tristanblue Samba Member
Posted: Thu Jun 10, 2021 12:03 pm Post subject: 6V engine / starter in 12V transmission ?? |
So I have a `66 ghia vert that has (what I am told) the 12V option which was apparently available in ghias. The trans is set up for 12V with a 12V starter and bushing and large bell housing opening. The vehicle came with no engine. I am making a rat driver out of it.
I have a great running low mileage rebuilt 6V 1200 engine from a `65 beetle I would like to use in this car. Trying to figure out the easiest way to do the install. I was considering a couple options but had a couple questions.
-the engine has a 6V flywheel on 40hp 64mm crank. Can a later 12V flywheel be used on this engine and swap rest of engine bits to 12V?
-If I decided to go 6V and leave the engine alone, can I run a 6V starter in a 12V trans? This would be kind of a reverse what is usually done. I have seen a very thin bushing to convert but heard these get torn up quickly and can ruin the trans case. Does anyone make a 6V starter with a 12V size armature tip for smaller bushing in 12V cars? I heard at one time someone on the samba was selling 6V starters modded to fit into 12V transmissions. Anyone know who that was? |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Thu Jun 10, 2021 2:48 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
If this is a long-term solution and you’re not planning to disassemble the engine, you can have a 12 volt ring gear put on the 40hp flywheel. I had rimco do one for a 36hp a few years ago and it turned out nice. _________________ 1965 Beetle sedan
Click to view image |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Thu Jun 10, 2021 4:24 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
tristanblue wrote: |
-the engine has a 6V flywheel on 40hp 64mm crank. Can a later 12V flywheel be used on this engine and swap rest of engine bits to 12V? |
Any 12v flywheel you're likely to come across will be an o-ring type. To fit this type of flywheel to your engine will require the flywheel be machined to fit the stepped crankshaft -- it's not a simple bolt on. Obviously the endplay will need to be checked and adjusted when swapping out a flywheel, which also brings with it the problem of finding suitable 40hp size endplay shims.
-If I decided to go 6V and leave the engine alone, can I run a 6V starter in a 12V trans? |
Yes, a 6v starter can be used in a 12v trans if an appropriate sized conversion bushing is used or you open up the bushing hole in the trans to the size found on 6v units, a standard 6v bushing can then be installed. Another option is to track down one of the uncommon self-supported 6v starters.
Matthew's suggestion to swap out the ring gear may well be your best option. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Thu Jun 10, 2021 7:08 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Converting the 40hp to 12V looks like it would be too much of a hassle considering this engine is fully restored and already 6V. I think keeping it as-is 6V and modifying a 6V starter to work with the trans.
I know thing 12-6V bushing conversion does not really work well due to thickness of the 12V bell housing opening and then opening up the bushing hole. It usually breaks through the casting or if you use the super thin conversion bushing it just wears out in a few months and starts eating away the trans material. Seen that happen years back.
The guy solved the problem and purchased a rebuilt 6V starter here on from a Samba member who turned the tip if the armature down on a lathe and it fits right in the 12V starter bushing. Worked perfectly. Would like to find out who that was if they are still around and doing this, he doesn't remember.
I could possibly just take a starter apart myself and have a machine shop turn it down but always seems that ends up being a cluster f-ck |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Jun 10, 2021 10:27 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
If installed corrcorrectly and greased, conversion bushing will not wear out any sooner than the stock set up _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Thu Jun 10, 2021 11:16 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Teeroy wrote: |
If installed corrcorrectly and greased, conversion bushing will not wear out any sooner than the stock set up |
Sorry but that is absolute hogwash. This is NOT the thicker bushing going from 6V to 12V this is the paper thin one going from 12V to 6V. They fail because they are far too thin for proper strength, they will last a little while but always fail down the road. These are so thin you can actually crush it between your fingers.
Here is one that has failed
Teeroy Samba Member
Posted: Thu Jun 10, 2021 11:25 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
I'm aware of how thin they are, ive been messing with these cars for over 40yrs, never had one fail. Not trying to cause an arguement, just trying to give you an easier solution to a custom/expensive starter or flywheel swap. _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Fri Jun 11, 2021 4:13 am Post subject: Re: 6V engine / starter in 12V transmission ?? |
Wait - Isn’t the car 12 volt? I’d think it’s more of a hassle converting the car than the engine. Plus the 12V system is far easier to live with. _________________ 1965 Beetle sedan
Posted: Tue Jun 15, 2021 2:45 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Teeroy wrote: |
I'm aware of how thin they are, ive been messing with these cars for over 40yrs, never had one fail. Not trying to cause an arguement, just trying to give you an easier solution to a custom/expensive starter or flywheel swap. |
My father ran (retired) a restoration shop since 1988 and dealt primarily with VWs. He is my source of info on this. He said those bushings are far to thin and can will fail far too soon. He had tried them on 2 different occasions and both failed down the road and cost him extra work and labor because of these bushings. After that he started using the rebuilt, machined starters from a vendor here on the samba they worked perfectly with never an issue or return. If VW would have thought bushings that thing would work they would have probably done so saving on materials/cost.
Problem is he does not recall this vendors info and apparently is no longer advertising in classifieds. I do not want to waste time doing a half assed empi repair with that paper thin bushing I am just going to take a couple 6V starters I have apart and have armatures machined locally. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Tue Jun 15, 2021 2:54 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
funny that you come here to ask, then diss someone suggesting something because of 3rd hand knowledge from your father. I agree, Never had a problem with one of those conversion bushings, I would even suggest a saxomat starter but whatever, sounds like you have the end all source of knowledge at your finger tips, no need to ask here |
Posted: Tue Jun 15, 2021 4:35 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Erik G wrote: |
No what is funny is people like you who think just because someone gives an answer on here it is the RIGHT way to do it. Lotsa folks post lotsa answers on here that are wrong way to do things. But hey if the bushing works for you guys have at it! Lots folks use crap ass Empi fix it shit and lotsa folks moan cry how there VWs break down all the time.
I know lotsa cry babies on here with the cancel culture going on. Everyone has to be right I guess. If you don't like my posts and replies then just keep on moving next time you see my name. |
Zundfolge1432 Samba Member
Posted: Tue Jun 15, 2021 7:06 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Teeroy wrote: |
You are exactly right and this was shown to me years back. How elegant and simple just turn down the thicker 6 volt shaft to 12 volt spec. So simple nobody thinks of it. The real thin conversion bushing is complete crap and will fail. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue Jun 15, 2021 7:29 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
when you get your armature back check for these 3 things.
1. make sure the shop didnt get or leave swarf or oil residoo on the armature.
2. make sure they didnt chuck up the outside of the armuture bare and scuff it.
3. check to see how good the surface finish is and how well it fits into the bushing. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Tue Jun 15, 2021 8:04 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Why would anyone want to mess with bushings or turning the starter support shaft when you can buy an auto stick starter that does not have a support shaft and requires no bushing for $50 at Orielleys with a lifetime warranty?
There are hard ways of doing things and there are smart ways of doing things. |
Posted: Tue Jun 15, 2021 8:09 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
hes using a 6v flywheel and no one makes a self supporting vw starter with the 6v gear.
if he had a 12v flywheel it would be a different story.
i actually just bought one of those for my car from O reillys.
the first one i bought was crap. complete mushy dog crap. the paint was flaking off, it came to me rusty, the two bolts holding the motor housing on were no joke loose and the threads came stripped.
so i took it in for exchange and what i got was GOLD. nice durable paint, NEW style selenoid, Torques fasteners all over the place(not flat heads), and it spins over real fast.
this is for the ultima brand. idk about the $180 bosch ones. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Tue Jun 15, 2021 8:12 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Ahhh, I stand corrected. Continue doing things hard way. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Tue Jun 15, 2021 10:22 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
AirHead1966 wrote: |
Because if you actually took the time to actually read the thread and educate yourself a 40hp with a 64mm crank has a 6V flywheel not a 12V and NO you can not easily just swap a 12V flywheel on to a 64 mm crank. So a 12V auto stick starter is useless. |
Posted: Tue Jun 15, 2021 10:34 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Thanks but nope, I already contacted this fellow before posting and he is not the guy. This seller had never heard of the mod and does not do it nor have the ability to.
It was around 2000 when my dad was last in contact with the guy, so he may not even be alive anymore. The last one he used was on a `51 Sunroof split that was on a `67 pan he restored. Had a custom dual carb 36hp set up in it.
Posted: Tue Jun 15, 2021 10:43 pm Post subject: Re: 6V engine / starter in 12V transmission ?? |
Chickensoup wrote: |
3. check to see how good the surface finish is and how well it fits into the bushing. |
Great tips thanks, I will do!
Zundfolge1432 wrote: |
Thumbs up! |
