Jim's Neptune Blue 68 Doublecab
Page: Previous  1, 2, 3, 4, 5, 6, 7
deepcflea
deepcflea is offline
PostPosted: Mon Dec 28, 2020 5:35 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
Don't know what I'm more jealous of... your barnfind... all your "junk" sitting around... your work barn... Great DC!!
1978 Bay Window Double Cab (1600cc) - Marilyn
https://www.thesamba.com/vw/forum/viewtopic.php?t=...005b041ddd
Formerly owned VW's
1983 Westfalia
1956 Oval Ragtop
1967 Bug
1970 Ghia
1969 Buggy
jakokombi
jakokombi is offline
PostPosted: Mon Dec 28, 2020 8:58 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
"Now I have way too much junk sitting around here..."
It makes it easier for us to find you on Google Earth Very Happy.
Nice work Jim! Looking forward to seeing you guys in 21!
70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja
earlybayjim
earlybayjim is offline
PostPosted: Mon Dec 28, 2020 11:46 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
Thanks Jack! Same here!
1971 Chianti Red Westfalia x2
1985 Westfalia
1984 tintop
SamboSamba22
SamboSamba22 is offline
PostPosted: Wed Dec 30, 2020 10:41 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
Looking good Jimbo.
Sam
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
Boesen
Boesen is offline
PostPosted: Wed Dec 30, 2020 8:01 pm    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
We need to have a winter hang out day Jim. Well once I can get anywhere off my street due to this snow/Ice crap from last night. Hope to see you soon.
1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa
earlybayjim
PostPosted: Fri Jan 08, 2021 6:50 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
SamboSamba22 wrote:
Looking good Jimbo.
Sam
Thanks Sam!
Come camp in my garage! You can sleep in the vanagon or the 71 if you don't want to bring Jude!
1985 Westfalia
1984 tintop
earlybayjim
PostPosted: Fri Jan 08, 2021 6:54 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
These really are the perfect work bench. Hoping to start digging in to her some soon...
1985 Westfalia
1984 tintop
earlybayjim
PostPosted: Fri Feb 05, 2021 11:05 pm    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
I found some time to work on the truck. The engine needed to come out for a minimum of push rod tube seals and a new generator. I figured I should give it all a good cleaning and a quick detail (is there such a thing???) while it is out. Also planning on throwing a new stock muffler on, cleaning and patching up the heater boxes, and a new battery tray too.
This is the first vw I have worked on with the cooling flaps and thermostat all in place. All these extra parts are new to me!
I have driven 3,369 miles since I first got the truck.
Engine out
For some reason a D-bolt was used on the driver side top? It was so painful to reach this and took me way longer than it should of because of 1 stupid bolt.
Looks like the customized the tin to get the oil cooler tin to fit...
I'm embarrassed to show that this motor mount completely separated once the pressure was off. Yikes.
Lots of rubber dust? Maybe the pulleys are out of alignment? Im thinking of replacing the pulleys with a new set...
Making a mess
1985 Westfalia
1984 tintop
deepcflea
PostPosted: Sat Feb 06, 2021 8:16 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
That D bolt Shocked Oh man, how is that even possible to tighten that up there?
Nice finding a complete un-molested engine, I got lucky on my DC, overall it was pretty complete.
Have fun with the engine!
Formerly owned VW's
1983 Westfalia
1956 Oval Ragtop
1967 Bug
1970 Ghia
1969 Buggy
earlybayjim
PostPosted: Thu Feb 11, 2021 8:34 pm    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
My forward most piece of engine tin was hacked up, I checked my stash for the elusive "71 only" tin... no luck so I decided to combine it with a beetle tin as others have done. This should work right? I'm not well versed in beetle parts so if something looks off please let me know.
Ouch
Separated the 2 pieces by drilling the spot welds all the way through.
Clamped up and ready for welding.
1985 Westfalia
1984 tintop
earlybayjim
PostPosted: Thu Feb 11, 2021 9:32 pm    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
I decide to fix a piece of the sled tin in the mean time.
The mounting tab the connects to the block has seen better days.
I hang on to left over patch panel chunks for jobs like this...
My tig welding needs a bit of work, but I think it will hold. 😅
One more piece of the seemingly endless tin puzzle...
1985 Westfalia
1984 tintop
cdennisg
cdennisg is offline
PostPosted: Thu Feb 11, 2021 9:39 pm    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
It will work just fine. That is pretty much exactly what VW did to make the 71 tin.
nothing
earlybayjim
PostPosted: Fri Feb 12, 2021 5:44 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
Cool. Im going to weld it up tonight after work.
I just remembered I forgot to post a picture of the #1 cylinder spark plug threads! They look pretty good from this side! Lucky me
1985 Westfalia
1984 tintop
earlybayjim
PostPosted: Wed Jun 16, 2021 2:05 pm    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
Finally had some time to upload a few pictures.
My heater boxes needed some repair.
I wanted my truck back on the road in a reasonable amount of time, so I wasn't trying to make these a show piece or anything... I ended up filling in the worn out areas where the donut seals. Ill probably replace them with a flange eventually.
VHT silver looks pretty good
Most of my tin was powdercoated black.
Its came together nicely. I pulled the heads and replaced the push rod tube seals, but I didn't take any pictures of that greasy project.
1985 Westfalia
1984 tintop
nynone4
nynone4 is offline
PostPosted: Thu Jun 17, 2021 8:34 am    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
Nice! Looks like it's coming together.
>>Looking for any and all Vic Williams, Peoria Illinois dealership items.<<
otiswesty
otiswesty is offline
PostPosted: Fri Jun 18, 2021 9:39 pm    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
Nicely done!
1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy
earlybayjim
PostPosted: Sun Jun 20, 2021 1:42 pm    Post subject: Re: Jim's Neptune Blue 68 Doublecab Reply with quote
Muffler is on.
I temporarily patched the battery tray last year. It was time to do it right.
I should have taken some pictures after seam sealer and paint but I was to excited to put it back together.
Engine is back in. New fresh air hoses and stuff.
Bumper on.
Out enjoying it as much as posible!
1985 Westfalia
1984 tintop
Page 7 of 7
