eureka117 Samba Member
Joined: May 10, 2012 Posts: 9 Location: White Plains, NY 10605
Posted: Fri Jun 18, 2021 9:14 pm Post subject: Alternative shocks.. Recommendations |
I have a 70 KG Vert that has been modified
It presently has bad rear air shocks and is just clearing the rear tires.
The original rear suspension system is long gone, springs etc.
It has 165 x 80 x 15 tires running on nice rims and a 12k mileage Mofoco - VW Air-cooled 1600cc Premium Long block engine.
I want replace the air shocks.
Do I stay with air, go to gas, or oil? What brand?
A restore of the rear suspension to VW specifications is not an option.
What about different tires?
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1135 Location: Melbourne Australia
Posted: Sat Jun 19, 2021 2:19 am Post subject: Re: Alternative shocks.. Recommendations |
Are the torsion bars still there?
if so they can be reset to give you a bit more clearance and I like Koni shocks, as they are adjustable.
good luck |
kingkarmann Samba Member
Posted: Sat Jun 19, 2021 8:23 am Post subject: Re: Alternative shocks.. Recommendations |
When I completed the resto on my Ghia I installed a set of Bilstein gas shocks. It's lowered about an inch all around. I found the ride to be very stiff so I switched to stock oil filled. The ride is dramatically better. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3804 Location: Georgia
Posted: Sat Jun 19, 2021 11:26 am Post subject: Re: Alternative shocks.. Recommendations |
I’m running KYB Gas-A-Just on the rear and GR 2s on the front. I tried coil overs on the rear, air shocks on the rear, which always leaked but eventually I readjusted my torsion arms and got the wheels with an offset that would fit inside the space and everything is happy happy. Runs nice and straight and feels solid at 90 miles an hour. _________________ Volkswagen!
(Compression 8.7:1) |
frenchroast Samba Member
Posted: Sat Jun 19, 2021 11:52 am Post subject: Re: Alternative shocks.. Recommendations |
I just went back to Sach's oem style oil shocks after years of KYB's. I prefer the oil shocks. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Tue Jun 22, 2021 8:17 am Post subject: Re: Alternative shocks.. Recommendations |
A 'gas shock' is an oil shock that has 'gas' added that prevents, or helps prevent, foaming of the oil during heavy use. Stiffness comes from the 'valving' on the plunger inside of the shock be it with or without gas _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Tue Jun 22, 2021 9:15 am Post subject: Re: Alternative shocks.. Recommendations |
I prefer the stiffer ride of the Bilstein shocks. While they do transmit more road feel, they also eliminate the wallowing and “porpoising” these cars exhibit over expansion joints & dips, none of which are ideal when cornering (or jumping.). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
