What parts break in a 002 3 rib
J@ngo
J@ngo is offline
PostPosted: Sat Jun 12, 2021 8:54 am    Post subject: What parts break in a 002 3 rib Reply with quote
When you put v6’s on a bus trans what commonly breaks?
69 baja 1600 daily
2017 custom sand rail from Cali with mid engine 2110
Vanapplebomb
Vanapplebomb is offline
PostPosted: Sat Jun 12, 2021 9:13 am    Post subject: Re: What parts break in a 002 3 rib Reply with quote
Same parts with any motor.
It’s more about how much power you put to the ground than how powerful the engine is, and shock loading the transmission, aka, hopping the wheels or landing on the gas.
Reverse gear is a major weak link, so baby it in reverse. Generally the next things to go are first gear or the side/spider gears in the differential.
1800 Type 4 Berrien 295
J@ngo
J@ngo is offline
PostPosted: Sat Jun 12, 2021 10:24 am    Post subject: Re: What parts break in a 002 3 rib Reply with quote
Thanks
69 baja 1600 daily
