16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sat Jun 12, 2021 2:19 pm Post subject: Brickwerks Tail light boot Install |
So 6 months ago I ordered 2 sets of Tail light wiring rubber boots, they been kicking around the bench and I decided to install them in my truck and my van today. Here's some of the highlights.
These pictures may be out of order, but you can figure it out. I cut the boot off with a pair of scissors. Less damage than a knife or blade.
Some of the wires had been tapped for trailer wiring and had open wound in them, I shrink wrapped all of those and then shrink wrapped the entire loom.
Those old boots were not holding and degraded. Pulling the connectors is standard business. They are now sealed up and secure the entire job per light was about 1/2 hour.
May not be the most important fix I've made but it is really nice now, hopefully the A/M boots last as long as the original sdid.
.thesamba.com/vw/gallery/pix/2187169.jpg[/img]
[img]https://www.thesamba.com/vw/gallery/pix
/2187166.jpg[/img]
_________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Sun Jun 13, 2021 12:13 pm Post subject: Re: Brickwerks Tail light boot Install |
Quote: |
How does one pull these? |
Looking straight at the connector plastic case and at each pin you will see an open side and a closed side. On the close side insert a small thin screwdriver and push down while pulling the wire out of the plastic case. Make sure to take a picture or take note of the order of wire before taking them out. |
16CVs Samba Member
Posted: Tue Jan 16, 2024 11:44 am Post subject: Re: Brickwerks Tail light boot Install |
Does anyone know how to contact these guys. They have no Phone and their "Contact us" button does not work.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
not more rust! Samba Member
Joined: July 08, 2022 Posts: 4 Location: Llandudno - UK
Posted: Tue Jan 16, 2024 1:42 pm Post subject: Re: Brickwerks Tail light boot Install |
[email protected]
You'll normally get a quick response in my experience. |
mtnhome Samba Member
Joined: July 17, 2010 Posts: 500 Location: Summit County, CO
Posted: Tue Jan 16, 2024 3:28 pm Post subject: Re: Brickwerks Tail light boot Install |
GoWesty has both the boots in stock and a kit with two boots and replacement terminals. I have a kit for when it gets warm enough to replace mine. _________________ '84 Westy, '93 Subaru ej22 and Subarugears 5speed
Build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=763098&highlight= |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
