JupiterTheEurovan Samba Member
Posted: Sun Jun 13, 2021 6:17 pm Post subject: Won’t start, lights and radio turn on, no clicks! |
I have a Eurovan 2003 that only gives me trouble. I am now stuck in Wyoming during a limited time road trip. It’s Sunday so no mechanic is open until tomorrow. The weird thing is it was working last 1000 miles no problem. I dispersed camped last night. For the first time I tried shifting to 1,2,3rd gear in prep for the pass. It was hard to pull the shifter into 1st and had to really yank. I then switched it to D and continued on the freeway. I pulled over for a viewpoint and ate some breakfast. I then tried to turn the car on and it would not turn the engine. The only click is the one disengaging the shifter. No clicking of the starter. The car is in park and I can shift the car through the gears. The lights and radio turn on. The engine is silent. I have limited tools.
What should I check first? Fuses? Starter? Ignition?
I opened the shifter box and everything looks ok. |
EVCSNOW Samba Member
Posted: Sun Jun 13, 2021 7:17 pm Post subject: Re: Won’t start, lights and radio turn on, no clicks! |
Try starting the Van in neutral |
Posted: Sun Jun 13, 2021 8:06 pm Post subject: Re: Won’t start, lights and radio turn on, no clicks! |
Tried to start on neutral, does not start. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Mon Jun 14, 2021 3:44 am Post subject: Re: Won’t start, lights and radio turn on, no clicks! |
If the linkage is messed up it’s almost certainly the safety switch is also messed up. You will have to disassemble it and jump it to get rolling.
That’s not a you tube-able process, so if you don’t know that subsystem or lack tools and time it’s flat bed time. _________________ .ssS! |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Mon Jun 14, 2021 7:16 am Post subject: Re: Won’t start, lights and radio turn on, no clicks! |
Regarding the multi-function switch on the transmission, does the display on the instrument cluster accurately report every gear selected on the shifter? _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
Posted: Mon Jun 14, 2021 10:28 am Post subject: Re: Won’t start, lights and radio turn on, no clicks! |
Passenger seat rotated forward? _________________ 2002 EVC |
SocalSteve Samba Member
Joined: February 08, 2019 Posts: 6 Location: Southern Cal
Posted: Tue Jun 15, 2021 7:18 pm Post subject: Re: Won’t start, lights and radio turn on, no clicks! |
Maybe broken ignition switch/cylinder. The tab broke on my lock cylinder, which is a common problem. My electricals worked but wouldn't turn over the engine. _________________ 01 EV Weekender
74 2002Tii |
