Righting some wrongs, 71 T1 bus engine.
RWK
RWK is offline
PostPosted: Thu Jun 17, 2021 10:20 am    Post subject: Righting some wrongs, 71 T1 bus engine. Reply with quote
Repairing some previous mechanics miss-steps. Have a 1776 that is overheating, backfiring, ect.
Need some additional input;
Details/problems are; 90.5s, CB O44 heads 40x35, Empi 34 EPCs on T3 manifolds, stock exhaust/heat (bug style), clone 009, stock cam? (approx .315 lift at valve) no oil filter, deep sump, missing front engine tin, flaps/t stat, usual holes and gaps in tin, missing oil cooler foam/seals, hoover bit ect., point set pad wore down, (non Bosch), no lobe lube, NGK D8EA plugs.
Obviously not a great combo of parts!
My plan is stock size valve heads, MFCs 040s, ACs L3 or equivalent.
Split case and check, drill and tap for berg full flow kit, re deck if necessary
Fix all tin and cooling issues, correct plugs, points ect.
Customer wants to retain 34EPCs and stock heat and exhaust, spending money on more important items.
Knowing nothing about the 34 EPCs, I'm looking for some advice on jetting and different manifolds, the T3's seem to cause carbs to interfere with shroud, so plan to get aftermarket one's, I see they have both std. and tall style for the 34s. Also possibly diff. or better linkage.
Also any input on a good dist. that would be compatible with the carbs, they do have vac ports on both carbs. Thinking rebuilt 034?
Suggested going back to a stock 34 PICT carb., but would involve more money, and air cleaner mount is hacked off also.
Thanks
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
FarmerBill
FarmerBill is offline
PostPosted: Fri Jun 18, 2021 4:51 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Do you still have the vacuum line for the brake booster hooked up? I ask, because having owned 3 1971 busses, I know that long length of tubing can be the source of frustrating vacuum leaks.
Alstrup
Alstrup is offline
PostPosted: Fri Jun 18, 2021 5:22 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Yeah, once again big valves and stock exhaust Rolling Eyes When will people learn.
So youre spot on. Heads need to go, - AND stock muffler needs to go! End of story. (OR he/you can gut the stock muffler)
Scat sells tall manifolds for the ICT/EPC carbs. The flimsy Empi linkage can be cut down and resized for tall manifolds. I have done that a few times. That along with bearings at the hex bar actually improves the set up signififantly, to the point of being nice.
PS. Get the 20 mm manifold extensions while you are at it.
Check the E tubes
If the stock cam has to stay, so be it, but I would recommend the 2280. Even the engle W90 would be a step in the right direction.
A rebuilt 034 would be a good thing.
Vacum from one carb will work, but the signal does get smoother with a signal from both carbs.
Heads. Buy a set of AA500 from Brian e, with a proper valve job instead of something coincidential out of the box.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
RWK
RWK is offline
PostPosted: Fri Jun 18, 2021 9:15 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Thanks for the reply,
20mm extensions? you mean the insulators for the carb. base?
e tubes= emulsion tubes?
yea the carbs need to be gone thru, 1,2 were rich,(breather tube into 1-2 carb contributing) 3,4 lean despite the wrong plugs.
stock bus muffler/tail pipe any better then bug style? given the displacement? don't think gutting muffler would be an option, maybe tail pipes, heater boxes and muffler new 100 miles ago, showing signs of overheat.
73 Type 181
63 Type 113
Alstrup
Alstrup is offline
PostPosted: Fri Jun 18, 2021 10:25 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Ohhhyearh, that engine has been through H***
Why is there a bug muffler on a bus?
A gutted bus muffler can easily support about 90 hp if done right. We do that every once in a while when it has to look as stock as possible. A gutted bug muffler can support 100 without too much trouble and over 120 if you go ballistic. (But then there is not much stock muffler left apart from the shell)
Since it has been that hot it has most likely also spat a lot of oil into the air cleaner. Another reason to why I prefer some sort of breather box before the air cleaner.
[email protected]
roy@mofoco.com is offline
PostPosted: Fri Jun 18, 2021 11:14 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Thanks
Actually my 041's would be perfect with the dual carbs and stock sized exhaust valves. Plus, since no casting cools as well as mine, they are perfect for a bus.
Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet
RWK
RWK is offline
PostPosted: Fri Jun 18, 2021 11:48 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Roy, heads in stock?
73 Type 181
63 Type 113
RWK
RWK is offline
PostPosted: Fri Jun 18, 2021 12:19 pm    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Farmer Bill, thanks for input, have to solve the over heating first, then on to tuning.
But yes maybe problems with the vac tube also, was hooked up properly with check valve and good brass T, have not traced it to the front yet, newer SAE hose on T3 manifolds tho. Many issues with the whole affair.
73 Type 181
63 Type 113
FarmerBill
PostPosted: Fri Jun 18, 2021 3:26 pm    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
What I'm saying is that a vacuum leak in the booster line could be causing some of your over heating and the lean conditions on your 3/4 side. Might want to plug it for now, just to eliminate it as a potential problem.
RWK
RWK is offline
PostPosted: Tue Jun 22, 2021 11:05 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Well, guess we are going to keep big valve heads, owner wants to try it with cooling system repairs, here is #3 chamber, is this what you get for valve jobs on new heads? they have couple hundred miles most, ex. land about .1-.110 intake around .06 with back cut, ex. look like a single angle valve job!
Limited air flow thru heads also not helping!
73 Type 181
63 Type 113
Ohio Tom
Ohio Tom is offline
PostPosted: Tue Jun 22, 2021 11:32 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
those clone 009's are horrible.
I would venture to say that it is the source of may issues.
The overheating could be from running timing too retarded.
Most "clones" I have seen have way too much advance in them, and they just keep advancing as you rev up.
So during normal operation, it's not near enough advance. That will turn the pipes blue...
Get a good distributor and be done with Chinese crap 009's.
I had a customer bring a motor recently with one. Timing was all over the place. Turns out the thing was falling apart inside. Brand new and falling apart. Timing was jumping around 20+deg.
They just don't give a shit if it works or not.
Alstrup
Alstrup is offline
PostPosted: Tue Jun 22, 2021 12:13 pm    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Opinions vary. But in my book large valve heads, even with a stock cam, stock heaterboxes and esapecially a stock muffler is an absolutely NO GO! Especially not in a bus. That is just plain stupid. A set of 041īs could/would work, but still it needs a better (or freer flowing) muffler. Sometimes I outline the decissions in front of the custemer so hard that it is my way or the highway. I refuse to assemble a combo that I know will work like crap. If the right way is more money, so be it. Not my problem the customer has bought a pile of crap. That is sometimes the only way to make people understand what is going on.
The clone 009 is naturally not helping for the reasons Tom pointed out. I never use them for these reasons.
RWK
RWK is offline
PostPosted: Tue Jun 22, 2021 2:19 pm    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Cust. bringing an electronic dist. can't wait,.. prolly a pertronix, also have to get the 34EPCs sorted out, jetting and needs taller manifolds previous mech. put T3 short ones on it, any advice on jets?, never worked on these 34EPCS, I'm not much of a tuner with all of this aftermarket stuff.
More then likely it will be back for my recommendations, Brick wall and cust is ok with that, going to put CHT gage on it, maybe it will go more then 15 miles with cooling tin fixes, that was max before overheat, previously. d'oh!
May get it running with 009 or SVDA I have good German ones in both.
Thanks
73 Type 181
63 Type 113
RWK
RWK is offline
PostPosted: Tue Jun 22, 2021 2:28 pm    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Did a quick check of chamber vol. and deck it's set up just about 8-1
one head is 53cc other 54 ish. of course the 53 head was 3-4 side, think I'll switch them around, contemplating putting a shim under cyl. drop C.R. some more.
73 Type 181
63 Type 113
madmike
madmike is offline
PostPosted: Thu Jun 24, 2021 4:24 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
My friend kids sand rail was overheating ,, I told him switch back to points ,, it was the 'pertronix' Rolling Eyes
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
oprn
oprn is offline
PostPosted: Thu Jun 24, 2021 4:34 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Isn't low compression one of the reasons the Bus engine runs hot?
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
Alstrup
Alstrup is offline
PostPosted: Thu Jun 24, 2021 6:27 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Thanks
The kit comes with short manifolds regarding type 1 & 3. only the linkage and air cleaners are different.
Definitely try to get it working with an SVDA. But those heads still need to go, or you wohnt get the temperature down to an acceptable level.
RWK
RWK is offline
PostPosted: Sat Jun 26, 2021 7:52 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Going to put on a CHT, Current CR is 8-1 but has stock cam, may shim cyl. to drop CR a little, biggest prob as Alstrup says, is big valve heads and stock exhaust, when back together going to run on stand to prove out, may eliminate another R&R.
73 Type 181
63 Type 113
RWK
RWK is offline
PostPosted: Fri Jul 30, 2021 8:15 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Ok, now on to the EMPI EPC experience, both floats are leaking, new manifolds (Redline) are not fitting any better then previous T3 iron ones, using stock dog house shroud, now a FI shroud.
Watched some u tubes, what a joke, both I watched to see how manifolds/carbs fit on those installs, lol both were with aftermarket shrouds.
Anyone install these carbs with stock fan shrouds? every thing fits, but just barely, and have hammered on the shroud, and with vac/balance tube fittings just about impossible to get to plugs on 2 cylinders.
Plan to make an insulator gasket for the head to manifold maybe 3/16 thick, that pushes manifold out a bit, and keeps the bus heat out of carb, also drill new vac port up by carb mounting surface, not really enough meat to tap so planning just a press fit tube with some JB maybe,
Anyone else have these issues? are there any different manifolds out there ?, tried a stock tall cast iron (040129526) one also but it doesn't offset out far enough, fear the aftermarket "tall" ones would be the same, help or tricks welcome.
Floats,
New manifolds,EPC carbs, and stock DH shroud.
Previous stock T3 manifolds, DH shroud
73 Type 181
63 Type 113
FreeBug
FreeBug is offline
PostPosted: Fri Jul 30, 2021 9:42 am    Post subject: Re: Righting some wrongs, 71 T1 bus engine. Reply with quote
Lower compression should mean less heat, all things being equal. It's the squish that does the magic to keep temps down. Speed of combustion.
