Scorpion1110 Samba Member
Joined: May 17, 2020 Posts: 43 Location: Maryland 21771
Posted: Sat Jun 19, 2021 9:33 am Post subject: Fuel Injection Hose Type 3 - 1973 Fastback - odd |
Hello Forum;
I decided to start replacing fuel hose on the 73 Fastback. I decided to start with the engine and the fuel injectors passenger side. The existing hose looks factory and is very brittle. When I got the injectors out, I noticed a hose crimp that is unlike what I saw when I did my forum search.
Is this a refurb or replacement exercise?
I prefer not to discard useable parts but if these have to go, so be it.
Thoughts and advice appreciated as always.
Dave |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Jun 19, 2021 10:34 am Post subject: Re: Fuel Injection Hose Type 3 - 1973 Fastback - odd |
You have to use a grinder to carefully grind the connectors off & use new clamps on both ends. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Jun 19, 2021 11:30 am Post subject: Re: Fuel Injection Hose Type 3 - 1973 Fastback - odd |
Mike Fisher wrote: |
You have to use a grinder to carefully grind the connectors off & use new clamps on both ends. |
Thanks Mike-
Well, that was fun. Slightly more fun than getting a cavity filled
Thanks for the help as always!
Dave |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Sat Jun 19, 2021 11:42 am Post subject: Re: Fuel Injection Hose Type 3 - 1973 Fastback - odd |
Yep ^^^^^
These were stock factory crimps ....and many years ago...even rebuilt injectors you might buy at BAP Geon or Beck Arnley...would have those same high quality swaged crimps.
Its a PITA to do. I hold the injectors ...not too tight between rubber or rags in a vise. Adjust the angle to fit how you are comfortable working.
I use a dremel with a fiberglass cut-off wheel. Put a piece of tape over the opening in the inlet barb to keep grit out.
You would to slice off little nubs of this area.....
.....without cutting into the plastic. or through the hose and into the metal barb. I turn the injector in the vise about two or three times. If you can get about 5-6 nubs of metal on that crimp rim cut through so you can see rubber underneath......then do two slots down the length of the ferrule about 180* apart....you can grab the ferrule with a pair of vise grips and twist it right off and then cut or pull off the hose.
Ray |
Posted: Sat Jun 19, 2021 12:57 pm Post subject: Re: Fuel Injection Hose Type 3 - 1973 Fastback - odd |
Thanks Mike and Ray-
Checking the injectors I can see the small seals are cracked. Any recommendation on where to order? I assume I want Viton seals?
A quick google showed mid-america has them and NAPA.
Thanks, Dave |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Sat Jun 19, 2021 1:51 pm Post subject: Re: Fuel Injection Hose Type 3 - 1973 Fastback - odd |
So-called FI clamps are better here. Worm clamps often cut the cloth cover.
