samm1 Samba Member
Joined: August 20, 2012 Posts: 217 Location: Saskatoon,Sask.
Posted: Sun Jun 06, 2021 4:55 pm Post subject: Oil fill piece |
Does anyone know if this notched piece comes out and what is the easiest way to remove this as it is leaking oil you can see in my picture there’s a couple little holes were it drips.
_________________ Hella ya! |
Zundfolge1432 Samba Member
Posted: Sun Jun 06, 2021 5:02 pm Post subject: Re: Oil fill piece |
Yes it is threaded and comes out |
samm1 Samba Member
Posted: Sun Jun 06, 2021 5:04 pm Post subject: Re: Oil fill piece |
So what’s the easiest tool to use to remove it I don’t have no fancy tools maybe a piece of iron the same width or something? _________________ Hella ya! |
Posted: Sun Jun 06, 2021 5:14 pm Post subject: Re: Oil fill piece |
Two choices but I like the internal pipe wrench.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Sun Jun 06, 2021 5:16 pm Post subject: Re: Oil fill piece |
Get an internal pipe wrench. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Jun 06, 2021 5:18 pm Post subject: Re: Oil fill piece |
It’s also easier and cheaper than trying to source a weird VW tool. |
samm1 Samba Member
Posted: Sun Jun 06, 2021 5:27 pm Post subject: Re: Oil fill piece |
Should be able to make something out of flat bar if I knew the dimensions of the notches, on that tool. _________________ Hella ya! |
Posted: Sun Jun 06, 2021 5:32 pm Post subject: Re: Oil fill piece |
Going the other way here’s that weird tool, it’s old but I never went back to using it after I discovered the pipe wrench
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
samm1 Samba Member
Posted: Sun Jun 06, 2021 5:36 pm Post subject: Re: Oil fill piece |
So what’s the width of the notches on that tool? _________________ Hella ya! |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Sun Jun 06, 2021 6:59 pm Post subject: Re: Oil fill piece |
You could take a one inch socket like this and make one |
davidw99 Samba Member
Joined: September 04, 2003 Posts: 696 Location: Boston, MA
Posted: Fri Jun 25, 2021 2:54 am Post subject: Re: Oil fill piece |
Zundfolge1432 wrote: |
Thank you for posting this. I have been trying to get the oil fill nut off for years with the slotted device but no luck. After seeing your post I bought an internal pipe wrench and removed the nut. It was still difficult to get it started but it came off. No gasket at all under it. Plus the filler was loose. No wonder it leaked. Thanks again. _________________ Dave
'73 Saturn Yellow Sports Bug that has undergone a full pan off restoration. "Herbert IV."
'67 Sedan. "Bellamy." Currently being "refreshed" and recently repainted. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Fri Jun 25, 2021 2:51 pm Post subject: Re: Oil fill piece |
Which size internal pipe wrench (1/2", 3/4", 1"?) fits the nut? _________________ AshMan40
Posted: Sat Jun 26, 2021 2:49 am Post subject: Re: Oil fill piece |
1 inch (25 mm). _________________ Dave
RWK Samba Member
Posted: Sat Jun 26, 2021 6:52 am Post subject: Re: Oil fill piece |
It also helps to warm the generator stand with a propane torch a little. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Sat Jun 26, 2021 4:36 pm Post subject: Re: Oil fill piece |
davidw99 wrote: |
1 inch (25 mm). |
Thanks for confirming.
I just realized that if I zoom in on the pic of the internal wrench box above it says on the right end … 3/4” to 1” _________________ AshMan40
