CeReal Samba Member
Joined: August 07, 2018 Posts: 2 Location: Dallas, Oregon
Posted: Mon Jun 14, 2021 8:50 am Post subject: Temp Sensor Gauge |
Is there a gauge that will work with the cylinder head temp sensor on fuel injected engines? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jun 14, 2021 9:11 am Post subject: Re: Temp Sensor Gauge |
Welcome,
Not that I'm aware of, the gauge could be quite simple, but the location of that sensor doesn't give an accurate depiction of real time head temps, it's purpose is just to tell the FI system if the engine is cold, or warmed up fully. By the time a gauge started to react the actual head temps could easily exceed danger levels, that's assuming you are pushing it so hard you could do it, CHT isn't usually a problem in stock Beetles that are tuned properly. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
CeReal Samba Member
Posted: Tue Jun 15, 2021 9:40 am Post subject: Re: Temp Sensor Gauge |
Makes sense. Thanks. |
clockworkbox Samba Member
Joined: July 12, 2020 Posts: 286 Location: Williamsport, PA
Posted: Fri Jun 25, 2021 10:07 am Post subject: Re: Temp Sensor Gauge |
busdaddy wrote: |
Welcome,
Not that I'm aware of, the gauge could be quite simple, but the location of that sensor doesn't give an accurate depiction of real time head temps, it's purpose is just to tell the FI system if the engine is cold, or warmed up fully. By the time a gauge started to react the actual head temps could easily exceed danger levels, that's assuming you are pushing it so hard you could do it, CHT isn't usually a problem in stock Beetles that are tuned properly. |
Thanks! The heads I bought have the threads for the temp sensor and I thought it might be useful to know the head temp but now I see that isn't a viable option. _________________ '69 Beetle (pieces)
Learning the hard way is still learning... |
RWK Samba Member
Posted: Sat Jun 26, 2021 7:10 am Post subject: Re: Temp Sensor Gauge |
Its possible, you would need to know weather it's a type J or K thermocouple,
This source has read out that would read either. The temp sender location on stock head is for the fuel Injection system to help it adjust, that temp may not be relevant. You could try the gage and see what the temps are at that location, I would guess, 150-200
http://thesensorconnection.com/egt-probes/meters-d...-peak-hold _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Sat Jun 26, 2021 7:23 am Post subject: Re: Temp Sensor Gauge |
It's not a thermocouple, it's a thermoresistor, the Ohm's to ground change with temperature.
Слава Україні! |
