Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Thu Jun 24, 2021 1:19 pm Post subject: Re: '59 Karmann Ghia fever |
Ok, ran the back wires behind the tar boards to the left rear light, pulled what was necessary through the hole in the tar board, ran the wire to the right rear light, and along the hood to the license plate light.
Also hooked up the coil (left the wire to the condenser as it seems fine and no new one was supplied). I think I figured out the two wires that need to run from the voltage regulator to the generator (leaving the VR where it is until we get our new generator). My intent is to hook up the new wires on top of those connections on the generator. My hope is that we can still run the car with the generator and VR as they are but using the new wiring. I was surprised that the thick red and black wire did not have a ring terminal — will have to get and attach one ourselves.
Need a screw terminal oil pressure switch but if one is not forthcoming will rig a connection that doesn’t mess up the ring terminal on the wire.
Still need to rig connections to the rear lights, awaiting a better solution. And deal with the starter connections. But it seems like we are approaching a newly wired automobile people!
Just to keep the suspense up— we are going off to a week postvax family reunion of sorts at a house on the beach. It will be difficult, but I think we get all get through this with the knowledge that we might just be on target for a Lime Rock finale.
Stay tuned! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
c21darrel Samba Member
Trylon Samba Member
Posted: Thu Jun 24, 2021 1:45 pm Post subject: Re: '59 Karmann Ghia fever |
Thanks Darrel! Going to order it now! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Marcdeb Samba Member
Posted: Thu Jun 24, 2021 2:04 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
Unfortunately you are missing the bracket to install the correct 58-59 rear bulb holders There should be a bracket spot welded to each side inside the fender that the bulb holders are bolted to. I would stick with what you have. In order to install the correct holders you would have to find the brackets and have them welded in. Maybe something to consider further down the road, but for now make them work so you can enjoy driving your Ghia. |
Just happened onto this picture of a 59 Tail light area showing the bracket that is missing.
_________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Trylon Samba Member
Posted: Thu Jun 24, 2021 2:45 pm Post subject: Re: '59 Karmann Ghia fever |
I can see a bit of it where it was cut off.
Our poor car. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Loren Samba Member
Posted: Thu Jun 24, 2021 3:51 pm Post subject: Re: '59 Karmann Ghia fever |
The tail light bracket is spot welded in place. If you are feeling creative there are several YouTube videos on how to make a small spot welder using parts from an old microwave. I made one and it works really well for small projects. It would work great for this application, though it would take a little touch up painting on the quarter panel to cover the spot welds. Good food for thought. It might make for a great father son project this winter |
Trylon Samba Member
Posted: Thu Jun 24, 2021 4:10 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
Interesting. But I think I will leave it all alone for now. The Grand Illusion is preserved by the taillight covers. I think I met even get away with the recreated photo without too much complaint.
Thanks for the thought Loren. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Trylon Samba Member
Posted: Fri Jun 25, 2021 2:01 am Post subject: Re: '59 Karmann Ghia fever |
John Moxon wrote: |
Your Ghia makes a pretty impressive picture. |
Our Ghia. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Fri Jun 25, 2021 10:32 am Post subject: Re: '59 Karmann Ghia fever |
I know the manuals are not necessarily the final arbitrators, but check this out.
The rear lights in 57 or early seem to go in horizontally.
January ‘57:
This is the first manual that has lights like ours with vertical lights.
June ‘58:
Since our car is December ‘58, I am thinking that these may be originals that have been modified. This seems more likely to me than some PO putting in older ones. I guess the definitive answer lies in the “missing” bracket. I will take a closer look…
In any case, the story is good enough for me to put in festoon bulbs, wire up the screw terminals, and call it concours. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
VeloMikey Samba Member
Posted: Fri Jun 25, 2021 4:44 pm Post subject: Re: '59 Karmann Ghia fever |
You can kind of see the where the tail light bracket used to be in this photo.
How about you purchase two correct tail light housings and make a bracket to hold them in the fender with the original wing nut and stud. Think about how the fuel gauge is held in the dash. That is the concept here. Tail light housing thru the fender opening and they place a wider bracket with "claw" feet on the sides pulling it into the fender. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
Trylon Samba Member
Posted: Fri Jun 25, 2021 5:01 pm Post subject: Re: '59 Karmann Ghia fever |
VeloMikey wrote: |
How about you purchase two correct tail light housings and make a bracket to hold them in the fender with the original wing nut and stud. Think about how the fuel gauge is held in the dash. That is the concept here. Tail light housing thru the fender opening and they place a wider bracket with "claw" feet on the sides pulling it into the fender. |
Ah, if I understand you correctly, this is a “no-weld” solution?
I think I love it! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sat Jun 26, 2021 5:27 am Post subject: Re: '59 Karmann Ghia fever |
So the light bulbs are supposed to be screw terminal as well?!
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
PeteSC Samba Member
Trylon Samba Member
Posted: Sat Jun 26, 2021 6:22 am Post subject: Re: '59 Karmann Ghia fever |
Surprised to see they still make them.
Found some originals though.
Thanks! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Braukuche Samba Member
Posted: Sat Jun 26, 2021 9:59 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
VeloMikey wrote: |
I think I love it! |
You could fabricate the bar and use steel rivets to attach it and use the correct housings. I think the trim and seal would cover the rivets. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Posted: Tue Jun 29, 2021 7:29 am Post subject: Re: '59 Karmann Ghia fever |
Got our work cut out for us people!
Dear Past Parade Entrants,
I hope this email finds you well! We are having our annual Vintage Race & Sports Car Parade to kick off Historic Festival 39, Thursday, September 2, 2021 4 – 7 pm.
In the past, racing entrants have been told that they are welcome to participate in the parade, whereas this year we made it option on the race entry form and the response has been overwhelming! I have a terrible feeling we are not going to be able to accommodate everybody as the total entry is limited to 125 cars. Due to the overwhelming amount of interest, we are going to take this opportunity to be a bit more selective on entrants.
As a way of thanking you for your previous participation we wanted to invite you to be a part of this year’s parade first!
We will be extending this invitation to our general fan base in about two weeks, so if you are interested please email me a filled out application and a photo of your car as soon as possible! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Wed Jun 30, 2021 3:58 am Post subject: Re: '59 Karmann Ghia fever |
Huh, so our car has a ‘58 door:
Who knew?
‘58 Karmann Ghia Fever? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
kingkarmann Samba Member
Posted: Wed Jun 30, 2021 8:51 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
We will be extending this invitation to our general fan base in about two weeks, so if you are interested please email me a filled out application and a photo of your car as soon as possible! |
It's good to have a goal to shoot for, keeps you focused. Not that you are not already _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
