texastomeh Samba Member
Joined: November 20, 2018 Posts: 291 Location: Dallas, TX
Posted: Mon Jun 21, 2021 3:35 pm Post subject: Re: andrigs fan |
Quote: |
jpaull wrote:
One problem with the current metal fans is the basic sheetmetal flexes so easy. Half of these that i install, i spin them, and they are not even true. When tightening it on, it bends/flexes some. it relys on one thin sheet of flexible sheetmetal to keep straight. Not exactly a foundation of strength.
A one piece of composite that is most likely not flexible seems like something that would stay straight and true better. |
SOOOO TRUE!!!
I just (two weeks ago) received a new (had to wait nearly two months to receive since they were on backorder) "welded and balanced" type 1 DH fan from Gene Berg Enterprises ($129.00).
It certainly looks new and is nicely welded. I have no way to test or verify if it is "balanced" (which I was assured was done "dynamically" when I inquired prior to ordering). It looks like a quality piece and I am by no means questioning the quality, integrity, or pricing of GBE!
In my case, the issue is the DESIGN OF THE FAN and my not having a zillion-dollar strobe lighted truing fixture/machine. The runout was/is "wobbly as H#LL" despite my best pitiful efforts to correct it using every means available to me as a hobbyist! I think that I have gotten it to a point that it won't rub (at least in the mockup), but I will just have to wait and see how it behaves at speed and under load. I am prone to believe that the best that I can hope for is that it doesn't rub - forget "runs true".
Of course, it can be argued that "not rubbing" is GOOD ENOUGH, but after over-killing in a lot of other areas, I am striving to reduce vibration, noise, imbalance, inefficiency, etc. everywhere that I can.
I would/will replace it in a heartbeat if this new composite fan proves out!!
THANX, and STAY WELL!!
Tom _________________ A new engine build won't solve ALL of life's problems - only those THAT REALLY MATTER!!!
GETTING old was GREAT - BEING old SUCKS!!
Too bad that the guys that know how to solve all of the WORLD's problems are too busy working on old Volkswagens!! |
Onceler Samba Member
Posted: Mon Jun 21, 2021 4:31 pm Post subject: Re: andrigs fan |
I saw the aftermath of a fan explosion a couple weeks ago at a race over in Ohio ,at least I think that’s what happened. Not sure of the specifics or what happened, but it sure ruined a nice looking shroud. Maybe this composite fan won’t cause as much damage if it does come apart. _________________ 1972 Karmann Ghia |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Jun 21, 2021 4:53 pm Post subject: Re: andrigs fan |
I may be wrong, but as I look at it, it seems the hub of the composite fan would round out before the fan shattered |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3444 Location: San Diego
Posted: Mon Jun 21, 2021 4:56 pm Post subject: Re: andrigs fan |
I have a new Berg fan I bought, probably 25 years ago, never used that i just mounted on a alt to check play. Axial was.008", radial was .020".
There are 112 points that would need welded, if you so desire. Also, for the material, intake manifolds have been some form of plastic/glass, whatever for a long time.
Want to see how long something lasts? Try to purposely destroy it. Destructive testing. |
Bad bug Samba Member
Posted: Tue Jun 22, 2021 4:05 am Post subject: Re: andrigs fan |
I am thinking about getting one of these fans and running it with my doghouse system ( all cylinder tins and flaps ). Where i live i am going to need all the cooling i can get with 9.5:1 compression and the tropical climate. |
mark tucker Samba Member
Posted: Tue Jun 22, 2021 10:42 am Post subject: Re: andrigs fan |
being as light as it is, if the addaptors fit corectly it should need no balancing if the machine shop that made the mold had a clue what they were doing. I would suppose a shop that does turbos could balance them perfectly if some proper sized addaptors were made. truing up run out may help.
I did try to balance one of my fans that I spun up in the shroud.I got it about half as bad as it was, thats as far as I could get it.possiably du to side to side run out. I put it on my 2028 for 80000 mile of lots of zinggers & fun. before I sold the car, as far as I know it's still in there.
one thing to remember side to side run out will try to flex the fan back to a straight non run out plane when it gains rpm, the more rpm the more it trys to "right" it's self. this can be catastrophic for a fan thats not strong enough at the shaft area. I would of liked to seen a spider in the back side of andrigs fan, but it may not be a issue, only time and high rpm will tell,it may not need one. I also wonder about alt cooling, that may or may not be a issue as there are pullys that have fans aswell as some alts that have the internal fan, so it may not be needed in andrigs fans.
in the end we just need to do testing and try to read between the lines. blind test by owners are just that, blind.
If I were to try this fan on the same engine take the air flow reading in front of the fan with std type vw heads then again with super flow heads there should be quite a change in reading due to the different air flow through the heads as the supers have less fins, and a big hole between the ports thus reducing pressure letting more flow through. IMHO you need a fan that will flow and make more pressure than the oe fan. how close to the shroud the fan is makes a differance there too. |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Tue Jun 22, 2021 10:44 am Post subject: Re: andrigs fan |
I would like to hear a recording or video of the test engine running with this fan. I am curious because Andrig mentions that it sounds louder and different than a stock fan. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Tue Jun 22, 2021 10:58 am Post subject: Re: andrigs fan |
evanfrucht wrote: |
I would like to hear a recording or video of the test engine running with this fan. I am curious because Andrig mentions that it sounds louder and different than a stock fan. |
I will post a video, when I get mine. It’s on its way _________________ Type 1 1968, Lotosweiss. 2109 oxyboxer engine
Early Bay 1970, Montana Red. Under construction |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue Jun 22, 2021 11:53 am Post subject: Re: andrigs fan |
Looks like page 3 hasnt sprawled into garbage yet.
Forgive me if it was already mentioned but what is the fan made out of?
The nice thing about this fan is if you really want to balance it even more you actually have material to remove unlike the stock units. You have to be careful on what you take out of course but it's still and upgrade.
I know a hand full of people, and have seen many here on the samber, who complain about how noisy the stock fan is. I wonder if this new one ends up being quieter if it can be marketed as a quiet fan. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
txoval Samba Member
Posted: Tue Jun 22, 2021 12:10 pm Post subject: Re: andrigs fan |
Respectfully, read pages 1&2 and visit his website.
I’m not touching the material question as I’ve already gone off on that one.
Andrig clearly tells everyone this fan is louder than stock... |
Posted: Tue Jun 22, 2021 2:18 pm Post subject: Re: andrigs fan |
chickensoup wrote:
Quote: |
Forgive me if it was already mentioned but what is the fan made out of? |
PLEEEEEZ NOOOOOOO!!!!
Posted: Wed Jun 23, 2021 6:27 am Post subject: Re: andrigs fan |
txoval wrote: |
Ah ok thanks. I thought it was answered somewhere but couldnt find it when I skimmed over. I will check again. Thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Wed Jun 23, 2021 7:46 am Post subject: Re: andrigs fan |
I never really noticed the fan noise on my car. I assumed all that noise I heard on other vw's was those dam pea shooters on the oe fluffmer.I woods thought a curved or even just angles blades wood be quieter and take push more air with less pumping losses. but Im no "rocket sciantest" I just drive the dam thing with dinamite straped to my back....WEEEEEEEEEEEEEEEEEEEEEEEEE BOOM I have worked with lotsa diferent balde types.some are better than others.some are simopler to manufactiure than others. this type weather straight or curved or angled would be no different making the mold or molding it unless a lip was added. it is what it is we will have to waite and sea. too bad rock krushier w=isant hear he claimed to hold pattents of blade desyne and was a ex spurt in his field. |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Wed Jun 23, 2021 10:10 am Post subject: Re: andrigs fan |
These came in too late. It was 117* last week and I was driving my doghouse type 1 . If the initial reviews don't suck I'll probably order one of these to try. Worst case scenario, I'd rather have a plastic fan explode than a metal one. I've seen exploding metal fans break fins off the heads. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
txoval Samba Member
Posted: Wed Jun 23, 2021 10:26 am Post subject: Re: andrigs fan |
I've never noticed fan noise either...especially when driving. Where I live you keep the windows down or die from heat stroke
mark tucker wrote: |
Posted: Wed Jun 23, 2021 1:06 pm Post subject: Re: andrigs fan |
txoval wrote: |
tex florida...dam neer the same weather, I was in tex last week for a few days. |
Dauz Samba Member
Posted: Wed Jun 23, 2021 2:10 pm Post subject: Re: andrigs fan |
txoval wrote: |
I thought FL humidity levels were off the chart. I remember being yelled at to get ouf of the pool in Orlando during the summer due to an incoming thunder storm. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9769 Location: Oregon
Posted: Wed Jun 23, 2021 5:28 pm Post subject: Re: andrigs fan |
Fan noise, what's that? I can't hear a fan over the roar of the 45 Dells at WFO anymore than I can hear it over the whine of the straight cut cam gears.
For all the questions here regarding the materials of construction, noise and balance.
Buy one and try it. For the price point. It's an inexpensive component.
Test it yourself!
I'm on the waiting list. I wanna support a new innovator in the business.
Help the man out.
Remember when HPMX Gen 1 carbs came out? Guess who did the R&D?
You guys did. Then EMPI improved the carbs based on customer feedback.
Hell I have a set of EMPI D-series door stops. Those are gen 1. And suck ass! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Wed Jun 23, 2021 6:38 pm Post subject: Re: andrigs fan |
The material is a trade secret... OK, 'nuff said. The balance... well, it's so light it doesn't matter to me and I'm sure it's pretty spot on anyway. It looks like a quality unit.
I'm just mainly curious about the sound. I think it would be a good idea for Andrig to post a video or recording that shows that.
Some may love the noise. Many could give a damn about noise they just wanna go fast Maybe it's not noticable, but perhaps it is very loud and sounds like a helicopter. For example, I don't like the sound of loud straight cut gears personally, but some people want that sound. I for one would just be interested to hear it on an engine. It isn't a deal breaker, just a suggestion out of interest. I'm sure a video of an engine with this fan running will pop up soon enough anyhow.
I'm keeping it in mind for my next top end overhaul scheduled for next year. _________________ 1967 Bug ( the daily rod )
Posted: Wed Jun 23, 2021 7:00 pm Post subject: Re: andrigs fan |
https://www.facebook.com/100063442975216/videos/61...ted_videos
At 27:25 Andrig's runs the fan prototype, in a 36 HP DS fan shroud.
IMO the electric motor makes more noise that the fan. _________________ I have learned over the years.
Buy Once, Cry Once!
