dagimp Samba Member
Posted: Fri Jun 11, 2021 1:56 pm Post subject: Fog light reverse light grounding question |
I'm installing both an external rear reverse light as well as a rear fog light both mounted to the bumper. Really just for looks. They're the rectangular VW/Hella type but I powder coated them black. They're all mounted and wired up but I'm having issues grounding them. They have the single power cable and grounded through the chasis. The back of the light where the bulb fits into is the ground but when I install it into the powder coated casing, it doesn't ground. Even when the lenses are screwed in, it's not properly grounding. Anyone have any experience with these types of lights? Thanks. _________________ Buck
1973 Orange VW Thing, "Otto". |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Sat Jun 12, 2021 5:50 am Post subject: Re: Fog light reverse light grounding question |
Assuming your external light is mounted with a threaded stud, make a ground wire with ring terminals at each end; one for the threaded stud, and one for one of the M10 bumper mounting bolts.
Good luck, Mondshine |
FJBLF Samba Member
Posted: Mon Jun 14, 2021 3:44 pm Post subject: Re: Fog light reverse light grounding question |
I hope this helps, Sucribe to my chanel if you like. Mine take the ground from the post where they bolt on to the bumper.
_________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
dagimp Samba Member
Posted: Tue Jun 15, 2021 6:44 am Post subject: Re: Fog light reverse light grounding question |
FJBLF wrote: |
Thanks Safari. When you say yours take the ground from the post, does this mean that you add a wire from the post to a bumper mounting point, like Mondshine suggests? _________________ Buck
FJBLF Samba Member
Posted: Tue Jun 15, 2021 7:18 pm Post subject: Re: Fog light reverse light grounding question |
Thanks Safari. When you say yours take the ground from the post, does this mean that you add a wire from the post to a bumper mounting point, like Mondshine suggests?[/quote]
Not quite. The lights on the video, which, by the way, are the correct lights for a 181,have only one wire coming out. That is the positive wire which goes to the transmision switch, which is fed from the coil positive (Ignition Switch).
The post of the light, grabs negative from the body, inside the the light there is already a wire that hooks the bulb socket to the metal body of the light which of course is connected to the post.
Basically you just wire the positive and the ground is pre-wiered inside the ligth.
I hope that helps _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
dagimp Samba Member
Posted: Wed Jun 16, 2021 6:15 am Post subject: Re: Fog light reverse light grounding question |
FJBLF wrote: |
Thanks Safari. When you say yours take the ground from the post, does this mean that you add a wire from the post to a bumper mounting point, like Mondshine suggests? |
I hope that helps[/quote]
Interesting. So my lights do not have the wire inside the body of the light that connects to the bulb socket. I have original ones that likely were too old to have that feature. These grounds go from the bulb socket which screws into the body of the light. But my guess is that due to corrosion on the bulb socket piece as well as the non-conductive powdercoating on the light body, the ground is poor. _________________ Buck
