mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Wed Jun 23, 2021 12:56 pm Post subject: Re: New project: 63 sunroof notch |
mdege wrote: |
Thank you Bob for your comment on the nob. It looks like I need the earlier version 311827535 which is held by a small screw. I guess I might need to 3D print the part. It doesn't look lie it is available anywhere. But, who knows part do pop up. I'm picking up NOS sill trim on Friday |
I didn't know there was an earlier version of it, but then a lot of the early cars got a lot of one off parts. You might try asking Jason (aka Notchboy) if he has an early knob, or might know where to find one. I only mention him, as he's hoarding a bunch of early parts. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwpieces Samba Member
Joined: March 23, 2005 Posts: 345 Location: UpHill BothWays, PA
mdege Samba Member
Posted: Wed Jun 23, 2021 9:41 pm Post subject: Re: New project: 63 sunroof notch |
@vwpieces: Thank you very much for the dimensions. That will be a nice challenge to figure out how to make it. 3D Printing is certainly the easiest way, but it looks like the original is made of aluminum or some other silver colored metal.
I'll have my son draw up a 3D model and then I'll decide how to proceed.
@Bobnotch: Ya, it is crazy how many change VW made in the first few years. Just think of it took them 5 iterations to end up with disk breaks. And not enough they even had two different calipers. That is 6 different front breaks in 12 years _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
Posted: Thu Jun 24, 2021 10:42 am Post subject: Re: New project: 63 sunroof notch |
mdege wrote: |
@Bobnotch: Ya, it is crazy how many change VW made in the first few years. Just think of it took them 5 iterations to end up with disk breaks. And not enough they even had two different calipers. That is 6 different front breaks in 12 years |
Yeah, as Tram and Russ used to tell us, the type 3 got all of the experimental stuff first. Like the bigger engine size, dual carbs, dual port heads, then FI, the biggest brakes of all models (first in 5 lug, then 4 lug composite), then the 12 volt option first (police and fire), then across the model line, and things like that, plus dual circuit master cylinders, with 2 different versions of them with 68-70 then 71 on, or tie rod ends getting larger in 67, then inner front wheel bearings changing in mid 68, or IRS being introduced in mid 68 with AT, then becoming standard in 69 for most countries (swing axle stayed available thru 73 as a heavy duty option). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
mdege Samba Member
Posted: Mon Sep 20, 2021 12:23 pm Post subject: Re: New project: 63 sunroof notch |
Time again for a bigger update.
I have been dealing with my doors. both of them had or have a lot of bondo. I fixed the passenger side, but the driver side is too bad for my liking, at least at the moment. I got a NOS door really cheep, it is the correct replacement door, but not a year correct one. It is what VW would have sold to me in the late 60ies. It will do for now.
I was able to pound out the worst of the dents on the passenger side. I didn't need a lot of new bondo.
I also rebuilt the doorstops:
On Saturday a friend of mine helped me pull the body off of the pan:
mdege Samba Member
Posted: Mon Feb 07, 2022 11:18 am Post subject: Re: New project: 63 sunroof notch |
Oh I have been lazy, but mostly just in updating this thread.
I have made some progress since we pulled it apart. I am getting close to finishing the welding on the driver side.
I also finished the inner rocker and heater channel for the passenger side, first I salvaged and repaired the heater tube:
Then I installed it in the inner rocker which I had previously made and made the inner layer of the rocker assembly:
notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
mdege Samba Member
Posted: Mon Feb 07, 2022 2:24 pm Post subject: Re: New project: 63 sunroof notch |
mdege wrote: |
notchboy wrote: |
You do nice work Michael |
Thanks Bob! |
Actually that was Jason's comment (notchboy), but I do have to agree Very nice work Michael. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
mdege Samba Member
Posted: Tue Feb 08, 2022 9:02 am Post subject: Re: New project: 63 sunroof notch |
mdege wrote: |
I am very sorry, that I getting you mixed up.
But, thank you for agreeing with Jason.
And thank you Jason! |
Ja,ja _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
andybla Samba Member
Posted: Tue Feb 08, 2022 1:15 pm Post subject: Re: New project: 63 sunroof notch |
Very nice progress, keep it up! |
mdege Samba Member
vwfye Samba Member
Posted: Thu Mar 31, 2022 8:38 am Post subject: Re: New project: 63 sunroof notch |
Wow! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
mdege Samba Member
Posted: Sun Nov 27, 2022 12:11 pm Post subject: Re: New project: 63 sunroof notch |
I am really bad a keeping this thread up.
I have been plugging away on this car and I am slowly getting the body ready.
I have replaced both rockers. I was lucky to get my hands on a good used one for the left side. And I was able to make a mirror copy of that for the right side.
I still have two areas which are causing me a headache. The PO. replaced the rear corners including the bumper brackets. Unfortunately he did not manage to get it right, actually its way off. The parts were welded in about 1" to far forward and tilted the wrong way. But see for your self:
Unfortunately I have nothing to go by to get it right. I would be really happy if someone could help out with some good picture of this area on an original early notchback. _________________ - Michael
ibjack Samba Member
Joined: February 06, 2002 Posts: 2106 Location: Imperial Beach CA
Posted: Sun Nov 27, 2022 2:06 pm Post subject: Re: New project: 63 sunroof notch |
here is the best I have, hope it helps. This an October 61 car
_________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
mdege Samba Member
