPosted: Mon Jun 21, 2021 12:50 pm    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
I went with a cheapo brand, Aligoo 300Watt Portable Power Station generator with 12V Car Jump Starter power bank, 266Wh lithium backup battery, Pure Sine Wave AC/DC outlet. It's on sale right now on Amazon for $159, https://amzn.to/35EFkpJ.
Even though I have two house batteries, sometimes when it's cloudy they don't get charged enough from solar, so this is my backup. I'm trying not to kill my AGM house batteries by running them down too low. It actually works great!
One feature I really like is the watt consumption readout on any device that is plugged in. For example, now I know my big "Endless Breeze" 12v fan uses 15 watts on low, 22 watts on medium and 32 watts on high. I always wondered how much some of the devices draw and now I know. My fridge uses about 70 watts during startup, but settles down to around 43 watts after a couple of minutes. It also will tell you how long it will last based on the current draw and how long it will take to charge based on current input.
One reason I chose this particular model is that it comes with an attachment to jump start the van should the starter battery become low over a long camp. I can use jumper cables from one of the house batteries (and have) but this is way easier. I experimented with using it to power my fridge and it could probably go for nearly a full day before it runs out of juice.
I did have to figure out a hack to keep it going when powering the fridge... it has an auto shutdown feature 60 seconds after no load is detected. Of course the fridge doesn't run constantly, so it would turn off between fridge cycles. To fix this issue, I discovered I could plug in my phone via USB and that would prevent the unit from shutting off automatically between fridge cycles, even when the phone is fully charged.
I always have my 2000w gas generator if all else fails. Overkill? Naw, I like my gadgets!
I just finished a two week camp and got to use it extensively and it worked like a champ. I'm not sure about other brands, but this one will function fine while being charged. I experimented with plugging it into a 12v receptacle to charge while the fridge was plugged into the unit and it worked fine and would still charge with the fridge load.
Anyway, I thought I'd share this inexpensive one for those that don't want to spend a fortune and don't have huge power requirements.
Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
1972 Bug (Last year you could buy a new one for under $2,000)
1965/66 Bug (2 bugs from a junk yard combined to make 1 functional bug)
1959 Bug (Pre Gas Gauge Era)
thebigben
PostPosted: Mon Jun 21, 2021 4:01 pm    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Now you have my wheels turning. I think I might try adding one of these portable battery packs to my house battery setup under the rear bench. At least to the charging portion.
It would be nice to have a small reserve that is also removable.
Ben
S4VAGE
S4VAGE is offline
PostPosted: Sun Jul 04, 2021 8:02 am    Post subject: Re: Portable Power Devices aka Solar Generator Reply with quote
Woke up this am to my first real test of the eco flow pro running my 63qt ARB. 20 hours on 120 and the eco pro is down to 35%. Fridge was in shade, opened 3-4 times. Based on my fridge and my conditions, Iím going to estimate that this might stretch me into 1.5 day of fridge power.
Not sure if this is a success or not. I really didnít know what to expect in real use.
Sadly I canít get solar to charge it. Any ideas? I bought the mc4 to Zamp adapter to plug into the unit. My zamp just flashes the ďbattery not detectedĒ b01 alert. Plugged the panel into my van and confirmed panel is working. 🤷‍♂️
Cheers
Page 3 of 3
