MikeCorbitt Samba Member
Joined: March 18, 2021 Posts: 65 Location: Corvallis, OR
Posted: Sun Jun 13, 2021 12:57 pm Post subject: Rostra cruise module mounting locations |
Recently purchased a Rostra universal control module (250-1223) for my recently purchased 1990 2WD, 2.1 waterboxer with manual gearbox.
For those who have completed a non-GW install, where did you mount the control unit?
Thanks for any feedback on this. Getting ready to embark on a trip from Oregon to Ohio in 11 days and hope to get this installed and working beforehand.
Mike |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Sun Jun 13, 2021 3:50 pm Post subject: Re: Rostra cruise module mounting locations |
Are you asking about the location of the servo or the switches? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
oldskewlsk8ter Samba Member
Posted: Sun Jun 13, 2021 5:30 pm Post subject: Re: Rostra cruise module mounting locations |
My van is Subaru powered so this may not work for you, but maybe you could move it to the opposite side. I mounted the control unit in the rear area where the stock air intake box used to reside. Never had any issues with that aspect of the system. The only issue I’ve ever had with mine has been VSS related. _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
Posted: Sun Jun 13, 2021 5:35 pm Post subject: Re: Rostra cruise module mounting locations |
Mine is an Audiovox (vacuum, not electromagnetic) but the component layout may be similar - I put the servo behind the right rear tail light. That's on a Digijet though which has nothing else going on in that space. |
Posted: Sun Jun 13, 2021 5:42 pm Post subject: Re: Rostra cruise module mounting locations |
Ahwahnee, I'm talking about the servo.
Dave, I've reviewed many of your past posts on this. Most appreciative of all your info and insights. I'm new to the forum and the van so excuse my lack of correct nomenclature and my ignorance at this point. I've been scoping out the back seat, so thanks for confirming this as a possible good option.
Mike |
Posted: Sun Jun 13, 2021 5:44 pm Post subject: Re: Rostra cruise module mounting locations |
The back right side of mine has the air intake. Looking around the immediate area of the engine compartment, there are few options without getting too close to the coil. |
jimf909 Samba Member
Posted: Sun Jun 13, 2021 9:04 pm Post subject: Re: Rostra cruise module mounting locations |
FWIW, here's a pic of the Rostra mounted for a Bostig...
_________________ - Jim
Abscate wrote: |
Posted: Mon Jun 14, 2021 7:00 am Post subject: Re: Rostra cruise module mounting locations |
MikeCorbitt wrote: |
The back right side of mine has the air intake.,, |
So does mine, that is where the servo sits. The cable comes out through a hole in the cardboard piece that covers the area (same one that has a big hole for the air snout. |
Posted: Mon Jun 14, 2021 5:24 pm Post subject: Re: Rostra cruise module mounting locations |
To mount the control unit in the back right corner, did you have to extend your a few of your wires to reach your switch control and the brake positive/negative wires? My wiring falls several feet short. |
Posted: Mon Jun 14, 2021 6:47 pm Post subject: Re: Rostra cruise module mounting locations |
The length of the Rostra cruise cable and the wiring harness does not provide many options where the control module can be located. Have most of you that purchased Rostra units in the past had to extend your wiring harnesses? Trying to locate my control module in the engine bay is not an option for the length of my wiring harness. |
Posted: Mon Jun 14, 2021 6:59 pm Post subject: Re: Rostra cruise module mounting locations |
Yes. The white cable sheath in the photo below is the Ancor six (?) conductor cable that extends the harness from the engine bay to the dash on my van. Something like this:
https://www.amazon.com/InstallerCCTV-Alarm-Cable-2...NrPXRydWU=
Abscate wrote: |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3092 Location: ABQ NM USA.... Except when not
Posted: Mon Jun 14, 2021 7:04 pm Post subject: Re: Rostra cruise module mounting locations |
jimf909 wrote: |
this is where mine is
re: wire extension, IDR if I got a extension from Rostra directly or if I used speaker wire or towing light strand....it wasn't a bit deal in any case _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Mon Jun 14, 2021 9:19 pm Post subject: Re: Rostra cruise module mounting locations |
Thanks for the replies. These are all appreciated and helpful. Nothing like being a newbie. |
Posted: Tue Jun 15, 2021 1:49 am Post subject: Re: Rostra cruise module mounting locations |
Oh, put your van year and engine in your sister we we know what we are referencing
Thigh my answer advice or correct with my subi,. I more recall with the 1.9 I had it on the rear muffler shield _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Tue Jun 15, 2021 6:06 am Post subject: Re: Rostra cruise module mounting locations |
Thanks for the note about including my van particulars. Took me a while to figure out how to do that. _________________ 90 Westy; 2.1 waterboxer; 4 spd; 102K miles, cold a/c |
Posted: Tue Jun 15, 2021 6:18 am Post subject: Re: Rostra cruise module mounting locations |
vanis13 wrote: |
Oh, put your van year and engine in your sister... |
Sometimes I think auto-correct is intentionally incorrect: signature to sister? Steve Jobs is spinning in his gravlax. _________________ - Jim
Abscate wrote: |
Posted: Tue Jun 15, 2021 7:59 am Post subject: Re: Rostra cruise module mounting locations |
I was able to decipher. I used to blame Bill Gates for auto-correcting what should not have been changed. _________________ 90 Westy; 2.1 waterboxer; 4 spd; 102K miles, cold a/c |
a2wolfsburggli Samba Member
Posted: Tue Jun 15, 2021 9:08 am Post subject: Re: Rostra cruise module mounting locations |
Mike |
I have the same kit. Also got the short rostra cruise stalk and mounted it on the steering cover forward and above the turn signal stalk.
Which switch did you get?
I followed the GW install instructions for mounting and cable actuation and wiring as much as possible. I was planning to mount in the engine compartment. Evaluated GW's install and it's quite ingenious actually. It's FAR easier to mod the throttle cable cover and be "ok," with the somewhat reverse actuation that GW uses than to extend the wiring all the way to the back of the van. At least IMHO.
I know Dave struggled with this install method. I had the exact opposite experience. I believe he also has an auto and wasn't getting a kick down he was looking for. I have a manual. Plus...Dave...I say this lovingly....you tend to over think and over complicate things when you're installing. (Ouch...sorry...flame suit on...lol.)
With mounting the unit under the dash, I can hear the cruise gears grab when I engage it which is a bit satisfying in knowing it's good to go. (It's silent otherwise.)
Here is my thread on dip switches. If you need any help or advice please hit me up. I've installed 3 of these on 3 different vehicles. 2 of them being motorcycles. So I have a good amount of experience with them.
https://www.thesamba.com/vw/forum/viewtopic.php?t=736663 _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense |
Posted: Tue Jun 15, 2021 10:24 am Post subject: Re: Rostra cruise module mounting locations |
I purchased the dash mount switch. At the time, I was wanting the RF bus it's no longer available and I did not think the cruise stalk was an option for my year. Duh.
There were a few reasons I didn't go with the GW version, but now I'm thinking lesson learned. And I paid more money for it. Ouch.
I had previously read your dip switch settings and modeled mine after yours for the most part.
Where did you get your GW instructions? Off their website, or just following their video? _________________ 90 Westy; 2.1 waterboxer; 4 spd; 102K miles, cold a/c |
