1958-Beetle Samba Member
Posted: Sat Mar 03, 2018 3:23 pm Post subject: Re: 36 hp with crankshaft seal leak |
thank you KTphil for your advice ill check on those |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Mar 05, 2018 8:01 am Post subject: Re: 36 hp with crankshaft seal leak |
Here's a pic of the seal installed even tho it is one of those nasty dual lip seals, (thanks to hazetguy)
You can see it does not sit flush with the case.
Read here about having to trim the double lip seal
http://www.stoddard.com/99911302950-nla.html
Here's one I've used with good luck
http://www.stoddard.com/99911302950.html _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
dougnlina Samba Member
Joined: January 19, 2016 Posts: 245 Location: San Francisco, CA
Posted: Fri Jun 11, 2021 3:57 pm Post subject: Re: 36 hp with crankshaft seal leak |
Reviving this thread a bit as I have a main seal leak on a new seal. It is a "dual Lip" seal and I was reading over on the 356 forum that the dual lip seals will leak and the Porsche guys are cutting the second lip off of them. Is this my likely problem? Are folks cutting the second lip off so it doesn't burn and fail?
see: http://forum.porsche356registry.org/viewtopic.php?f=1&t=44170
Thanks, Doug _________________ "Olive" a '60 Ragtop Beetle
"Grover" a '87 Syncro Poptop 1.8T |
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Fri Jun 11, 2021 6:32 pm Post subject: Re: 36 hp with crankshaft seal leak |
When I refreshed my 36 hp, I originally installed a dual lip seal that I got from Wolfsburg West. Even though I was very careful I still messed it up when I installed my flywheel. So after I pulled the engine again I ended up buying a "cheapo" single lip seal from Autozone since I didn't want to wait for a new seal from WW. Over 10,000 miles later it's still nice and dry! _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
vwoldbug Samba Member
Posted: Sat Jun 12, 2021 10:13 pm Post subject: Re: 36 hp with crankshaft seal leak |
Wolfsburg West has orange - brown flywheel seals that work good. What color seals are you using. |
Posted: Sun Jun 13, 2021 3:04 pm Post subject: Re: 36 hp with crankshaft seal leak |
I dont remember what color the seal in there is, but I'll be pulling it next weekend. For what its worth, it was purchased from WW.
DP _________________ "Olive" a '60 Ragtop Beetle
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Tue May 24, 2022 9:52 am Post subject: Re: 36 hp with crankshaft seal leak |
quick question...
I am re-setting the end float... engine was built, not by me, WITHOUT the paper gasket and only 2 shims... 0.32mm and 0.34mm total =0.66mm
The paper gasket is currently unavailable in the UK. I found one in my shed and punched extra holes in for the 8 dowels and I plan to use this.
Obviously this will crush down from the 0.2mm thickness it has right now... but will still allow me to put in 2 shims @ 0.24mm and 1 @ 0.34 total 0.82mm-0.15(est?) =0.67mm with some adjustment depending on the crush of the paper gasket, and the correct 3 shims.
so... as I only have one gasket, and can't get any more, I will have to reuse it after the first test fit. Will this be ok??? _________________ 1954 L227 Type 113
1964 L31 Type 265 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24732 Location: Olympia Wash Rinse & Repeat
Posted: Tue May 24, 2022 10:07 am Post subject: Re: 36 hp with crankshaft seal leak |
pig-pen wrote: |
so... as I only have one gasket, and can't get any more, I will have to reuse it after the first test fit. Will this be ok??? |
Only if you put the flywheel on with the same orientation to the crankshaft will you have a good chance of that. Otherwise, could be.....
Easy enough to find some gasket material to make another from. Heck over here one can use phone book paper. _________________ In Stereo, Where Available! |
Posted: Tue May 24, 2022 1:37 pm Post subject: Re: 36 hp with crankshaft seal leak |
Eric&Barb wrote: |
pig-pen wrote: |
Easy enough to find some gasket material to make another from. Heck over here one can use phone book paper. |
yep. however stamping 4 holes in with having the original 4 for reference made me nervous enough, let alone cutting the big holes too... I do have some much thicker (0.6mm) coming in the post. maybe they will crush down a lot and work well. _________________ 1954 L227 Type 113
1964 L31 Type 265 |
