robotrophic Samba Member
Joined: March 08, 2009 Posts: 88 Location: San Francisco
Posted: Thu Jun 17, 2021 3:07 pm Post subject: Spindle Install |
Hi all,
I just finished bolting up my new disc brake assembly from Airkewld.
The assembly is a little heavy and unruly... and getting it to mate up to the trailing arms is kind of a pain by itself, let alone that the ball joints are squirrely and are uncooperative...
Does anyone have tips, cheats, suggestions?
Bottom one first (bolted), then jack it up to meet the top one?
My knuckles are now bare, and the assembly is still sitting on the floor.
Thanks for any ideas you may be able to throw at me. Pictures and/or videos would be amazing.
thanks!
robo. |
yellrhd Samba Member
Joined: April 02, 2006 Posts: 144 Location: Okinawa Japan
Posted: Thu Jun 17, 2021 4:37 pm Post subject: Re: Spindle Install |
Not sure this reads like you have the whole brake assembly installed on the spindle and then you're trying to install it.
The best and least ungainly way would be to install just the spindle to the ball joints and then add all the brake parts. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Thu Jun 17, 2021 5:16 pm Post subject: Re: Spindle Install |
Are these for a stock type 3 front beam? Or an airkewld modified type 1 air beam? Just asking as it does make a difference which parts you're using. You might want to post up some pics of the spindles and beam/trailing arms you're using. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Thu Jun 17, 2021 6:10 pm Post subject: Re: Spindle Install |
yellrhd wrote: |
Agreed.
When I've installed spindles - I've attached the spindle to the upper ball joint first, then used the commonly-available "spring plate compressor" tool (with tabs welded onto the ends to fit on the Type 3 trailing arms) to squeeze the arms together, then slowly release the tension while lining up the lower ball joint. _________________ 1988 Ford Festiva L
1965 Honda 50 "Super Cub"
2016 Miami Sun Trike |
Posted: Thu Jun 17, 2021 6:15 pm Post subject: Re: Spindle Install |
ok!
thanks for the tips.
I did end up removing the caliper and rotor.
My trick: I used some super heavy duty washers tapped into the spindle clamps to spread it open a hair, it worked really well. I then pressed the bottom joint in first using the floor jack and a block of wood.
Once the bottom was set, clamped, and still on the jack, I used a large c-clamp to press in the top one.
took five minutes. |
