Tusk Samba Member
Joined: June 19, 2012 Posts: 207 Location: Massachusetts
Posted: Thu Jun 17, 2021 5:37 pm Post subject: 1385 with Dual Solex 34s - Tuning Issue - SOLVED |
Hello all!
So I'm having a hell of a time trying to tune my 1385, surprisingly running super lean.
1385
1300 SP heads
SVDA 90mm Dizzy
Dual Solex 34s
22mm Venturis
There are two jets marked for 130, one at the bottom of the bowl, one in the throat. Theres a jet outside the carb on the side thats marked 50
Not only did I buy a metric shit ton of jets that are all smaller than the factory jets, but I only bought one of each.
Symptoms;
Starts right up, idles stupid high and theres a ton of white smoke. Unresponsive to mixture screw adjustment, which at this point, I have just barely hanging on by a thread. I would imagine this means I have to jet up?
I have a syncrometer on it as well, 3/4 carb is pulling 30 kg/h, 1/2 carb is pulling 10 kg/h.
How the hell do I sync these up?
Am I correct in thinking I need to jet up?
And of course, how the hell do I tune these? I am quite familiar with these engines but I've never done anything with dual carbs and can't seem to find anything on tuning these carbs specifically.
Any and all help is appreciated, thanks. _________________ 1956 Beetle - Lisbeth - Sold
1979 Bay Window - Betty - Sold
1975 STD Beetle - Lucille - Sold
1964 Beetle - Rita - Restoration in Progress
1971 Squareback - Joanie - Sold
1961 Beetle - Daphne - Sold
bcrazy Samba Member
Tusk Samba Member
Posted: Sun Jun 20, 2021 2:38 am Post subject: Re: 1385 with Dual Solex 34s - Tuning Issue |
Thanks! I called in a buddy of mine with much more experience with dual carbs than I. We found that the throttle plates were actually binding and not returning to a fully closed position, in fact, they were never starting at one either. So the idle was stupid high. We also found that the 3/4 carb was pulling vacuum at idle. I had initially been using that carb for a vacuum signal to the distributor simply because the port looked to be the right size, the other carb had a 1/4" vacuum port. Turns out thats the one I had to be using, albeit with an adapter to step the line size down. After we sorted that, we followed the typical dual carb tuning procedure and it worked out great. Little engine runs pretty strong. _________________ 1956 Beetle - Lisbeth - Sold
1961 Beetle - Daphne - Sold |
