maplesyruplover Samba Member
Posted: Fri Jun 18, 2021 8:53 pm Post subject: Turning engine by hand, clunk |
Hello all. I just picked up a beetle and as I turn the engine over I hear a clunk noise. The engine turns over fully but between this position it makes a noise.
Last edited by maplesyruplover on Fri Jul 23, 2021 12:39 pm; edited 1 time in total |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat Jun 19, 2021 12:01 am Post subject: Re: Turning engine by hand, clunk |
You said the motor turns over but it doesn't! Other than about 1/8 of a turn.
The last time I heard this sort of noise was when assembling the engine and the conrod was not connected and when the crankshaft was turned it hit the loose conrod. It is a very heavy steel on steel knock. Not a steel to aluminium knock if one of the valves was in the wrong position and hit the piston when the engine was turned e.g. if camshaft has been installed incorrectly.
Has the engine ever run? Has it ever turned over more than this?
Sounds very mechanical to me so whatever you do, do NOT try and start it up until you find out. If it were me, I'd pull the engine and heads and see if there is any obvious evidence of metal to metal contact. If the heads come off and the knock is still there, then you need to split the case.
But wait for other experts to chime in. This is just my diagnosis. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3847 Location: San Jose, CA
Posted: Sat Jun 19, 2021 1:57 am Post subject: Re: Turning engine by hand, clunk |
Yeah, the way you've worded it is a bit confusing. When you say "fully," are you saying that it will in fact turn round and round and round several rotations, but only at that particular angle it makes that sound?
Maybe it's just the tinny speaker on my phone, but it sounds more like a screwdriver shank rapping sheet metal, not a clunk.
This is curious |
Kthomas Samba Member
Joined: January 23, 2021 Posts: 256 Location: North Carolina
Posted: Sat Jun 19, 2021 5:11 am Post subject: Re: Turning engine by hand, clunk |
Maybe something under valve cover hitting valve cover ? That’s bizarre |
Posted: Sat Jun 19, 2021 6:58 am Post subject: Re: Turning engine by hand, clunk |
I should clarify. The engine was last run in 2003. It turns over fully without any problems and has compression. The video shows that in this position as I turn the engine it makes this clunk noise. It cannot be felt when turning the engine.
Sorry for any confusion. |
dougnlina Samba Member
Joined: January 19, 2016 Posts: 246 Location: San Francisco, CA
Posted: Sat Jun 19, 2021 7:31 am Post subject: Re: Turning engine by hand, clunk |
I think what you are hearing is cam whip. What is happening is the pressure from one of the valve springs is putting a side load against a cam lobe by pushing on the valve train when that valve train has an open valve. This in turn causes the cam to rotate slightly against other components in the gear train and valve train. It is very subtle and sounds almost like a wet, light, tick or click you could make with your tongue. If that is what it is, it is normal and not preventable.
It is also more noticeable when engine is dry, as it is easier to hear the lash being taken up.
You normally can't feel any resistance when it happens but you can feel a very slight bump _________________ "Olive" a '60 Ragtop Beetle
"Grover" a '87 Syncro Poptop 1.8T |
Posted: Sat Jun 19, 2021 8:38 am Post subject: Re: Turning engine by hand, clunk |
I like this theory ^^^
Does it make the same noise on every rotation? Or every OTHER rotation? Remember, the engine has to rotate 360° twice to run each cylinder through their full cycles, i.e. the cam needs two crank rotations to make its way around once, so it's actually doing different things with different valves through those TWO crank rotations. |
Posted: Sat Jun 19, 2021 8:51 am Post subject: Re: Turning engine by hand, clunk |
What I suggest you might be hearing is a click of backlash as the pressure from the valve spring, pushing against the lifter goes over the tip of the cam lobe and causes the cam to go from loading one side of the cam gear tooth to the other side of the cam gear, this is common on opposed engines that "share" cam lobes for multiple cylinders. It is kind of tough to tell for sure that this is what it is from the video, one way to check is to pull the rocker arms off and see if it still makes the noise without the valve spring pressures.... _________________ "Olive" a '60 Ragtop Beetle
rcooled Samba Member
Joined: September 20, 2008 Posts: 2506 Location: Santa Cruz, CA
Posted: Sun Jun 20, 2021 2:44 pm Post subject: Re: Turning engine by hand, clunk |
I've encountered something like this once before. It turned out that one of the bolts fastening the timing gear to the cam backed out slightly and was hitting a boss on the rear of the oil pump housing. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Sun Jun 20, 2021 9:41 pm Post subject: Re: Turning engine by hand, clunk |
I have gone through all the suggestions. The noise is still heard with the rockers disconnected. When cylinder 3 plug is removed, it disappears. I ran the motor and there is no knocking. Can it be the rod hitting the case.
The engine appears to be a 40hp with a vintage empi 1600 stroker kit & ram air zenith carb.
My thinking is that the case wasn't fully machined and it rubs.
Posted: Sun Jun 20, 2021 11:11 pm Post subject: Re: Turning engine by hand, clunk |
maplesyruplover wrote: |
I ran the motor and there is no knocking. Do you mean it runs perfectly fine under it's own fuel and spark and it doesn't make any unusual sounds at all?
Or does it continue to make that clapping sound?
Can it be the rod hitting the case. No. If you've actually run the engine, the rod hitting the case would've resulted in disastrous consequences long ago.
My thinking is that the case wasn't fully machined and it rubs.What? The Rod? Rubbing on what? Again, no, any interference at rotating engine speeds would have disastrous consequences. |
It's an odd phenomenon, but probably has a perfectly logical explanation
You never really answered my questions regarding crank angle, and just when it makes the noise throughout a total of two full crankshaft rotations. But short of completely clear explanations from you, I'm deducing that it's got something to do with pressure buildup during the compression stroke on #3. Something amiss with #3 wrist pin or rod bearings come to mind, but you said "I ran the motor and there is no knocking" so that essentially rules those out.
Knowing crank angle now is important because the highest chance of any internal rod contact on #3 would be on the driver's side of the case, and it would happen on every rotation.
Again: does it do it on every rotation of the crank? Or only every other rotation of the crank? If every rotation, then contact somewhere internally could be happening, but I just don't see how it can run fine without any knocking (cuz that's what you said) and not literally grenade at high engine rotation speeds if there were in fact some sort of internal contact.
If it only does it on every other rotation of the crank, then that jibes with the fact that you removed the #3 plug and thus removed "compression" from the equation, and that helps narrow it down. (A rod knock?)
So, a worn/loose rod bearing, some foreign object inside the #3 chamber, a wrist pin issue, (contact?), all of these are possibilities, I suppose, but it doesn't seem to make sense that it runs perfectly fine without any knocking. |
splitjunkie Samba Member
Posted: Mon Jun 21, 2021 6:42 am Post subject: Re: Turning engine by hand, clunk |
Sounds like a bad rod bearing on number 3. Could also be that one or both of the rod bolts have loosened which will cause excessive clearance. It doesn't take that much excess clearance to cause a knock.
If you haven't changed the oil, drain it into a perfectly clean container and check for metal flakes and fragments.
At a minimum I would strip the number 3 side down to the cylinders and pull the number 3 cylinder and check the rod bolts and for any excess clearance.
If I am correct, and you continue to run the engine, you will have a catastrophic failure sometime in the near future. If it is actually one of those old EMPI kits, I would be even more cautious due to the value of those parts. _________________ Chris
Posted: Mon Jun 21, 2021 4:43 pm Post subject: Re: Turning engine by hand, clunk |
I think you should consider the things Busstom has said re crank angle.
Does the knocking occur at the same rotation of the crankshaft?
You can get a template you can print out on the web for a VW pulley that you attach onto the pulley. Then measure the angle at which the "clunk" happens. You can then determine which valves etc are in operation from documentation on valve opening sequence, even if you think it is related to No 3 piston. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Wed Jun 23, 2021 7:07 am Post subject: Re: Turning engine by hand, clunk |
Don't take my word for it. Removing spark plug wires one at a time will do the same thing by eliminating the force against the crankshaft caused by the gas igniting. Removing the plug also removes all compression so you are putting the least amount of force on the crank,and thus the rod bearing.
https://www.carboncleaningusa.com/connecting-rod-bearings
How can we diagnosis the connecting rod bearing ?
Plug Wire Removal
1. One way to identify the cylinder connected with the faulty rod bearing is to open the car hood and pull out all spark plug wires one by one.
2. After removing each wire, turn on the engine and check if the knocking sound still persists.
3. If the sound is eliminated, this means that the cylinder from where the plug wire was just removed has a faulty bearing on its connecting rod.
http://corvaircenter.com/phorum/read.php?1,630718 _________________ Chris
Posted: Wed Jun 23, 2021 1:21 pm Post subject: Re: Turning engine by hand, clunk |
I just watched the video over again several times. That noise doesn't sound like a moving part that suddenly contacts something solid. And it doesn't seem like it's preventing the engine from turning over like you'd expect if that were the case. It sounds more like something that was sticking, then suddenly snaps back to its intended position.
It's not a rod bearing knock.
I think that it's a sticking valve...probably in the #3 cylinder. As the cam lobe starts allowing the valve to close, it sticks open a bit before contacting the seat. Then as the cam lobe continues to turn and releases pressure from the pushrod, the valve spring overcomes the sticking point and the valve snaps shut, generating that noise you're hearing. I'm not sure about the valve/piston clearances in these motors, but the piston might also be contacting the open valve and snapping it shut as it gets to the top of its stroke.
Once the motor's running, heat will quickly expand the valve guide just enough to increase the stem-to-guide clearance and eliminate the sticking point. That's why the noise disappears when the motor's running under it's own power.
You can check for a sticking valve in #3 cylinder by removing the valve cover and observing the valve movement while a helper rotates the motor to the point where it makes the noise.
I had this problem once with a Porsche 911 motor. Made noise until the motor ran for a minute or two and freed up the sticking valve. The piston was tapping the valve shut as it neared the top of its stroke, and the valve left a witness mark on the piston to prove it. I had the guides reamed out in that cylinder head and the noise disappeared.
The noise is still heard with the rockers disconnected. |
Both rocker shafts removed...no valve movement at all? It that's the case, forget about what I wrote above _________________ '63 Ragtop (current)
