72VWSB Samba Member
Joined: August 06, 2018 Posts: 707 Location: New Mexico
Posted: Thu Jun 24, 2021 8:39 am Post subject: Dash Panels for 2-5/8" Autometer tach?? |
Looking for a left side dash panel where I can mount a 2-5/8" Autometer tach and two 2-1/16 gauges. All I find is a 3-1/8" tach hole in all the one's I've looked at. Anyone know where one could be had? Thanks. _________________ 72 VW Super Beetle |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Thu Jun 24, 2021 5:41 pm Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
My VW Dashboard Gauges, first installed in 1977. I cut the stock grill to make these fit (I don't know if aftermarket grills were available then).
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
72VWSB Samba Member
Posted: Thu Jun 24, 2021 8:51 pm Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
Cusser wrote: |
How did you cut the holes without tearing up the thin grills? _________________ 72 VW Super Beetle |
Xevin Samba Member
Posted: Thu Jun 24, 2021 10:01 pm Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
72VWSB wrote: |
How did you cut the holes without tearing up the thin grills? |
I’ve thought about that too. I suspect my X-ACTO knife could slice through that cleanly. Maybe some nice wire cutters. I dunno. Looking forward to how it’s done. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Fri Jun 25, 2021 4:41 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
When I installed mine, I used a hole saw and very minimal pressure, and snugly pressed against a wooden backing. The thin slats did bend a little bit, but they were easy to straighten. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Cusser Samba Member
Posted: Fri Jun 25, 2021 6:08 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
72VWSB wrote: |
Cusser wrote: |
Tin snips
windfish Samba Member
Posted: Fri Jun 25, 2021 6:13 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
I used a dremel with a cutoff wheel on mine, cut the hole slightly too small then worked my way out til the gauges fit snugly.
Xevin Samba Member
Posted: Fri Jun 25, 2021 7:15 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
Ahhh. So the grill is metal. I thought it was plastic.
When someone has time. I would love to see a picture of the back of the gauges from inside the trunk. Thank you. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Fri Jun 25, 2021 8:06 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
Xevin wrote: |
When someone has time. I would love to see a picture of the back of the gauges from inside the trunk. Thank you. |
Yep, the grills are steel
And sure, please excuse the grunge -
The newer VDO gauges I'm using have a threaded body, the keeper screws on from the back and sandwiches the grill + backer to the gauge's front lip.
Backer is a plastic For Sale sign I rattledcanned, the original was too deteriorated to reuse.
So at least in my case the large gauge sits in the speaker hole and is just supported by the grill, can see the grill's retaining tabs around the edge; I have them just barely bent incase I needed to remove it again, it's been holding fine like that.
Looking at the pic I 'spose I could remove the former speaker's retainer, lol, but it's apparently not hurting anything.
Smaller side gauges are similar, but the keeper can engage the dash metal as well (you'll need to cut holes in the dash for them). |
Xevin Samba Member
Posted: Sat Jun 26, 2021 8:53 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
Thanks windfish. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 573 Location: South of Raleigh
Posted: Sat Jun 26, 2021 11:42 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
Aftermarket gauge panels are usually for 67 and earlier cars. The panels for the later padded dash models are physically smaller. So for the later cars you don't really have an option besides DIY |
HarrysRatBug Samba Member
Joined: March 14, 2021 Posts: 27 Location: Grand Forks ND
Posted: Sat Jun 26, 2021 2:42 pm Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
AirCoolin Parts on EBay has solid ones for the later models w/padded dash. I think he is on here as well! |
vamram Samba Member
Posted: Sun Jun 27, 2021 9:06 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
HarrysRatBug wrote: |
Do you have a link? I tried searching "aircoolin parts" on ebay and got zero results. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sun Jun 27, 2021 11:38 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
AirCoolin Parts EBay seller info cdk1974 (33665). Can't get my puter to do a link! |
vamram Samba Member
Posted: Sun Jun 27, 2021 12:14 pm Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
Found it, thanks. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Tue Jun 29, 2021 4:18 am Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
Would like to hear from someone who actually tried to use these on a later car with padded dash, since in the description it also says for 62-67. |
keg184 Samba Member
Joined: July 03, 2016 Posts: 83 Location: Mountville, PA
Posted: Tue Jun 29, 2021 4:09 pm Post subject: Re: Dash Panels for 2-5/8" Autometer tach?? |
I made my own dash panels. Only took a few hours. I made them so they bolt in.
