avocado_tom Samba Member
Joined: June 18, 2007 Posts: 235 Location: Pittsburgh, PA
Posted: Thu Jun 24, 2021 6:38 pm Post subject: Brake Drum Removal with Transmission Out |
Hey Volks,
i received a mystery small nut transmission in a trade and I’d like to swap my big nut RGBs onto it and try it out. The problem is that the drums are still on the transmission and I’m having no luck getting the axle nuts loose. I’ve tried the air rachet and also two breaker bars moving in opposite directions (one on a lug nut). The torch has been applied to no avail.
Any tricks I’m missing, or is my best bet to just mount it and pull the nuts, then pull it out?
Thanks!
Avo _________________ "You realists can stay the hell out of our office." - D. Dudas |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Jun 24, 2021 6:52 pm Post subject: Re: Brake Drum Removal with Transmission Out |
… there is a special tool, for that - put the tool, on the nut and beat it with a 3 pound sledge - - it'll get loose - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Thu Jun 24, 2021 7:07 pm Post subject: Re: Brake Drum Removal with Transmission Out |
ZENVWDRIVER wrote: |
… there is a special tool, for that - put the tool, on the nut and beat it with a 3 pound sledge - - it'll get loose - z |
Dig. Of course the tool in question is in my other bus, stuck 60 miles from here, but i can resolve that. Thanks! _________________ "You realists can stay the hell out of our office." - D. Dudas |
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
Posted: Thu Jun 24, 2021 11:43 pm Post subject: Re: Brake Drum Removal with Transmission Out |
I had a similar issue with a spare rear end. Turned our, that the axle nut was sized on one side.
I had access to really heavy duty tools and help at the time. Which solved the problem but created a new one, we stripped a good part of the threads on the axle stub.
Knowing that I would use a grinder to carefully grind down the nut on two sides. Be careful not to grind into the threads on the axle stub. Once you are almost down to the threads take a chisel and whack the rest of the nut apart and off of the stub. _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10198 Location: Petaluma, CA
Posted: Fri Jun 25, 2021 6:27 am Post subject: Re: Brake Drum Removal with Transmission Out |
You can make one of those knocker tools by welding a piece of 1/2” plate steel to the side of your socket. I did it once when I was in a pinch and cut it off later when the knocker was found. |
