RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Thu Jun 17, 2021 11:59 am Post subject: Rear heater valve |
Which direction is "no heat"? Bottom of the lever forward or toward the motor? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Thu Jun 17, 2021 12:15 pm Post subject: Re: Rear heater valve |
Pretty sure it is the forward location of the valve access "hole" in the cabinet, pushing it back lets the flow through. I have to dig in my back seat box later today, my PO wrote the directions on the top of the cover... If I find I have mislead you, I will edit this. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
harvgwen Samba Member
Joined: February 11, 2021 Posts: 160 Location: British Columbia, Canada
Posted: Thu Jun 17, 2021 12:33 pm Post subject: Re: Rear heater valve |
Bobbyblack may be correct but my memory says the opposite. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
British Columbia, Canada |
Posted: Thu Jun 17, 2021 3:26 pm Post subject: Re: Rear heater valve |
Pic, on toward front, from PO's days
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Thu Jun 17, 2021 5:14 pm Post subject: Re: Rear heater valve |
Yes forward is on. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Posted: Thu Jun 17, 2021 6:56 pm Post subject: Re: Rear heater valve |
Thanks for checking. I'd do the obvious thing, run the engine, turn on the blower, and be enlightened. At the moment, our Westy's grounded while I do some "getting ready for the next road trip" projects. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
jlrftype7 Samba Member
Posted: Fri Jun 18, 2021 1:57 pm Post subject: Re: Rear heater valve |
I'm no help since I switched over to the GoWesty Valve version and never turn off the Rear Heater Core coolant flow. I could, probably should,,,, but I don't..... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
