mystery mechanical failure
rustbus
rustbus is offline
PostPosted: Tue Jun 29, 2021 9:19 am    Post subject: mystery mechanical failure Reply with quote
Hi Guys,
After almost 10 years of no major maintenance, i had a break down yesterday.
Particulars:
camper special engine 2012, 34,000km.
new starter 2012
rebuilt stock high output alternator 2012
-pretty sure i installed everything meticulously.
*battery is also from 2012....
symptoms:
-Super hot outdoor temperatures. like over 35*C
- previous day replaced the ignition lock cylinder with a NOS one
- did not change the ignition switch, it *Seemed* fine...
- up to now, ive had to jumper the bus to start it, most times when hot. no hot start relay. i have a cable running from the starter that i contact to the positive battery terminal to do this.
so yesterday after a drive and few stops, upon trying to start it, the starter just would grind, not engage. and do other funny things like groan a bit. but it did start eventually and i started to drive home. on the ride home, it lost power and bucked a couple times, then ran fine for another 10 mins. a few blocks from home, it started bucking even worse and funny whirring noise was heard by my passenger on his side of the bus. we pulled over and shut down. upon trying to restart, power would cut out. i went to the engine, everything looked ok. check the key again, no power, no dash lights, again back to the engine compartment, the ground cable was smoking and too hot to yank off by hand, so i quickly wrenched it off, and that's it. we towed it home later
It too hot out, up to 39*c for the next 3 days, so im not gonna crawl around under it yet... anyone care to speculate what went wrong? is it a basic starter failure? did my ignition lock cylinder replacement contribute to this?
thanks for thoughts
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Tue Jun 29, 2021 9:52 am    Post subject: Re: mystery mechanical failure Reply with quote
Sounds like either the ignition switch or the solenoid hung up & kept the starter engaged & more than likely cooked the starter. (This will also cause the starter to short internally.)
Abscate Premium Member
Abscate is offline
PostPosted: Tue Jun 29, 2021 12:39 pm    Post subject: Re: mystery mechanical failure Reply with quote
Battery is about 5 years past end of life.
Honestly, with nothing done for 12 years the entire cranking circuit probably has multiple marginal operating parts.
.ssS!
rustbus
rustbus is offline
PostPosted: Wed Jun 30, 2021 12:23 pm    Post subject: Re: mystery mechanical failure Reply with quote
had the battery and starter tested, battery is definitely too old for a load, and the starter solenoid is fused.
i'll replace the ignition switch too.
the starter only had some 34000km of use on it, but i suppose with the weak battery and fiddling with the ignition may have caused it some grief, or the starter these days are just remanufactured to shit standards. it was a "bosch". paid extra for the name too if i remember correctly.
my Bus thread
timvw7476
timvw7476 is offline
PostPosted: Wed Jun 30, 2021 1:15 pm    Post subject: Re: mystery mechanical failure Reply with quote
Typical outcome with Bosch Approved rebuilts, starter OR alternator.
Some of their stuff signs off inside two years, others go a decade plus.
Then there's the starter-mounted solenoid, which costs so much you might as
well treat the entire unit as a single assembly. My last starter was Pure Energy rebuild, from Rockauto, 1 year warranty, it's decent, two+ years in. $40-ishUSD & core return.
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jun 30, 2021 4:34 pm    Post subject: Re: mystery mechanical failure Reply with quote
if you or the PO added a hot start relay look at it too. If it goes bad in the on position it will destroy everything down stream from it.
American Standard Snorkeling Terrier
Bring the American Hostages home alive.
Thanks to all who served:
ToolBox
ToolBox is offline
PostPosted: Thu Jul 01, 2021 11:35 am    Post subject: Re: mystery mechanical failure Reply with quote
If it's a Bosch reman it should have a "lifetime" warrenty.
airkooledchris
airkooledchris is offline
PostPosted: Thu Jul 01, 2021 1:45 pm    Post subject: Re: mystery mechanical failure Reply with quote
keep the old one. the new ones had been such garbage for a while I finally went pushbutton.
rustbus
rustbus is offline
PostPosted: Sun Jul 04, 2021 5:47 pm    Post subject: Re: mystery mechanical failure Reply with quote
No hot start relay, I thought about it but never did it
my Bus thread
rustbus
rustbus is offline
PostPosted: Sun Jul 04, 2021 5:48 pm    Post subject: Re: mystery mechanical failure Reply with quote
Ahh, it was, but alas, I already traded in as a core for a "Wilson" brand unit. I'm sure they would have wanted proof of purchase anyway I wouldn't have had a that anymore
my Bus thread
rustbus
rustbus is offline
I did keep it, but i had, on hand, what I think was a vw brand new replacement switch for a few years now
my Bus thread
rustbus
rustbus is offline
PostPosted: Sun Jul 04, 2021 5:50 pm    Post subject: Re: mystery mechanical failure Reply with quote
So yeah, I replaced the ignition key cylinder, the Ignition switch, the starter and the battery and its better than ever. Now I have 2 keys to deal with but that's ok
my Bus thread
Abscate is offline
PostPosted: Mon Jul 05, 2021 3:38 am    Post subject: Re: mystery mechanical failure Reply with quote
Gabe can re-key that to one key if you get annoyed with that. Hes got a lock on that business. You can find him here on the Samba or on his Tumbler account
.ssS!
