Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Mon Jun 14, 2021 6:59 am Post subject: Rust Goop. |
Hi guys have any of you used this product? I want to use it on my pans that have just a little surface rust, before I paint them with POR-15. The instructions say to put it on the surface let it sit and then wipe it off, a little later the instructions say it can also be rinsed off with water. The body is still on the pan my question is can this be used without rinsing the pans with water? Thanks.
KTPhil Samba Member
Posted: Mon Jun 14, 2021 9:02 am Post subject: Re: Rust Goop. |
I think we used to call this "naval jelly." Assuming so, these notes are on the web: "Naval jelly does this by converting rust to a soluble iron compound that you can rinse off with water. It's effective because its main ingredient is phosphoric acid, which is one of the few acids capable of doing this. Other stronger acids corrode the metal and end up creating more rust."
So I would recommend rinsing. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Mon Jun 14, 2021 9:16 am Post subject: Re: Rust Goop. |
I used this. You brush it on and it converts the rust back to metal and encapsulate it. Once it dries, it forms a hard surface and you apply paint over it.
Just wear a respirator and be well ventilated.
https://www.3m.com/3M/en_US/p/d/b40071580/
_________________ Glenn
Member #1009
#BlueSquare |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Mon Jun 14, 2021 12:53 pm Post subject: Re: Rust Goop. |
I would suggest you read the instructions for using Por-15 over again.
My understanding is that it is best applied right over the rust. Clean the metal too much and it may not adhere or work as intended. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Mon Jun 14, 2021 4:10 pm Post subject: Re: Rust Goop. |
Thanks guys for the info, I will check with the POR-15 people for details. |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Mon Jun 14, 2021 5:04 pm Post subject: Re: Rust Goop. |
The second step of the POR15 does the same job as the Permatex product you show. You don’t need the Permatex if you use all three steps of the POR15 system. However if you have loose and flaking rust you should remove this by sanding or wire brushing.
The steps are:
1. Wash with a degreasing solution
2. Convert the rust and provide a key for the paint
3. Encapsulate the rust with a moisture cured polyurethane
I think MS and KBS use similar systems. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Glenn Mr. 010
Posted: Mon Jun 14, 2021 5:09 pm Post subject: Re: Rust Goop. |
I've used POR15's Marine Clean and One-Step, it depends on how bad the rust it. If the metal is solid with little flake, use the Marine Clean. If it's pitted use the One-Step... it dries and leaves a VERY hard surface. _________________ Glenn
Member #1009
#BlueSquare |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1475 Location: Westfield, MA.
Posted: Tue Jun 15, 2021 3:21 am Post subject: Re: Rust Goop. |
I also would re read the POR directions. This stuff is SUPER picky about application, and IMO just way way overhyped. I've had way better luck with ospho followed by epoxy primer and 2K black topcoat. Again with ospho directions must be followed. |
splitjunkie Samba Member
Posted: Tue Jun 15, 2021 4:00 am Post subject: Re: Rust Goop. |
I fail to see how encapsulating rust is superior to removing it.
If it is truly just surface rust I don't see how using this product would prevent any paint from adhering. I would use a wire brush before rinsing the gell off to make sure you get as much of the rust as possible. If there is any worry about the paint having enough "tooth" to adhere to, then sand the area after it has dried. _________________ Chris
Glenn Mr. 010
Posted: Tue Jun 15, 2021 5:40 am Post subject: Re: Rust Goop. |
splitjunkie wrote: |
I fail to see how encapsulating rust is superior to removing it. |
When you remove it you make the metal weaker.
Converters leave the metal stronger. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jun 15, 2021 12:31 pm Post subject: Re: Rust Goop. |
Thanks for the great ideas guys, I am going with the POR-15. They offer a kit that has the all 3 items in it to complete the job, I used just straight POR-15 "paint" when I did my bus 5 or 6 years ago and it came out great. Thanks. |
