spencerfvee Samba Member
Posted: Fri May 21, 2021 10:31 am Post subject: Re: Amr500 failure what could cause this? Pics |
Rockbound wrote: |
spencerfvee wrote: |
hi great you got it back together . would you mind if i asked you where you got your new arm 500 super charger from ? i would like to buy one but i dont want to get a bad one . thanks please post photos of your new super charger i want to see how you made the new mount for your new super charger many thanks spencerfvee |
basically the same mount, the bottom mounting point on my old super charger was in direct line vertically of the pulley shafts, the new one was kinda offset, i actually used the old mount but cut it at the bottom and opened it up then re welded the gap and plated the side of it to reinforce it.
i bought both of them on amazon but from different sellers.
the good unit came from motofansclub store
not really sure where the other unit came from to old to get any info
my build for the entire buggy is here: https://www.thesamba.com/vw/forum/viewtopic.php?t=686076
the supercharger specifically starts on page 9 |
.................................................................................................................thats one bad ass looking buggy you made your own look .instead going old school buggy look .that a lot of guys do you should call it the PA looker . why not they got the Cal look lol lol . super great job on your buggy . and thanks for the info . do you ever go to jims custom vws show here in ohio its in columbiana spencerfvee |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Fri May 21, 2021 10:42 am Post subject: Re: Amr500 failure what could cause this? Pics |
Just wondering if leaded gas would help lubricate the rotors or putting some Marvel Mystery Oil in the gas. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Fri May 21, 2021 12:00 pm Post subject: Re: Amr500 failure what could cause this? Pics |
When my engine is ready to go, I'll be putting some data on my Bug's build thread. Megasquirt, draw through TBI, crank fired with wideband and real time intake temp readings. I can possibly even disable my Marvel oiler and use my infrared temp gun to see if it drops blower heat at all.
Also, your "new" supercharger has a steel cover instead of the whole thing being cast. A real Aisin unit is the same. The lobes also look like both of my OEM ones too. You can see the original pulley on mine are closer in size to the one you are using than I usually see on other engines. You really shouldn't have heat issues from the RPM it's spinning.
Your new one also has the round "nubs" cast into it. Here's a mock up pic of using my Aisin that's locked up. I think something fell into it at the junkyard it came from, thats why I have 2. The seller sent me another one. Mine also have an Aisin ID plate you can see in the 3rd pic. I will take apart the one that only partially spins and take some pics of the autopsy. I'll keep what's good for spare parts.
_________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
Posted: Fri May 21, 2021 1:20 pm Post subject: Re: Amr500 failure what could cause this? Pics |
hay rock bound. look what i found on ebay its off of a subaru its a super charger inter cooler .if you want to see the add on ebay heres the add number 324631040219 it looks like a vw oil cooler lol you might like to see it spencerfvee
Rockbound Samba Member
Joined: September 06, 2017 Posts: 303 Location: Pennsylvania
Posted: Mon May 24, 2021 6:02 am Post subject: Re: Amr500 failure what could cause this? Pics |
Rockbound wrote: |
thanks, i was out at jims last year for the show. hoping to make it again this year. |
vwracerdave wrote: |
Just wondering if leaded gas would help lubricate the rotors or putting some Marvel Mystery Oil in the gas. |
i do add lead additive to the fuel just about every time i fill up |
Posted: Mon May 24, 2021 6:05 am Post subject: Re: Amr500 failure what could cause this? Pics |
thats an interesting idea, not sure where i would fit that though.. lol |
Posted: Mon May 24, 2021 6:07 am Post subject: Re: Amr500 failure what could cause this? Pics |
just got home from dubs on the lake this past weekend, car ran great drove around all day saturday no issues, barley got hot, and it was HOT out.. Time will tell but i feel pretty good about this new unit. |
Posted: Thu May 27, 2021 5:51 am Post subject: Re: Amr500 failure what could cause this? Pics |
Rockbound wrote: |
.....................................................................................................................great i am happy for you that it is running great . spencerfvee |
mark tucker Samba Member
Posted: Thu May 27, 2021 7:27 am Post subject: Re: Amr500 failure what could cause this? Pics |
I think those old coated lobes were tight, possiably to "wear in" and give good prersure...untill it got hot from rubbing and came appart.I think you will be good to go now.have fun!!! |
Ulu Samba Member
Posted: Thu Jun 17, 2021 2:04 pm Post subject: Re: Amr500 failure what could cause this? Pics |
What an awful disappointment to do so much and blow it up from unknown causes.
I used to race MG's. Blowing up was my specialty.
So sympathies @rockbound _________________ SS100 kit kar
1600cc DP |
Posted: Fri Jun 18, 2021 9:44 am Post subject: Re: Amr500 failure what could cause this? Pics |
Ulu wrote: |
So sympathies @rockbound |
yeah all in the process i guess live and learn.. sucks, but shortly after fixing, i ended up smoking cylinder 3 on the turnpike.. so out with the super charger altogether and in with a new stroker 2276 |
Posted: Fri Jun 18, 2021 10:23 am Post subject: Re: Amr500 failure what could cause this? Pics |
poop. |
Posted: Fri Jun 18, 2021 6:33 pm Post subject: Re: Amr500 failure what could cause this? Pics |
Rockbound wrote: |
Ulu wrote: |
....................................... sorry to hear about your motor . you tryed your best with the super charger . good luck spencerfvee |
Ulu Samba Member
Posted: Fri Jun 18, 2021 8:59 pm Post subject: Re: Amr500 failure what could cause this? Pics |
Sad news. . . _________________ SS100 kit kar
1600cc DP |
Posted: Sat Jun 19, 2021 11:53 am Post subject: Re: Amr500 failure what could cause this? Pics |
figure out if it was the super shit in the motor or somethen else!!! |
j10nbom Samba Member
Joined: February 14, 2007 Posts: 262 Location: Philly
Posted: Tue Jan 10, 2023 10:47 am Post subject: Re: Amr500 failure what could cause this? Pics |
Rockbound wrote: |
Ulu wrote: |
Would you recommend buying the same supercharger from that vendor?
I bought a junk one like yours that also destroyed itself. I see the same vendor selling the one you had bought to fix it on ebay:
https://www.ebay.com/itm/264418564613 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Tue Jan 10, 2023 10:28 pm Post subject: Re: Amr500 failure what could cause this? Pics |
Run a bit of 2 stroke oil in the fuel.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
