coolbugfan Samba Member
Posted: Sun Jun 20, 2021 8:45 pm Post subject: Magna Spark II Questions |
Hi Sambas,
I just had the engine rebuilt on my 1965 1200. The distributor would not advance properly. After the builder and I tried a number of cheap ones that would not work properly, he recommended the Magna Spark II. The car runs nicely with it.
Questions:
Unlike the old one, there is no marking for TDC. How do I find TDC to adjust the valves? I know it's supposed to be "about 4 o'clock" and I can see where spark plug wire #1 goes as an approximation. Is there a more precise way of doing this easily?
Spark plug gap. I'm told the coil with the MSII puts out significantly higher voltage than the original. Should the spark plug gap be made larger? Any tables on proper gap for various engine permutations?
Thanks! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9761 Location: Oregon
Posted: Sun Jun 20, 2021 9:26 pm Post subject: Re: Magna Spark II Questions |
Valve adjustment. Find TDC on the crank pulley. Remove the dist cap and verify that the rotor is pointing at the #1 spark plug lug. If not rotate the crank another 180 degrees. Adjust your valves.
Gap the plugs at 28 thousands as normal. The MSII really doesn't put out a more powerful spark to warrant opening the gap further. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Don Jones Samba Member
Joined: April 09, 2020 Posts: 198 Location: Makaha, Hawaii
Posted: Sun Jun 20, 2021 11:02 pm Post subject: Re: Magna Spark II Questions |
Easiest way to adjust your valves is to find TDC on your pulley with rotor facing #1 spark plug wire on distributor cap.
You now can adjust #1 Exhaust, #1 Intake, #2 Intake and #4 exhaust valves.
Rotate the engine 360 degrees to TDC with rotor facing #3 spark plug wire on distributor cap.
You now can adjust #3 exhaust, #3 Intake, #4 Intake and #2 Exhaust valves.
Thanks to Vintage Speed CEO for the tip. |
Posted: Tue Jun 22, 2021 8:16 pm Post subject: Re: Magna Spark II Questions |
thank you.
So, you can adjust 1&2 and 3&4 at the same crank position? Good to know. I thought it was a 90 degree turn for each. Thanks for the tips. Much appreciated. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Jun 22, 2021 8:35 pm Post subject: Re: Magna Spark II Questions |
It’s the same crank position, but the cam position is different
Have to rotate the crank two full circles for the cam to rotate once
Also, it was never 90 degrees...180 degrees if you do it the standard way |
Posted: Tue Jun 22, 2021 9:04 pm Post subject: Re: Magna Spark II Questions |
Okay. Got it. Thanks for the clarrification. |
Posted: Tue Jun 22, 2021 11:41 pm Post subject: Re: Magna Spark II Questions |
Here's the link to the easiest way to adjust your valves.
https://www.youtube.com/watch?v=lfkxlHWZmxM
Check the link just as i explained in the previous message and you will find it to be the best way!
You rotate the crank pulley clockwise once, go under the car and adjust 4 valves, get back out and rotate the crank another 360 degrees and adjust the other 4 valves. Simple. |
mark tucker Samba Member
Posted: Wed Jun 23, 2021 8:03 am Post subject: Re: Magna Spark II Questions |
you dont need tdc. just turn crank in the normal rotation direction look at the valves and see witch exhaust is going down. when it's about 1/4" down adjust the intake valve next to it. repeat 3 more times with the other cylinders. then watch as the intake valve go's down and is comming back up when it's about 1/4" from being all the way up adjust the exzaust valve next to it. repeat 3 more times with the other cylinders. when you get good at it you can see and do them as they come around . it's very eazy. and never worry about any degrees. and spelling dosent change a thing either. |
maui Samba Member
Posted: Tue Jun 29, 2021 11:51 am Post subject: Re: Magna Spark II Questions |
I think you mean you no more mark on pulley and want to know TDC on pulley.Take um off and put on a pulley with TDC to #1,then put yours on and mark um. Den line up rotor with #1 and mark um. Now adjust like da ada guys said. |
Posted: Fri Aug 05, 2022 2:49 pm Post subject: Re: Magna Spark II Questions |
I didn't want to start a new thread for this dumb question
I have forgotten what sparkplugs are compatible with the MSII distributor.
Resister or non-resister?
Damned old age is getting to me! _________________ I have learned over the years.
Buy Once, Cry Once!
