64 bug rear seat support bar/rail
napgonz
napgonz is offline
PostPosted: Thu Jun 17, 2021 5:00 pm    Post subject: 64 bug rear seat support bar/rail Reply with quote
Hi all,
I've been trying to buy the rear seat support bar but seems like no one sells them new. Any other sources you guys know? I know they sell them used but I would really like to buy it new.
thank you!
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Fri Jun 18, 2021 4:23 am    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
https://www.thesamba.com/vw/classifieds/search.php...r+seat+bar
Try and find a VW wrecker in Ca. These are not hard to find. You just have to know where to look.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
downsbs1
downsbs1 is offline
PostPosted: Fri Jun 18, 2021 8:01 am    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
He's looking for a new one.
I don't know that I've seen anyone repopping these.
PostPosted: Fri Jun 18, 2021 9:22 am    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
I get that. I have never seen a repop of the rear seat support bar. Hence the classifieds post.
Buy Once, Cry Once!
obnoxiousblue
obnoxiousblue is offline
PostPosted: Fri Jun 18, 2021 9:32 am    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
But used. Media blast and powder coat to your preferred color.
Haven’t seen anyone building new and I just finished putting my 64 back together.
Mike
1964 Beetle
2001 Eurovan Camper
napgonz
napgonz is offline
PostPosted: Fri Jun 18, 2021 4:33 pm    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
thank you all for the feedback. Maybe the only option will be getting a used and sand and paint. Very Happy
lardawge
lardawge is offline
PostPosted: Fri Jun 18, 2021 6:29 pm    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
What is the difference with these between years?
11/2/54 L227 Strato Silver Ragtop - Soon to be L41 Black - Build Thread
1/7/55 L275 Light Beige
napgonz
napgonz is offline
PostPosted: Sat Jun 19, 2021 6:23 pm    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
I don't really know, maybe none. I'm pretty new on the vw culture. I'm looking for a mechanic so I can learn but for now I'm ordering the "bugme" videos to get started on the most basic things.
napgonz
napgonz is offline
PostPosted: Sat Jun 25, 2022 7:01 pm    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
Hi all,
finally found it! All the way from Texas Laughing
runamoc Premium Member
runamoc is offline
PostPosted: Tue Jun 28, 2022 7:14 am    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
made one out of angle iron from Lowe's
Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
Scott65Beetle
Scott65Beetle is offline
PostPosted: Tue Jun 28, 2022 7:19 am    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
"bug Me" vids is how I started too. Very helpful.
DesertG
DesertG is offline
PostPosted: Sat Dec 17, 2022 3:48 pm    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
Hi Guys, are these rails supposed to have padding on them to protect the bottom edge of the vinyl seat? On the 65 I just bought, there is no padding and the vinyl is gouged and torn just on the bottom edge. Rest of seat is fine. Sad
1965 Beetle, 1970 1600cc DP 60HP, 12v
61SNRF
61SNRF is offline
PostPosted: Sat Dec 17, 2022 6:23 pm    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
The only insulation is a strip of felt along the bottom of the channel, it can be seen clearly in the reference photo above.
It is common for the seat upholstery to get torn or cut along the bottom outer edges. This happens when the seat cushion is removed/installed for normal battery service/inspection. Stock the seat cushions can be a tight fit but they can get even worse if they use too much padding when the seat is reupholstered. Normally the damage gets hidden when the seat is back down in it's rest position.
-Bruce
An ounce of prevention is worth a pound of cure.
DesertG
DesertG is offline
PostPosted: Sat Dec 17, 2022 6:25 pm    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
Thanks Bruce. I wish I could fix so it does not get worse.
Slow-N-Rusty
Slow-N-Rusty is offline
PostPosted: Sat Dec 17, 2022 6:26 pm    Post subject: Re: 64 bug rear seat support bar/rail Reply with quote
My car had a strip of thin felt (or maybe jute?) padding. It was maybe 1/8" thick and ran the length of the rail.
