Jason37 Samba Member
Posted: Sun Sep 20, 2020 1:12 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Praying for no miss shifts. 🙏 |
vwfye Samba Member
Posted: Sun Sep 20, 2020 5:36 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Haha, lots of missed shifts.
But... 9.42 1/8 was the best e.t. For a sweep the floor engine on 87 octane and 1850lbs, I'm ok with it. Stock T3 gearing too... _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwfye Samba Member
Posted: Mon Sep 21, 2020 10:52 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Officially track retired... cruiser time now. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Nov 21, 2020 12:23 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
Started taking measurements for the cruiser engine mounting plate. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat May 22, 2021 8:12 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Long overdue modification today.
Since the speedster's beginning, the large engine cover has been held on by bolts. This made removal for servicing slow and replacemenf slow. It worked well, but was annoying. Fast forward 25 years or so and now it is held by hood pins. 30 seconds to remove! The sad part is... I have had a set of hood pins hanging on a hook for more than a decade. Doh! _________________ 64 No'back Speedster "Pearl"
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Sun May 23, 2021 11:16 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
I guess that means the red Notch must be pretty close to track ready. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sat Jun 12, 2021 4:26 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
That's a new one for me... built a new shifter for my midengine notchback! Now to tear it back apart, paint and lube the different parts and install it for real! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Jun 13, 2021 5:25 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye Samba Member
Posted: Mon Jun 14, 2021 12:48 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
After adjusting the cable lengths a bit, the shifter slack seems to be minimal now. Next is sorting the throw on the slave cylinder. The new unit, is shorter than the failed one. Grrr... no wonder the clutch action is on/off. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Wed Jun 16, 2021 12:03 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Today is the day to re-engineer how the slave cylinder is mounted. Maybe, just maybe, I will be satisfied with the result... _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Nov 04, 2021 10:17 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
Well, things are taking a new turn. I have, in the works, the possibility of adding a lift off hard top to the car after years of dreaming of doing it.
This has now turned from a 'long term' project to an 'extremely long term' project, but if it works out like I see it in my mind's eye, it will be worth it! _________________ 64 No'back Speedster "Pearl"
Posted: Thu Nov 04, 2021 5:13 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
This has now turned from a 'long term' project to an 'extremely long term' project, but if it works out like I see it in my mind's eye, it will be worth it! |
Yeah, that's Rob's plan too. But he has so many irons in the fire, that it'll be years before that happens. Right now he still has an Acura to strip and give him the needed front end parts for his K-20 swap on his 98 Civic. Then he can concentrate on finishing up the 98, so he can go back to working on the "Pile".
It doesn't help when he plans to do something, only to find out his wife already had something else for them to do. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Nov 05, 2021 12:27 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
I hated the lift off roof on my Corvette and installed a soft top that I loved for its versatility! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vwfye Samba Member
Posted: Fri Nov 05, 2021 12:41 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
and? _________________ 64 No'back Speedster "Pearl"
Posted: Fri Nov 05, 2021 1:24 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
You guys should build convertible soft tops not permanent monstrosities. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Sat Nov 06, 2021 1:11 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Mike Fisher wrote: |
You guys should build convertible soft tops not permanent monstrosities. |
I tried that a few times on my own car, but it never worked quite like I wanted it to. I ended up parting the car out to myself for the most part, and decided to put my time and energy into my sunroof car instead. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sat Nov 06, 2021 7:03 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Well1, if it doesn't work, it doesn't. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Nov 07, 2021 1:57 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
24 hour bomber run coming in a couple weeks to obtain my roof. Woot! _________________ 64 No'back Speedster "Pearl"
Posted: Mon Nov 08, 2021 10:33 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
24 hour bomber run coming in a couple weeks to obtain my roof. Woot! |
That sounds good! _________________ https://imgur.com/user/FisherSquareback/posts
vwfye Samba Member
Posted: Mon Nov 08, 2021 1:11 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Well, this will be an adventure! I now have to add a side trip to Vegas. So, Roseburg to Hesperia to LV to Roseburg is the plan. Oh, in 3 days max. The things we do for these cars! Doh _________________ 64 No'back Speedster "Pearl"
