brownbus2 Samba Member
Joined: October 13, 2020 Posts: 244 Location: Roanoke, VA
Posted: Sun Jun 13, 2021 5:52 pm Post subject: shiftrod set screw wire |
What gauge wire is used for the set screw on shift rod coupling? Braided? _________________ formerly known as Brown_Bus
1976 FI Marino Yellow Westy |
busdaddy Samba Member
Posted: Sun Jun 13, 2021 5:59 pm Post subject: Re: shiftrod set screw wire |
.020-.040" solid wire, meant for the job lock wire is best but mechanics wire or any other thinnish wire like rebar tie wire will do. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jun 13, 2021 6:08 pm Post subject: Re: shiftrod set screw wire |
Thanks! _________________ formerly known as Brown_Bus
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Jun 13, 2021 7:21 pm Post subject: Re: shiftrod set screw wire |
Most don’t have any lock wire so anything you can find is better than nothing. That is unless you wire it backwards _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun Jun 13, 2021 7:52 pm Post subject: Re: shiftrod set screw wire |
A medium strength Loctite works fine |
Cap10323 Samba Member
raygreenwood Samba Member
Posted: Sun Jun 13, 2021 8:39 pm Post subject: Re: shiftrod set screw wire |
Thanks for the part #!
I have an order going in to MC this week. I have numerous things that need a lock wire. I have been cheating...and buying shitty stainless picture hanging wire from Ace hardware. OK in a pinch but one twist too far and its gone.
Ray |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Jun 14, 2021 11:01 am Post subject: Re: shiftrod set screw wire |
raygreenwood wrote: |
Ray |
Pick your poision... https://www.aircraftspruce.com/catalog/appages/safetywire.php |
Posted: Mon Jun 14, 2021 3:02 pm Post subject: Re: shiftrod set screw wire |
ToolBox wrote: |
Ray |
Yep....its one of those things that I just need to order a spool of to have on hand. If you dont have in on hand ...when you finally do need it you will never have it.
The shift linkage on my 412...has two grub screws that get hammered so hard because the parts are flexible...that no locktite will ever work. The screws came drilled for wire from the factory....and I never have it in the toolbox...so I always have to scrounge
This thread was just a good reminder at the right time to just get some!
Ray |
Posted: Mon Jun 14, 2021 6:39 pm Post subject: Re: shiftrod set screw wire |
aeromech wrote: |
Most don’t have any lock wire so anything you can find is better than nothing. That is unless you wire it backwards |
So, not using the lock wire wont be an issue? _________________ formerly known as Brown_Bus
Posted: Mon Jun 14, 2021 6:42 pm Post subject: Re: shiftrod set screw wire |
brownbus2 wrote: |
aeromech wrote: |
So, not using the lock wire wont be an issue? |
Maybe, maybe not. I'd always wire it myself but locktite would works fine or you can roll the dice. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Mon Jun 14, 2021 8:35 pm Post subject: Re: shiftrod set screw wire |
brownbus2 wrote: |
aeromech wrote: |
I forgot to use the lock wire on mine, on my first test trip out it came loose and I lost all ability to shift. Luckily the screw didn’t fall out and all I had to do was screw it back in and I was good to go. Once I got home I used some safety wire. Why chance it over $11 for some safety wire? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Mon Jun 14, 2021 9:26 pm Post subject: Re: shiftrod set screw wire |
ivwshane wrote: |
brownbus2 wrote: |
aeromech wrote: |
I forgot to use the lock wire on mine, on my first test trip out it came loose and I lost all ability to shift. Luckily the screw didn’t fall out and all I had to do was screw it back in and I was good to go. Once I got home I used some safety wire. Why chance it over $11 for some safety wire? |
Been there. I lost a pointed grub screw from my shift linkage somewhere between Atlanta and Birmingham Alabama many years ago...because I figured I could get away with it....with no wire.....thank God for the bucket of spare parts in the trunk. Ray |
Posted: Tue Jun 15, 2021 12:20 pm Post subject: Re: shiftrod set screw wire |
yeah, I figured it was needed. _________________ formerly known as Brown_Bus
