Steering column upper bearing replacement 1973 bay
maz-o
maz-o is offline
PostPosted: Mon Jun 14, 2021 5:15 am    Post subject: Steering column upper bearing replacement 1973 bay Reply with quote
Howdy.
I've lost the steering column spring, and the collet is cracked, both of which are hard to source aftermarket, so I figured I'd replace them with this new bearing:
211415585A
However I can't find any installation instructions.. Is it a straight fit into the steerer tube or what? Do I need a press or other specialty tools?
The original bearing looks to be inside the steerer tube and not removable? Is this right? Is there a way to pull it out of there if needed? It still works fine, maybe there is some slight play, but the main reason I need the replacement is that the spring and retaining ring are missing.
Thanks in advance!
maz-o
maz-o is offline
PostPosted: Wed Jun 23, 2021 3:08 am    Post subject: Re: Steering column upper bearing replacement 1973 bay Reply with quote
i've tried to search it but came up with naught so far. anyone?
can it be as easy as knocking down the new bearing so it sits "on top" of the old one?
Alexzeat
Alexzeat is offline
PostPosted: Fri Jan 13, 2023 2:19 pm    Post subject: Re: Steering column upper bearing replacement 1973 bay Reply with quote
How did you assembly it? I need to know
Volkswagen T1 Kombi 1500 1963
Volkswagen T2 Pickup 1600 1974
