kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Fri Jun 18, 2021 11:30 am Post subject: Re: Gas in oil |
LancA2C wrote: |
Any suggestions would be appreciated. |
To test for diaphragm leakage, all you have to do is connect the input fitting of the (removed from engine) pump to some
container of gas held above the fitting. A small funnel that you can fit a hose over the bottom of, for instance. Work the
operating lever of the pump a few times till
gas starts emerging from the output. This ensures the upper diaphragm chamber is filled with gas.
If there's a leak, it will start running out the vent hole in
the bottom side of the diaphragm chamber. Contrary to the assertions of many here, gas will not
leak down into the lever chamber (and eventually into the crankcase if the pump was installed) unless
there's an absolute flood of gas thru the diaphragm. So, if your pump was operating and you didn't get
a bunch of gas running onto the top of your engine, you can forget the pump diaphragm as a source
of the gas in your oil.
VW installed a version of the "non-rebuildable" fuel pumps with a fuel cutoff valve on some Type 1 vehicles, but not
in the '71 busses. There might be one for sale in the classifieds here. Failing that, I would suggest getting a rebuilt
stock Pierburg "square-top" fuel pump from one of the rebuilders who advertise here on thesamba.com, because
they have a built-in fuel cutoff valve which is designed to eliminate slow leakage of fuel from the tank into the
engine, which is likely the cause of your gassy oil. _________________ '67 bug: seized by the authorities
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Tue Jun 22, 2021 1:46 pm Post subject: Re: Gas in oil |
LancA2C wrote: |
Not sure if I'm in the right place.
I've got a '71 Westie that was sitting in the bush for 25 yrs. It's now up and running , the problem I'm having is fuel in the crank case. After installing a new
stock carb. , it's been driven about 50 miles. My feeling is that the diaphragm in the pump is the source.
Bentley claims you can't access the diaphragm in these pumps so they have to be replaced. My question is : is there a procedure to bench test the pump to determine if that is the problem? I've drained the oil and puled the pump It is the original and it would be nice to keep it in service.
If you pull the pump and the grease has been washed out of the foot area, pretty safe to assume the diaphragm is shot and its leaking into the case. I have run into this quite a bit and just had it happen on my 65 bug. Checked the oil and it was about 1/2 qt high. Pulled the pump and some of the grease was gone. Pump replacement and oil change...all good. _________________ D-Dubya Manx clone - 63 Short pan,1914.
