jcptillman Samba Member
Posted: Sun Jun 20, 2021 9:06 am Post subject: best case for a stock fuel injected motor |
I have a 78 beetle convertible that needs a rebuild. I also need to keep it stock so it passes smog, (California)
My original case has issues it was already rebuilt in the past and line bored to the limit so has to be replaced.
I've been looking at the OEM magnesium replacement cases but been having issues finding one.
Is there a better option than the OEM magnesium case that will last? |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Jun 20, 2021 9:25 am Post subject: Re: best case for a stock fuel injected motor |
The stock FI cases didn't have a provision for a mechanical fuel pump otherwise they are basically the same.
Any late case should be able to work for you. I would look for an AE or higher lettered case if you want used or just get a new case from a qualified source. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
mcdragracer Samba Member
Posted: Sun Jun 20, 2021 11:21 am Post subject: Re: best case for a stock fuel injected motor |
Agree with clonebug 100%
If you can't find a FI case, just use a block off plate to cover where the mech fuel pump is bolted to. |
EVfun Samba Member
Posted: Sun Jun 20, 2021 12:17 pm Post subject: Re: best case for a stock fuel injected motor |
With a California smog test in his future is using an earlier case going to cause inspection headaches? _________________
Wildthings wrote: |
Posted: Sun Jun 20, 2021 2:55 pm Post subject: Re: best case for a stock fuel injected motor |
EVfun wrote: |
With a California smog test in his future is using an earlier case going to cause inspection headaches? |
The case shouldn't have anything to do with inspection.....the FI system will have to be up to snuff maybe, but I can't say that the specs in that year can be too hard to meet.... _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
