ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Fri Sep 15, 2017 11:39 pm Post subject: What is the T7a/6 wire for ? ( black/red) 1985 |
Hello folks!
I'm converting an 1985 Westy from 1.9L WBX to 1.9L M-Tdi.
I have a connector in the connectors black box that I believe is called T7a ( the same one that has the wires for the coolant level sensor).
For the life of me I cannot find and trace the Red/black wire from that round connector on the Bentley. I can find from 1 to 5 but not number 6 wire.
The engine end of that wire is gone with the wiring harness and engine onto another van, so I don't know what it was...
I'm using a pig tail from a 2.1L harness and I know the black/red wire is going to the ignition relay box long the red B+.
Thank you for your help
Shootz! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Sep 16, 2017 4:31 am Post subject: Re: What is the T7a/6 wire for ? ( black/red) 1985 |
I just went through the T7's and from my notes on 1988-91 it is going to the Digifant ECU Terminal #1. This was on page 97.206
I know it is later then your '85, but seeing how they try to follow through during the years it might be going to the same location?
1987-91 notes:
(I do know what #4 is, just haven't written it down yet.) _________________ This free advice is worth exactly what you paid for it.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sat Sep 16, 2017 11:00 am Post subject: Re: What is the T7a/6 wire for ? ( black/red) 1985 |
Thank you guys!
You are correct, 1984 didn't have a T7a, I found that name from my notes when I did a Subie conversion in a 87. Probably why that connector/wire doesn't exist in the Bentley.
So what I did is follow what you said about the ignition switch. It goes there on the 1986 and up. If I go on the 1985 diagram, I can find the wire but only at the ignition switch, but it goes nowhere
I don't understand the function of the 2 wire plug for the relay box in the engine bay for a 2.1L : one is B+, the other would be a IGN+ ? ( after contact +) ?
The van is in pieces or I would just try it and see....
Thanks again _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Sat Sep 16, 2017 11:12 am Post subject: Re: What is the T7a/6 wire for ? ( black/red) 1985 |
That red/black goes to the wbx FI harness to tell the FI system that you are trying to start the engine. It comes from the circuit 50 wiring. Circuit 50 is from the ignition switch starter contact to the starter solenoid. The exact path varies by model/year.
Mark
ALIKA T3 wrote: |
Thanks again |
Posted: Sat Sep 16, 2017 1:28 pm Post subject: Re: What is the T7a/6 wire for ? ( black/red) 1985 |
crazyvwvanman wrote: |
Mark
ALIKA T3 wrote: |
Thanks again |
Thanks Mark!
I did notice the solenoid has the same wire color, and on the Subie conversion notes I had it is a the solenoid wire at T7a-6 for a 1987.
Makes sense.
So it's just a temporary contact then? I cannot use it for anything.
I'll take the pin out with the wire then _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
leecat Samba Member
Joined: September 13, 2012 Posts: 773 Location: Regina
Posted: Sun Jun 13, 2021 4:14 pm Post subject: Re: What is the T7a/6 wire for ? ( black/red) 1985 |
This thread was immensely helpful, guys! That T7a/6 almost drove me nuts too just now. I know it's an ancient thread, but what happens if the FI system is NOT told that you are trying to start the engine via momentary power to that line?
Update - apparently nothing! Van starts and runs just fine with the red/black wire cut. Oy vay, Volkswagen! You drive me nuts sometimes! |
