ccowx Samba Member
Joined: May 15, 2015 Posts: 661 Location: Whitehorse Yukon
Posted: Thu Jun 24, 2021 8:36 am Post subject: Attaching manifold heat tubes to a CB SS single intake manifold |
How do you attach the separate heat crossover tubes for the manifold carb heat on this manofold? I am not sure if the two materials are weldable or could I simply use an exhaust sealant? They are a fairly tight friction fit, but not enough to seal.
Thanks!
Chris |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Thu Jun 24, 2021 8:58 am Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
It pretty much needs to be welded. You didn't mention what material your trying to attach to the SS header.
I would find a SS tube and weld it where needed. Mild steel can be welded to stainless using a normal mig setup, but it does not look very good and is prone to cracking. It's a pretty terrible option. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
busdaddy Samba Member
Posted: Thu Jun 24, 2021 9:04 am Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
I think he's referring to those aftermarket single carb manifolds where the heat riser tubes come loose in the box and shove into the lower casting, no welding that. Copper high temp RTV would work fine there.
Before you get too far along look through the hole where the tubes go into, some aren't drill all the way through. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jun 24, 2021 9:10 am Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
Post a pic _________________ 1967 Bug ( the daily rod )
ccowx Samba Member
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Thu Jun 24, 2021 9:28 am Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
The center section of that is aluminum. The pre heat tubes are steel, and yes they are a sloppy fit |
Posted: Thu Jun 24, 2021 9:36 am Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
Yep neither one is stainless steel. You have steel tubes and they shove into a cast aluminum center section. Use your favorite flavor of high temp sealant.
Also apply the sealer while its being fitted. Get everything bolted up before the sealer cures because I'm pretty sure that will make it easier to line up all the flanges and such. _________________ 1967 Bug ( the daily rod )
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Jun 24, 2021 9:48 am Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
Get everything fitted/clean and use high temp JB Weld (Extreme Heat).
https://www.jbweld.com/product/j-b-extremeheat
There are other epoxy type materials, but they are pricey...made by Loctite |
ccowx Samba Member
Posted: Thu Jun 24, 2021 10:07 am Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
Thanks guys, that tells me what I need to know. I was hoping to be able to weld or something similar but as I feared the materials don't allow it.
Thanks!
Chris |
zoltron55 Samba Member
Posted: Thu Jun 24, 2021 5:46 pm Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
I was thinking of getting 1 of those intakes let us know if you notice a difference |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Thu Jun 24, 2021 5:54 pm Post subject: Re: Attaching manifold heat tubes to a CB SS single intake manifold |
Make sure to test fit everything first before using any sealant. The tubes are pretty long to accommodate wider engines, and may need to be cut down to fit. |
