Heat tab/heat sticker
The_orange_beetle
The_orange_beetle is offline
PostPosted: Mon Jun 21, 2021 11:52 am    Post subject: Heat tab/heat sticker Reply with quote
Hi all. If the engine had overheated would this be totally black?
Cheers
Michael Ambrozik
Michael Ambrozik is offline
PostPosted: Mon Jun 21, 2021 9:38 pm    Post subject: Re: Heat tab/heat sticker Reply with quote
I saw you posted on Facebook and got a couple answers, to tell you the truth if it has any meaning it’s for just the area it is stuck to and don’t really mean anything. If you need to know the temp get the proper tooling.
The_orange_beetle
PostPosted: Mon Jun 21, 2021 11:09 pm    Post subject: Re: Heat tab/heat sticker Reply with quote
Thanks for the reply.
I am just trying to work out how the sticker works so I have all the information before I talk to my engine guy.
Thanks again
AlmostHeavenWV_VW Premium Member
AlmostHeavenWV_VW is offline
PostPosted: Tue Jun 22, 2021 10:49 am    Post subject: Re: Heat tab/heat sticker Reply with quote
It's my understanding that those are "warranty" stickers used by some engine rebuilders.
When a customer comes back claiming that the engine is busted after being built its an easy check to see whether or not the engine had been overheated since it was built.
It's a kin to the moisture monitoring things inside electronics to show whether or not the item has ever been wet.
1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor
