pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Thu Jun 10, 2021 9:15 am Post subject: Rear Wheel well rust repair panels |
I am looking for the small lower outer rust repair panels for the rear wheel well area of a late bus. They supposedly go between the body seams and the wheel well. Those made by Klokkerholm appear to be the only ones available here in Canada. No Autocraft or KlassicFab. I am not looking for the large one piece panels.
I would like to hear from anyone who has installed these specific panels. How was the fit? My experience with Klokkerholm has not been great on other vws.
Thoughts and comments. |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Thu Jun 10, 2021 12:42 pm Post subject: Re: Rear Wheel well rust repair panels |
assume you mean both front and behind the wheel arch. i just bought the whole panel ($40), and then cut off what I needed for that rear arch area. it was cheap enough to buy the whole thing and I will use the front end to do the same. the actual arch is solid, so no need to replace it. it also gives me a nice big piece of leftover, flat, straight metal, to cut into any kind of repair pueces I need.
it is indeed Klokkerholm, but since the curve is not very complex, had little trouble making it fit as needed.
Edit:
Current BD prices.
As you can see, they do offer just the corner at small money. I did not see the forward piece listed seperately, but even if it was $15 as well for that one, for another $10, you get the whole panel.
Where it says its european made=Klokkerholm _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson
Posted: Thu Jun 10, 2021 6:45 pm Post subject: Re: Rear Wheel well rust repair panels |
Those panels are $100+ Canadian here and depending where you buy them, shipping may be extra and for us here in BC add 12% sales tax.
Good to know that the fit is not too bad. The Klokkerholm beetle ones I bought bordered on junk. At one point I made some of what I needed. Just less frustration and time.
I just need to get at this as the van is pretty much rust free except for a few small spots. It's 42nd birthday is coming up in a couple of weeks.
Thanks for the feedback. |
Posted: Fri Jun 11, 2021 3:30 am Post subject: Re: Rear Wheel well rust repair panels |
its $100 to get your bus tightened up. Bite the bullet and do it. When the work is done, and the rot is gone, your standing value will be 10x what that panel cost you. And even if you dont care about the value as much ( like me), its nice to look down on it and know its better than it was. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
